Mon, Jan 7, 2019 7:05 PM
On 1/7/2019 9:00 AM, PhilipJ wrote:
Hi, thanks for the link.
I'm still trying to learn the language of openSCAD so could you explain:
in the module first line it says:
"module Line( pts, r=0.05, closed=false, color=undef, transp=1, fn=4 )"
what is "pts" ?
I assume it is the points for the line but how do I pass them into the
module through this one variable ?
As an example: how would I draw a line from 0,0,0 to 30,30,30 ?
Many thanks for your time
pts is an array of 3D points to connect.
The tersest answer to your question is
Line([[0,0,0],[30,30,30]]);
Reformatting a bit for readability:
Line([
[0,0,0],
[30,30,30]
That will yield the default radius of 0.05 units. You probably want
some other radius, so perhaps
Line([
[0,0,0],
[30,30,30]
], 5);
I'd recommend that you use positional arguments only in the most trivial
of cases, and that in more complex cases you use named arguments:
Line(r=5, pts=[
[0,0,0],
[30,30,30]
The default for that module is to generate four-sided "cylinders". You
can adjust that:
Line(r=5, fn=20, pts=[
[0,0,0],
[30,30,30]
though I don't understand why there's an explicit fn parameter instead
of just using $fn. I would remove the ", $fn=fn" from the cylinder call
at the end, and then any of these will work:
Line(r=5, $fn=20, pts=[
[0,0,0],
[30,30,30]
$fn = 20;
Line(r=5, pts=[
[0,0,0],
[30,30,30]
$fa = 10;
$fs = 0.1;
Line(r=5, pts=[
[0,0,0],
[30,30,30]
I like that better because it integrates better with other OpenSCAD
constructs.
Similarly, I don't understand why there is an explicit color and
transparency options, rather than letting you control those using the
color() transformation.
Note that it's a list; you can connect multiple points, e.g.:
Line(r=5, pts=[
[0,0,0],
[30,30,30],
[-30,30,30]
> what is "pts" ?
Line([
[0,0,0],
[30,30,30]
Line([
[0,0,0],
[30,30,30]
], 5);
Line(r=5, pts=[
[0,0,0],
[30,30,30]
can adjust that:
[0,0,0],
[30,30,30]
[0,0,0],
[30,30,30]
$fn = 20;
Line(r=5, pts=[
[0,0,0],
[30,30,30]
$fa = 10;
$fs = 0.1;
Line(r=5, pts=[
[0,0,0],
[30,30,30]
constructs.
Line(r=5, pts=[
[0,0,0],
[30,30,30],
[-30,30,30]
PhilipJ
Mon, Jan 7, 2019 7:33 PM
Line([
[0,0,0],
[30,30,30]
Thanks, that is a great and comprehensive explanation, I appreciate it :-)
regards
PhilipJ
> Line([
> [0,0,0],
> [30,30,30]
regards
PhilipJ
Mon, Jan 7, 2019 8:43 PM
Using a smaller number would cut down rendering and preview time.
Thanks, I tried different values, 10 makes the rods look like hexagons, 30
was still a bit rough but rendered 4 rods in 11 seconds, still seems
awfully
slow.
If th rods are made of cylinders and spheres with no hull function then the
Render takes fractions of a second, but I'm still trying to resolve the
cartesian to spherical coods bit so I can rotate the cylinder to the
correct
angles to join up...
The long render times are not due to the hull but the union of the rods.
Better times result if the rods are just cylinders without the spherical
cap because the vertex count is smaller. The following code runs relatively
fast compared to the hull solution, however the rod joint is not as much
smooth.
$fn=30;
rod_dia=3;
rod([ 0, 0,0], [10,10,30], rod_dia);
rod([20, 0,0], [10,10,30], rod_dia);
rod([ 0,20,0], [10,10,30], rod_dia);
rod([20,20,0], [10,10,30], rod_dia);
module rod(p1,p2,d)
translate(p1)
rotFromTo([0,0,1], p2-p1)
cylinder(d=d, h=norm(p2-p1));
module rotFromTo(di,do)
if( norm(di-do)==0 || norm(di)==0 || norm(do)==0 )
else
mirror(do/norm(do)+di/norm(di)) mirror(di) children();
The module rotFromTo does exactly what you were searching for: rotates the
cylinder from the upward direction ( [0,0,1] ) to the desired direction.
For another approach, take a look on
https://en.wikibooks.org/wiki/OpenSCAD_User_Manual/The_OpenSCAD_Language#Rotation_rule_help
BTW, you may want to subscribe to the mailing list in order to have a
broader audience to your messages. Some people, like me, usually don't read
the forum messages in the forum site but rather from their mail box.
Jan 07, 2019; 5:08pm [image: PhilipJ]
<http://forum.openscad.org/template/NamlServlet.jtp?macro=user_nodes&user=2371>
PhilipJ
> > $fn=100 is pretty big.
> awfully
> slow.
> correct
smooth.
$fn=30;
rod_dia=3;
module rod(p1,p2,d)
translate(p1)
else
PhilipJ
Tue, Jan 8, 2019 10:39 AM
Si I have found the solution to my conversion problem, it was in the help
text under rotate (if only I'd read it properly!!).
Thus if "a" is fixed to zero, and "b" and "c" are manipulated
appropriately, this is the spherical coordinate system.
So, to construct a cylinder from the origin to some other point (x,y,z):
x= 10; y = 10; z = 10; // point coordinates of end of cylinder
length = norm([x,y,z]); // radial distance
b = acos(z/length); // inclination angle
c = atan2(y,x); // azimuthal angle
rotate([0, b, c])
cylinder(h=length, r=0.5);
%cube([x,y,z]); // corner of cube should coincide with end of cylinder
All my attempts used atan2() for both angles, this uses acos for one of
them, I don't know what the difference is but this one works for all four
quadrant angles.
Thanks to everyone who took time to offer suggestions, now moving on to the
geodesic dome :-)
PhilipJ
>> rotate([0, b, c])
quadrant angles.
geodesic dome :-)
PhilipJ
runsun
Tue, Jan 8, 2019 10:04 PM
JordanBrown answered it in details. One more "pt" to add: that Line(pts...)
function is able to take multiple points:
Line( pts= [ [2,3,4],[5,6,7],[1,2,3] ... ] );
So you can throw in hundreds or even thousands of pts and it will draw like
a cham. This efficiency is something the hull() can't achieve.
JordanBrown answered it in details. One more "pt" to add: that *Line(pts...)*
Wed, Jan 9, 2019 11:31 AM
a cham.* This efficiency is something the hull() can't achieve.*
runsun,
I disagree. The hull() operation (at least in this case of convex sets) is
very fast compared to the union of the rods. I have done some tests to show
it.
- define the rods and the Phillip's tent frame as:
$fn=30;
translate([ 0, 0,0]) rotFromTo([0,0,1],-([ 0, 0,0] - [10,10,30]))
rod(rod_dia);
//translate([20, 0,0]) rotFromTo([0,0,1],-([20, 0,0] - [10,10,30]))
rod(rod_dia);
//translate([ 0,20,0]) rotFromTo([0,0,1],-([ 0,20,0] - [10,10,30]))
rod(rod_dia);
//translate([20,20,0]) rotFromTo([0,0,1],-([20,20,0] - [10,10,30]))
rod(rod_dia);
module rod(d)
hull() {
sphere(d/2);
translate([0,0,norm([ 0, 0,0] - [10,10,30])]) sphere(d/2);
Now, the rods are fixed length and vertical. Render this code with a clean
cache. The hulled rod will be in the cache. Render again dropping the
comments in the main code. The last running time will be spent just in the
union. In my computer, it is (surprisingly) greater then the render time of
the original code.
- In the original code, instead of the hulled rods draw just a sphere at
the top end. The render time will again show the union render time. In my
computer, it is again (and very surprisingly) greater then the render time
of the original code.
Conclusion: the render time of the hull() operation is negligible compared
to the union operation. Even the union of 4 disjoint sphere spends more
render time than the hull() of them.
Em ter, 8 de jan de 2019 às 22:05, runsun <runsun@gmail.com> escreveu:
runsun,
it.
1) define the rods and the Phillip's tent frame as:
$fn=30;
rod(rod_dia);
rod(rod_dia);
rod(rod_dia);
rod(rod_dia);
module rod(d)
hull() {
sphere(d/2);
the original code.
2) In the original code, instead of the hulled rods draw just a sphere at
runsun
Wed, Jan 9, 2019 11:57 PM
@Ronaldo, Thx. I did mention "hundreds or thousands of points". Have you
tested that many points?
runsun
Thu, Jan 10, 2019 12:14 AM
Have to correct myself on this --- in the past I did preview, never did
render. With some preliminary tests now, rendering on "hundreds/thousands of
pts" with either Line() or rod() seems impossible (takes too long), so it's
hard to state which is faster in my tests.
Thu, Jan 10, 2019 4:39 PM
of
I use my version of Line only in preview mode for debugging geometry. To
avoid any accidental render of lines, I check $preview inside of Line and
inhibit the drawing if false.
Em qui, 10 de jan de 2019 às 00:15, runsun <runsun@gmail.com> escreveu:
> of
