this is a question about coding style. (I’m new to functional programming.)
I prefer to write in small enough pieces/functionality that I can already
understand it before the first coffee in the morning. In OpenSCAD I use this
pattern:
For individual objects that works well but now I’m trying to make more
complex modules and there seems to be a piping problem, informations don’t
always go through all the elements that a module-to-be is made of.
What are the things I need to know about OpenSCAD if I don’t want to write
in two-pages-functions-of-horror but in smaller, easier to maintain parts,
especially when writing modules? Is there a guide or discussion about coding
style in OpenSCAD anywhere?
As an example, these two files makes the same thing. As small-parts-code:
https://github.com/benjaminwand/OpenSCAD-loft-module/blob/master/two%20layers/two%20layers%20example.scad
and as working module:
https://github.com/benjaminwand/OpenSCAD-loft-module/blob/master/two%20layers/two%20layers%20module.scad
Thanks for the help!
Yes, if the answer is “read xyz book”, I would consider that helpful.
About style:
I don't know any guide to style for OpenSCAD coding. Some people prefer to
define functions and module bottom up following the order that is common in
C programming: define objects above its usage points. Some other prefer the
reverse top down style: the main module is defined first. I prefer the
bottom up style. Anyway I use smaller identifiers than you used in your
codes. I prefer to precede each function or module with a short comment
describing succinctly what it does (not how it does) and have a more
condensed code where they are called. This is a matter of taste but to me
lengthy identifiers usually overcrowd the text and spoil the readability.
About your code:
I don't define as many global variables as you do. I prefer to define
functions to compute intermediate results and to include all values needed
for a function computation as function arguments. For instance, in one of
your codes, the the middle point computation is partially done by a function
and a variable initialization. However, it is simple enough to be computed
just in one function as I show bellow. In some points of your code, you use
the function concat to build a vector like concat(1,2,3) instead of [1,2,3]
which is simpler and clearer. In fact, I consider idiosyncratic this
functionality of concat which should be restricted to concatenate lists.
Find bellow my version of your loft. That code may be used as a library to
be included in other codes. The global variables and the intersection at the
end serves only as a example of usage and would be ignored by the clause
include. Finally, you may find useful to study the loft of the library
skin.scad found in
https://github.com/openscad/list-comprehension-demos
// compute intermediate points between the vertices of a upper polygon
// and a lower polygon both with same number of vertices
function middle_points(upper, lower) =
let( l=len(upper) )
l!= len(lower) ?
[ for(i=[0:l-1])
(upper[i] + lower[i] + upper[(i+1)%l] + lower[(i+1)%l])/4
// a loft of two planar polygons with the same number of vertices
// the function result is a pair [list of points, list of faces]
// appropriate to build a polyhedron
function simple_loft(poly1, poly2, rev=false) =
let(l = len(poly1))
l!=len(poly2) ?
[ // points
concat(poly1, poly2),
// faces
if(rev) // revert?
[ [for(i=[0:l-1]) i], // poly1 facet
for(i=[0:l]) [(i+1)%l + l, (i+1)%l, i+l], // triangular faces
for(i=[0:l]) [i, i+l, (i+1)%l],
[for(i=[l-1:-1:0]) i+l]] // poly2 facet
else
[ [for(i=[l-1:-1:0]) i], // poly1 facet
for(i=[0:l-1]) [(i+1)%l, (i+1)%l + l, i+l], // triangular faces
for(i=[0:l-1]) [i, (i+1)%l, i+l],
[for(i=[0:l-1]) i+l] ] // poly2 facet
// build a loft from the planar polygon upper to the planar polygon lower
(both
// with same number of vertices) by creating an intermediate set of vertices
// in between
module loft(upper, lower)
if (len(upper)==len(lower))
s1 = simple_loft(upper, middle_points(upper, lower),true ); // upper
volume
s2 = simple_loft(lower, middle_points(upper, lower),false); // lower
volume
f1 = [for(i=[0:len(s1[1])-2]) s1[1][i] ]; // remove from s1 and s2 the
faces
f2 = [for(i=[0:len(s2[1])-2]) s2[1][i] ]; // of middle points
polyhedron( points = concat(s1[0], s2[0]),
faces = concat( f1, // upper faces
[for(f=f2)[for(v=f)
v+len(s1[0])]] ) // lower faces
my_upper_points = [ [0,20,20], [5,12.5,15], [10,5,10], [15,-2.5,5],
[20,-10,0], [10,-10,5], [0,-10,10], [-10,-10,15],
[-20,-10,20], [-15,-2.5,20], [-10,5,20], [-5,12.5,20] ];
my_lower_points = [ [0,10,-20], [12,30,-20], [8,5,-20], [35,0,-20],
[8,-5,-20], [12,-30,-20], [0,-10,-20], [-12,-30,-20],
[-8,-5,-20], [-35,0,-20], [-8,5,-20], [-12,30,-20] ];
intersection(){
//render()
loft(my_upper_points, my_lower_points);
//translate([0,0,-500]) cube(1000); // uncomment to check CGAL failure on
F6
Hi, thanks for the answer! I still don’t understand 100% of it but it helps.
