assertion is ignored
Mon, Nov 18, 2019 1:39 AM
Is this a bug?  I have run across this sort of problem before, but in more
complex situations.  This one is quite simple.
function lcm(a,b) =
assert(is_num(a) && is_num(b),"Invalid parameters to lcm")
abs(a*b) / gcd(a,b);
function gcd(a,b) =
b==0 ? abs(a) : gcd(b,a % b);
echo(lcm([60,12]));  // Oops, called with list instead of two args
Result:
ERROR: Recursion detected calling function 'gcd' in file test105.scad, line
159
TRACE: called by 'gcd', in file test105.scad, line 159.
If I rewrite the code like this:
function lcm(a,b) =
let(
parmok = is_num(a) && is_num(b),
dummy=assert(parmok,"Invalid parameters to lcm")
function gcd(a,b) =
Then I get the expected behavior:
ERROR: Assertion 'parmok' failed: "Invalid parameters to lcm" in file
test105.scad, line 145
TRACE: called by 'lcm', in file test105.scad, line 152.
TRACE: called by 'echo', in file test105.scad, line 152.
Is this a bug? I have run across this sort of problem before, but in more complex situations. This one is quite simple. function lcm(a,b) = assert(is_num(a) && is_num(b),"Invalid parameters to lcm") abs(a*b) / gcd(a,b); function gcd(a,b) = b==0 ? abs(a) : gcd(b,a % b); echo(lcm([60,12])); // Oops, called with list instead of two args Result: ERROR: Recursion detected calling function 'gcd' in file test105.scad, line 159 TRACE: called by 'gcd', in file test105.scad, line 159. TRACE: called by 'gcd', in file test105.scad, line 159. TRACE: called by 'gcd', in file test105.scad, line 159. TRACE: called by 'gcd', in file test105.scad, line 159. TRACE: called by 'gcd', in file test105.scad, line 159. If I rewrite the code like this: function lcm(a,b) = let( parmok = is_num(a) && is_num(b), dummy=assert(parmok,"Invalid parameters to lcm") ) abs(a*b) / gcd(a,b); function gcd(a,b) = b==0 ? abs(a) : gcd(b,a % b); echo(lcm([60,12])); // Oops, called with list instead of two args Then I get the expected behavior: ERROR: Assertion 'parmok' failed: "Invalid parameters to lcm" in file test105.scad, line 145 TRACE: called by 'lcm', in file test105.scad, line 152. TRACE: called by 'echo', in file test105.scad, line 152. -- Sent from: http://forum.openscad.org/
Mon, Nov 18, 2019 2:45 AM
Probably, but it seems fixed in 2019.10.06.
Probably, but it seems fixed in 2019.10.06. ----- Admin - email* me if you need anything, or if I've done something stupid... * click on my MichaelAtOz label, there is a link to email me. Unless specifically shown otherwise above, my contribution is in the Public Domain; to the extent possible under law, I have waived all copyright and related or neighbouring rights to this work. Obviously inclusion of works of previous authors is not included in the above. -- Sent from: http://forum.openscad.org/
