ManuelSuarez wrote
Dear all, it is possible do: objectA && objectB?
the reason is that i have an object with holes but when i place them very
close the holes are filled by the second one. There is a way to preserve
the holes?
Thanks in advance
What you need to do is to union only those parts of the objects that do not
overlap. So you can first remove the overlap from each part.
union()
ObjectA;
ObjectBWithoutHoles;
ObjectB;
ObjectAWithoutHoles;
This is only a sketch. The rotates and transforms have to be duplicated in
the relevant locations. As written it would probably create a non-manifold
surface where the two touch; you should probably scale down or move the
subtracted objects so that the union ends up overlapping the the resulting
objects by a tiny amount. In creating "ObjectXWithoutHoles" you could
simplify it further; in some cases a bounding cube would be good enough.
View this message in context: http://forum.openscad.org/Logic-operation-among-objects-tp18725p18727.html
Or alternatively:
ObjectAHoles;
ObjectBHoles;
View this message in context: http://forum.openscad.org/Logic-operation-among-objects-tp18725p18731.html
