Re: [OpenSCAD] Setting Normalized Tree limit from command line?
N
nophead
Mon, Nov 7, 2016 9:24 AM
I have always assumed that the GUI preferences are also used by the command
line. I have it set to 100000 and never see an issue rendering complex
models on the command line.
Are you running the command line from the same user account as you run the
GUI?
View this message in context: http://forum.openscad.org/Setting-Normalized-Tree-limit-from-command-line-tp18958p18985.html
I have always assumed that the GUI preferences are also used by the command line. I have it set to 100000 and never see an issue rendering complex models on the command line. Are you running the command line from the same user account as you run the GUI? -- View this message in context: http://forum.openscad.org/Setting-Normalized-Tree-limit-from-command-line-tp18958p18985.html Sent from the OpenSCAD mailing list archive at Nabble.com.
Mon, Nov 7, 2016 10:04 AM
Von: nophead nop.head@gmail.com
No, GUI preferences are not available at all when running from
command line.
The setting is available as "--csglimit=num", not sure when
it was introduced though.
Von: nophead <nop.head@gmail.com> > I have always assumed that the GUI preferences are also used > by the command line. I have it set to 100000 and never see an > issue rendering complex models on the command line. > No, GUI preferences are not available at all when running from command line. The setting is available as "--csglimit=num", not sure when it was introduced though. ciao, Torsten.
Mon, Nov 7, 2016 2:42 PM
I wonder how I manage to render a full model of a Mendel90 without ever
setting this.
command line.
I wonder how I manage to render a full model of a Mendel90 without ever setting this. On 7 November 2016 at 10:04, Torsten Paul <Torsten.Paul@gmx.de> wrote: > Von: nophead <nop.head@gmail.com> > > I have always assumed that the GUI preferences are also used > > by the command line. I have it set to 100000 and never see an > > issue rendering complex models on the command line. > > > No, GUI preferences are not available at all when running from > command line. > > The setting is available as "--csglimit=num", not sure when > it was introduced though. > > ciao, > Torsten. > > _______________________________________________ > OpenSCAD mailing list > Discuss@lists.openscad.org > http://lists.openscad.org/mailman/listinfo/discuss_lists.openscad.org >
Mon, Nov 7, 2016 3:28 PM
Von: "nop head" nop.head@gmail.com
Maybe due to the well placed render() calls?
Von: "nop head" <nop.head@gmail.com> > I wonder how I manage to render a full model of a Mendel90 > without ever setting this. > Maybe due to the well placed render() calls? ciao, Torsten.
Mon, Nov 7, 2016 3:39 PM
Both the cmd-line and GUI defaults to 100K.
I believe this number was increase to 100K a few versions ago..
> On Nov 7, 2016, at 09:42, nop head <nop.head@gmail.com> wrote: > > I wonder how I manage to render a full model of a Mendel90 without ever setting this. > Both the cmd-line and GUI defaults to 100K. I believe this number was increase to 100K a few versions ago.. -Marius
Troberg
Mon, Nov 7, 2016 3:40 PM
Thanks, I'll try as soon as I'm at the correct computer!
I have a sneaking suspicion it won't help, though, as it previews just fine
in the GUI with a setting of 100000, but the command line doesn't and
complains that it's more than 100000.
I'll try, though, and get back about how it works.
View this message in context: http://forum.openscad.org/Setting-Normalized-Tree-limit-from-command-line-tp18958p18993.html
Thanks, I'll try as soon as I'm at the correct computer! I have a sneaking suspicion it won't help, though, as it previews just fine in the GUI with a setting of 100000, but the command line doesn't and complains that it's more than 100000. I'll try, though, and get back about how it works. -- View this message in context: http://forum.openscad.org/Setting-Normalized-Tree-limit-from-command-line-tp18958p18993.html Sent from the OpenSCAD mailing list archive at Nabble.com.
Troberg
Mon, Nov 7, 2016 7:39 PM
Thank you, worked like a charm!
Perhaps the documentation could be a little clearer on the subject, it is
just listed without any explanation.
Anyway, I really love OpenSCAD, it works the way I think. It's a
programmer's CAD.
View this message in context: http://forum.openscad.org/Setting-Normalized-Tree-limit-from-command-line-tp18958p18994.html
> The setting is available as "--csglimit=num", not sure when > it was introduced though. Thank you, worked like a charm! Perhaps the documentation could be a little clearer on the subject, it is just listed without any explanation. Anyway, I really love OpenSCAD, it works the way I think. It's a programmer's CAD. -- View this message in context: http://forum.openscad.org/Setting-Normalized-Tree-limit-from-command-line-tp18958p18994.html Sent from the OpenSCAD mailing list archive at Nabble.com.
