Re: [OpenSCAD] make an object hollow with constant wall thickness
C
clothbot
Mon, Nov 2, 2015 7:31 PM
If you don't care as much about the inner geometry and precision of the wall
thickness, and want something that runs reasonably quickly, you can do
something like this old "shell_3d()" module I came up with:
https://github.com/clothbot/makerbot/blob/master/fabjects/libraries/constructors/shell_3d.scad
It's basically a union of shifted-difference operations.  Handy if you want
to be asymmetric in your thicknesses, e.g. thicker top relative to bottom
and sides to allow for more 3d-printed internal self-supporting structure.
Andrew.
View this message in context: http://forum.openscad.org/make-an-object-hollow-with-constant-wall-thickness-tp14255p14270.html
If you don't care as much about the inner geometry and precision of the wall thickness, and want something that runs reasonably quickly, you can do something like this old "shell_3d()" module I came up with: https://github.com/clothbot/makerbot/blob/master/fabjects/libraries/constructors/shell_3d.scad It's basically a union of shifted-difference operations. Handy if you want to be asymmetric in your thicknesses, e.g. thicker top relative to bottom and sides to allow for more 3d-printed internal self-supporting structure. Andrew. -- View this message in context: http://forum.openscad.org/make-an-object-hollow-with-constant-wall-thickness-tp14255p14270.html Sent from the OpenSCAD mailing list archive at Nabble.com.
