I want to create a SVG that will display concentric circles. OpenSCAD will
only show the largest circle. Is there a way to do this?
for (a = [1, 5]){
circle(r=a);
Thanks
View this message in context: http://forum.openscad.org/Displaying-concentric-circles-tp21939.html
A couple items here. One is the separator is a colon :
The other is you are creating a circle with a solid center, making the inner
ones invisible.
I used a difference to subtract a circle of 0.25 smaller diameter, keeping
the outside diameter to your formula:
http://forum.openscad.org/file/n21940/circles.png
View this message in context: http://forum.openscad.org/Displaying-concentric-circles-tp21939p21940.html
OpenSCAD produces 2D geometry, a circle in a circle is just a circle.
If you want to do concentric rings you will need to remove (difference)
inner circles.
circle(40);
circle(35);
View this message in context: http://forum.openscad.org/Displaying-concentric-circles-tp21939p21941.html
Beat me by 3 min...
View this message in context: http://forum.openscad.org/Displaying-concentric-circles-tp21939p21942.html
The short answer is no. OpenSCAD performs a top-level union. Since your largest circle encompasses the smaller ones, you are always left with one big circle.
You can approximate it using a difference. This creates nonintervention thin shells.
for (a=[1,5])
circle (r=a);
circle (r=a-0.1);
Sent from my iPhone
for (a = [1, 5]){
circle(r=a);
Thanks
The application is creating gcode files for CNC and the overlapping circles
was just an example of my problem. If it's impossible, I'll need to
selectively display and create several SVGs of my design. Not the best
solution, but it works.
big circle.
thin shells.
for (a=[1,5])
circle (r=a);
circle (r=a-0.1);
Sent from my iPhone
will
for (a = [1, 5]){
circle(r=a);
Thanks
Usually, but [1, 5] will go through to the loop twice with a equal to
first 1 and then 5, which is useful at times.
for (a = [1, 5]){
circle(r=a);
Thanks
Maybe it would be easier to make the concentric circles using Inkscape
to generate the SVG which can then be exported to OpenSCAD using the
library from Drew Newman https://www.thingiverse.com/thing:25036.
Generally spoken, OpenScad is not the right language to produce Gcode, as
Gcode is always target machine dependent. For simple stuff like circles try
http://www.intuwiz.com/circle.html and see what you get.
Well, if you know what you do, you indeed can use OpenSCAD to design "flat"
and "line-like" 3D objects, export them as STL and abuse a slicer tool to
generate Gcode from that. Say you want to have your 5 circles with 1 to 5 cm
radius then your code would be something like this:
$fa = .2; // resolution
for (a = [10:10:50])
difference() // use line thickness of 0.5mm for single line slicing
cylinder(r=a+.25, h=.5, center=true);
cylinder(r=a-.25, h=.6, center=true);
after F6 and export as STL, you can use a slicer to do the dirty work. A
slicer uses a profile to adopt its code to the target machine. It outputs a
text file and you can use any editor to find what you are trying to find, if
you know what you are looking for. Of course you should study G-Code a bit,
but the sematics is quite simple and straight forward.
For the above code my kisslicer http://www.kisslicer.com/ (which uses
the profile for my 3D Printer) produced the following circle code (find the
raw file attached):
G1 X122.18 Y118.94 E15.8864 F1200
G1 X123.65 Y117.02 E15.9503
G1 X125.65 Y114.09 E16.0439
G1 X126.85 Y112.08 E16.1058
G1 X128.42 Y109.06 E16.1955
G1 X129.41 Y106.86 E16.2594
G1 X130.5 Y104.03 E16.3394
G1 X131.35 Y101.37 E16.413
G1 X131.87 Y99.42 E16.4665
G1 X132.33 Y97.37 E16.5219
G1 X132.68 Y95.45 E16.5734
G1 X132.94 Y93.59 E16.6229
G1 X133.21 Y90.53 E16.7042
G1 X133.32 Y87.42 E16.7862
G1 X133.28 Y85.48 E16.8376
G1 X133.13 Y83.2 E16.898
... and so on.
The E Parameter is the Extrusion and the F parameter the speed. It depends
on your target machine, whether it just ignores it. Also you should add a G0
X122.18 Y118.94 and some other code to instruct your targetmachine to do
what you want it to do before and after each circle.
Here is the raw gcode file: test.gcode
http://forum.openscad.org/file/n21949/test.gcode
View this message in context: http://forum.openscad.org/Displaying-concentric-circles-tp21939p21949.html
