stl, amf, off, 3mf
Mon, Mar 2, 2020 3:22 PM
I am currently preparing an update to my thingiverse post  globoid worm gear
https://www.thingiverse.com/thing:2776688  where I show the simulation of
a  subtractive process
https://cdn.thingiverse.com/assets/8b/4e/87/f7/3d/story.gif  in order to
create a worm-gear couple. In contrast to the referred post I now construct
the worm (and the cutting tool) in a direct fashion by sweeping an explicit
2D spline, which avoids the first difference operation. This speeds up the
whole process and leads to a more stable and reliable output.
However, even CGAL succeeds to render proper objects which I can export into
stl format, a proper reimport of such an STL is not possible in most cases,
in the sense that a union with a cube(1) leads to a CGAL error. Therefore I
started to experiment with the other available file formats and found out
that the problem also exists with AMF and OFF, but not with 3MF.
Therefore I suspected that it is the number of digits in the vertex
coordinates that differs and leads to the problem. To check this, I exported
rotate(5) cube(100);
into all four formats and checked the representation of the same coordinate.
Here the results:
STL
vertex 90.9039 108.335 100
OFF
90.9039 108.335 100
AMF
<vertex><coordinates>
<x>90.9039</x>
<y>108.335</y>
<z>100</z>
3MF (to view: rename file.3mf to file.zip and unzip the text file
3dmodel.model)
<vertex x="90.903896" y="108.335048" z="100.000000" />
3mf obviously contains output more digits and more close to the exact
representation used by OpenSCAD. But due to binary/decimal conversion issues
it also might have its limits.
  1. While binary formats seem to be limited to single (16 bit) values I don't
    know whether at least the text formats for STL, AMF and OFF, forbid it to
    output more digits. But wouldn't it be a solution to do so? I suspect, that
    most - if not all - importers don't care anyway.
  2. Wouldn't it make sense to introduce/offer an output format that exactly
    represents an OpenSCAD object and can thus be imported without any losses
    and risks. I personally wouldn't mind if such a format was proprietary,
    because one can always use OpenSCAD as converter.
I am currently preparing an update to my thingiverse post globoid worm gear <https://www.thingiverse.com/thing:2776688> where I show the simulation of a subtractive process <https://cdn.thingiverse.com/assets/8b/4e/87/f7/3d/story.gif> in order to create a worm-gear couple. In contrast to the referred post I now construct the worm (and the cutting tool) in a direct fashion by sweeping an explicit 2D spline, which avoids the first difference operation. This speeds up the whole process and leads to a more stable and reliable output. However, even CGAL succeeds to render proper objects which I can export into stl format, a proper reimport of such an STL is not possible in most cases, in the sense that a union with a cube(1) leads to a CGAL error. Therefore I started to experiment with the other available file formats and found out that the problem also exists with AMF and OFF, but *not with 3MF*. Therefore I suspected that it is the number of digits in the vertex coordinates that differs and leads to the problem. To check this, I exported rotate(5) cube(100); into all four formats and checked the representation of the same coordinate. Here the results: STL vertex 90.9039 108.335 100 OFF 90.9039 108.335 100 AMF <vertex><coordinates> <x>90.9039</x> <y>108.335</y> <z>100</z> 3MF (to view: rename file.3mf to file.zip and unzip the text file 3dmodel.model) <vertex x="90.903896" y="108.335048" z="100.000000" /> 3mf obviously contains output more digits and more close to the exact representation used by OpenSCAD. But due to binary/decimal conversion issues it also might have its limits. 1. While binary formats seem to be limited to single (16 bit) values I don't know whether at least the text formats for STL, AMF and OFF, forbid it to output more digits. But wouldn't it be a solution to do so? I suspect, that most - if not all - importers don't care anyway. 2. Wouldn't it make sense to introduce/offer an output format that *exactly* represents an OpenSCAD object and can thus be imported without any losses and risks. I personally wouldn't mind if such a format was proprietary, because one can always use OpenSCAD as converter. -- Sent from: http://forum.openscad.org/
TV
Tim V. Shaporev
Mon, Mar 2, 2020 3:50 PM
Do you mean 32-bit (not 16) binary IEEE floating-point format?
As far as I read it requires up to 9 decimal digits to represent its
value as a text so the current dumper implementation involves accuracy
loss against binary STL either.
I see no good reason to hold on 6 meaningful digits output.
Here the results:
STL
OFF
90.9039 108.335 100
AMF
<x>90.9039</x>
<y>108.335</y>
<z>100</z>
3dmodel.model)
Do you mean 32-bit (not 16) binary IEEE floating-point format? As far as I read it requires up to 9 decimal digits to represent its value as a text so the current dumper implementation involves accuracy loss against binary STL either. I see no good reason to hold on 6 meaningful digits output. On 3/2/2020 6:22 PM, Parkinbot wrote: > I am currently preparing an update to my thingiverse post globoid worm gear > <https://www.thingiverse.com/thing:2776688> where I show the simulation of > a subtractive process > <https://cdn.thingiverse.com/assets/8b/4e/87/f7/3d/story.gif> in order to > create a worm-gear couple. In contrast to the referred post I now construct > the worm (and the cutting tool) in a direct fashion by sweeping an explicit > 2D spline, which avoids the first difference operation. This speeds up the > whole process and leads to a more stable and reliable output. > > However, even CGAL succeeds to render proper objects which I can export into > stl format, a proper reimport of such an STL is not possible in most cases, > in the sense that a union with a cube(1) leads to a CGAL error. Therefore I > started to experiment with the other available file formats and found out > that the problem also exists with AMF and OFF, but *not with 3MF*. > Therefore I suspected that it is the number of digits in the vertex > coordinates that differs and leads to the problem. To check this, I exported > > rotate(5) cube(100); > > into all four formats and checked the representation of the same coordinate. > Here the results: > > STL > vertex 90.9039 108.335 100 > > OFF > 90.9039 108.335 100 > > AMF > <vertex><coordinates> > <x>90.9039</x> > <y>108.335</y> > <z>100</z> > > 3MF (to view: rename file.3mf to file.zip and unzip the text file > 3dmodel.model) > <vertex x="90.903896" y="108.335048" z="100.000000" /> > > 3mf obviously contains output more digits and more close to the exact > representation used by OpenSCAD. But due to binary/decimal conversion issues > it also might have its limits. > > 1. While binary formats seem to be limited to single (16 bit) values I don't > know whether at least the text formats for STL, AMF and OFF, forbid it to > output more digits. But wouldn't it be a solution to do so? I suspect, that > most - if not all - importers don't care anyway. > > 2. Wouldn't it make sense to introduce/offer an output format that *exactly* > represents an OpenSCAD object and can thus be imported without any losses > and risks. I personally wouldn't mind if such a format was proprietary, > because one can always use OpenSCAD as converter. > > > > > > > > > -- > Sent from: http://forum.openscad.org/ > > _______________________________________________ > OpenSCAD mailing list > Discuss@lists.openscad.org > http://lists.openscad.org/mailman/listinfo/discuss_lists.openscad.org > . >
arnholm@arnholm.org
Mon, Mar 2, 2020 3:52 PM
issues
The numeric precision of the ascii file formats (STL, AMF, OFF and
probably 3MF)is a property of the software that wrote those files , not
a property of the file formats themselves. For example, xcsg (
https://github.com/arnholm/xcsg ) writes ASCII versions of those files
in up to 12 digit precision (where required).
    don't
    to
    that
This is not correct. Binary STL contains 32bit floating point
coordinates, i.e. single precision. OFF is ASCII only I think, there is
no limit to the numeric precision you can write to it, but there is no
point in writing higher precision than the precision of the software
reading those files.
  1. Wouldn't it make sense to introduce/offer an output format that
    exactly
    losses
A good start would be for OpenSCAD to write binary STL by default, that
would give you 32 bit precision right away, smaller files and faster
reads.
On the other hand, one should not really use STL for anything, as it is
just a polygon soup in all cases. Better to use e.g. OFF with 12 digit
precision.
That being said, there is nothing to stop you from writing formatted
files with c (64 bit) , for STL, AMF or OFF, but the importer must use
double precision as well.
Now, if you want exactly what OpenSCAD uses internally (in CGAL), I
suspect things will be getting really ugly. xcsg uses standard 64 bit
double precision internally, but CGAL uses its peculiar numeric
representation (causing slowness).
On 2020-03-02 16:22, Parkinbot wrote: > 3mf obviously contains output more digits and more close to the exact > representation used by OpenSCAD. But due to binary/decimal conversion > issues > it also might have its limits. The numeric precision of the ascii file formats (STL, AMF, OFF and probably 3MF)is a property of the software that wrote those files , not a property of the file formats themselves. For example, xcsg ( https://github.com/arnholm/xcsg ) writes ASCII versions of those files in up to 12 digit precision (where required). > 1. While binary formats seem to be limited to single (16 bit) values I > don't > know whether at least the text formats for STL, AMF and OFF, forbid it > to > output more digits. But wouldn't it be a solution to do so? I suspect, > that > most - if not all - importers don't care anyway. This is not correct. Binary STL contains 32bit floating point coordinates, i.e. single precision. OFF is ASCII only I think, there is no limit to the numeric precision you can write to it, but there is no point in writing higher precision than the precision of the software reading those files. > 2. Wouldn't it make sense to introduce/offer an output format that > *exactly* > represents an OpenSCAD object and can thus be imported without any > losses > and risks. I personally wouldn't mind if such a format was proprietary, > because one can always use OpenSCAD as converter. A good start would be for OpenSCAD to write binary STL by default, that would give you 32 bit precision right away, smaller files and faster reads. On the other hand, one should not really use STL for anything, as it is just a polygon soup in all cases. Better to use e.g. OFF with 12 digit precision. That being said, there is nothing to stop you from writing formatted files with c (64 bit) , for STL, AMF or OFF, but the importer must use double precision as well. Now, if you want *exactly* what OpenSCAD uses internally (in CGAL), I suspect things will be getting really ugly. xcsg uses standard 64 bit double precision internally, but CGAL uses its peculiar numeric representation (causing slowness). Carsten Arnholm
CA
Mon, Mar 2, 2020 4:14 PM
Here the results:
STL
OFF
90.9039 108.335 100
AMF
<x>90.9039</x>
<y>108.335</y>
<z>100</z>
3dmodel.model)
I repeated that example using xcsg
Formatted STL (binary STL is preferred in xcsg)
  vertex 90.90389553440875 108.3350440839404 100
OFF
90.9038955344 108.335044084 100
AMF
<coordinates>
<x>90.903895534408747</x>
<y>108.33504408394037</y>
<z>100</z>
</coordinates>
OBJ
v 90.9038955344 108.335044084 100
There is a slight mismatch in the number of digits that xcsg generates
for these formats, they should really all be the same, and at some stage
it is just "numeric noise". But your examples have clearly truncated the
numbers to become useless for import.
On 02.03.2020 16:22, Parkinbot wrote: > To check this, I exported > > rotate(5) cube(100); > > into all four formats and checked the representation of the same coordinate. > Here the results: > > STL > vertex 90.9039 108.335 100 > > OFF > 90.9039 108.335 100 > > AMF > <vertex><coordinates> > <x>90.9039</x> > <y>108.335</y> > <z>100</z> > > 3MF (to view: rename file.3mf to file.zip and unzip the text file > 3dmodel.model) > <vertex x="90.903896" y="108.335048" z="100.000000" /> I repeated that example using xcsg Formatted STL (binary STL is preferred in xcsg) vertex 90.90389553440875 108.3350440839404 100 OFF 90.9038955344 108.335044084 100 AMF <coordinates> <x>90.903895534408747</x> <y>108.33504408394037</y> <z>100</z> </coordinates> OBJ v 90.9038955344 108.335044084 100 There is a slight mismatch in the number of digits that xcsg generates for these formats, they should really all be the same, and at some stage it is just "numeric noise". But your examples have clearly truncated the numbers to become useless for import. Carsten Arnholm
Mon, Mar 2, 2020 5:20 PM
Carsten, you are half right. It is 32 bit that is used for single
precision. I don't know, why I wrote 16 bit, sorry for this. Of course any
modern CAD program will internally use double values (64bit) as CPUs
natively support them. This means that values in binary STLs also truncated.
As we know from several elder threads OpenSCAD internally uses several
representations from single to double to fixed point and as CGAL is
concerned rationals.
However I think we could gain a lot, if we were able to persist OpenSCAD
objects in a lossless format.
> 1. While binary formats seem to be limited to single (16 bit) values I Carsten, you are half right. It is 32 bit that is used for *single* precision. I don't know, why I wrote 16 bit, sorry for this. Of course any modern CAD program will internally use double values (64bit) as CPUs natively support them. This means that values in binary STLs also truncated. As we know from several elder threads OpenSCAD internally uses several representations from single to double to fixed point and as CGAL is concerned rationals. However I think we could gain a lot, if we were able to persist OpenSCAD objects in a lossless format. -- Sent from: http://forum.openscad.org/
FV
Frank van der Hulst
Mon, Mar 2, 2020 5:24 PM
3D-printing precision is normally about 80 steps/mm or so. Of course, you
can build a printer with higher (or lower) precision, but I doubt that
accuracy of all the mechanisms could be much better than +/-.001mm. So
specifying points to precision better than .001mm would usually be
pointless.
coordinate.
Here the results:
STL
OFF
90.9039 108.335 100
AMF
<x>90.9039</x>
<y>108.335</y>
<z>100</z>
3dmodel.model)
OFF
AMF
<coordinates>
<z>100</z>
</coordinates>
OBJ
3D-printing precision is normally about 80 steps/mm or so. Of course, you can build a printer with higher (or lower) precision, but I doubt that accuracy of all the mechanisms could be much better than +/-.001mm. So specifying points to precision better than .001mm would usually be pointless. On Tue, Mar 3, 2020 at 5:15 AM Carsten Arnholm <arnholm@arnholm.org> wrote: > On 02.03.2020 16:22, Parkinbot wrote: > > To check this, I exported > > > > rotate(5) cube(100); > > > > into all four formats and checked the representation of the same > coordinate. > > Here the results: > > > > STL > > vertex 90.9039 108.335 100 > > > > OFF > > 90.9039 108.335 100 > > > > AMF > > <vertex><coordinates> > > <x>90.9039</x> > > <y>108.335</y> > > <z>100</z> > > > > 3MF (to view: rename file.3mf to file.zip and unzip the text file > > 3dmodel.model) > > <vertex x="90.903896" y="108.335048" z="100.000000" /> > > I repeated that example using xcsg > > Formatted STL (binary STL is preferred in xcsg) > > vertex 90.90389553440875 108.3350440839404 100 > > OFF > 90.9038955344 108.335044084 100 > > AMF > <coordinates> > <x>90.903895534408747</x> > <y>108.33504408394037</y> > <z>100</z> > </coordinates> > > > OBJ > v 90.9038955344 108.335044084 100 > > > There is a slight mismatch in the number of digits that xcsg generates > for these formats, they should really all be the same, and at some stage > it is just "numeric noise". But your examples have clearly truncated the > numbers to become useless for import. > > Carsten Arnholm > > _______________________________________________ > OpenSCAD mailing list > Discuss@lists.openscad.org > http://lists.openscad.org/mailman/listinfo/discuss_lists.openscad.org >
arnholm@arnholm.org
Mon, Mar 2, 2020 5:37 PM
precision.
That's what I said.
truncated.
It depends. 32 bit floating point numbers correspond to approximately 7
decimal digits. 64 bit floating point numbers correspond to
approximately 16 decimal digits. I will standardise on 16 decimal digits
for formatted output of coordinates, but it is really overkill since the
last few digits are mostly noise.
concerned rationals.  hard.
And this means that single precision on binary STL will be good enough
until you got those other issues sorted.
OpenSCAD
I would challenge you to define lossless in this context, it is harder
than it may seem. Defining a binary format with 64 bit double precision
is the easy part. An as mentioned before, the existing formats support
double precision already, so why not use them?
On 2020-03-02 18:20, Parkinbot wrote: >> 1. While binary formats seem to be limited to single (16 bit) values I > > Carsten, you are half right. It is 32 bit that is used for *single* > precision. That's what I said. > I don't know, why I wrote 16 bit, sorry for this. Of course any > modern CAD program will internally use double values (64bit) as CPUs > natively support them. This means that values in binary STLs also > truncated. It depends. 32 bit floating point numbers correspond to approximately 7 decimal digits. 64 bit floating point numbers correspond to approximately 16 decimal digits. I will standardise on 16 decimal digits for formatted output of coordinates, but it is really overkill since the last few digits are mostly noise. > As we know from several elder threads OpenSCAD internally uses several > representations from single to double to fixed point and as CGAL is > concerned rationals. hard. And this means that single precision on binary STL will be good enough until you got those other issues sorted. > However I think we could gain a lot, if we were able to persist > OpenSCAD > objects in a lossless format. I would challenge you to define lossless in this context, it is harder than it may seem. Defining a binary format with 64 bit double precision is the easy part. An as mentioned before, the existing formats support double precision already, so why not use them? Carsten Arnholm
arnholm@arnholm.org
Mon, Mar 2, 2020 5:42 PM
This is correct only for the final step in the process (assuming the
process is 3d printing, sometimes it is not).
Parkinbots starting premise was that he wanted to import an existing
model (in STL, OFF or whatever) and further process it. In such a
situation it is essential that all precision is retained. Importing
models with truncated precision is almost always guaranteed major
problems.
Not understanding this has caused a lot of problems for people.
Cartsten Arnhol,
On 2020-03-02 18:24, Frank van der Hulst wrote: > 3D-printing precision is normally about 80 steps/mm or so. Of course, > you can build a printer with higher (or lower) precision, but I doubt > that accuracy of all the mechanisms could be much better than > +/-.001mm. So specifying points to precision better than .001mm would > usually be pointless. This is correct only for the final step in the process (assuming the process is 3d printing, sometimes it is not). Parkinbots starting premise was that he wanted to import an existing model (in STL, OFF or whatever) and further process it. In such a situation it is essential that all precision is retained. Importing models with truncated precision is almost always guaranteed major problems. Not understanding this has caused a lot of problems for people. Cartsten Arnhol,
AC
Alan Cox
Mon, Mar 2, 2020 6:08 PM
On Mon, 2 Mar 2020 10:20:15 -0700 (MST)
Or at least a stable one. Part of the problem with things like STL is
that if you blindly write or read floats you get ambiguity between points
and OpenSCAD doesn't use a point dictionary to resolve it.
Personally I'd use 64bit 32.32 fixed precision if I was writing these
kinds of tools. Whilst PC class hardware is pretty fast at floats a lot
of tablet/phone devices are not.
32.32 fixed point for the usual 1 = 1mm covers a range of +/- 4294
kilometres at a precision sufficient for everyone (even people assembling
molecules) and the accuracy of your object doesn't depend on its
distance from the 0. With floats if you translate an object away from the
centre it gets less accurate and can change, as well as the fact that
translating an object somewhere away from the centre and back loses
accuracy in most unintuitive ways.
Alan
On Mon, 2 Mar 2020 10:20:15 -0700 (MST) Parkinbot <rudolf@digitaldocument.de> wrote: > > 1. While binary formats seem to be limited to single (16 bit) values I > > Carsten, you are half right. It is 32 bit that is used for *single* > precision. I don't know, why I wrote 16 bit, sorry for this. Of course any > modern CAD program will internally use double values (64bit) as CPUs > natively support them. This means that values in binary STLs also truncated. > As we know from several elder threads OpenSCAD internally uses several > representations from single to double to fixed point and as CGAL is > concerned rationals. > > However I think we could gain a lot, if we were able to persist OpenSCAD > objects in a lossless format. Or at least a stable one. Part of the problem with things like STL is that if you blindly write or read floats you get ambiguity between points and OpenSCAD doesn't use a point dictionary to resolve it. Personally I'd use 64bit 32.32 fixed precision if I was writing these kinds of tools. Whilst PC class hardware is pretty fast at floats a lot of tablet/phone devices are not. 32.32 fixed point for the usual 1 = 1mm covers a range of +/- 4294 kilometres at a precision sufficient for everyone (even people assembling molecules) *and* the accuracy of your object doesn't depend on its distance from the 0. With floats if you translate an object away from the centre it gets less accurate and can change, as well as the fact that translating an object somewhere away from the centre and back loses accuracy in most unintuitive ways. Alan
AC
Alan Cox
Mon, Mar 2, 2020 6:14 PM
On Mon, 2 Mar 2020 18:50:43 +0300
What matters is not just the digits but the fact that you don't end up
with two different points having the same value. Ditto any 'noise' needs
to cause points to collide of swap over when exported/imported.
A good STL exporter creates a list of every point. If there are two
points that would collide because of precision loss then you jiggle them
by the smallest possible value up or down (and repeating if need be) so
that the points remain unambiguous and correctly numerically ordered (and
the error introduced is microscopic in proportion the value).
Alan
On Mon, 2 Mar 2020 18:50:43 +0300 "Tim V. Shaporev" <tim.shaporev@auriga.ru> wrote: > Do you mean 32-bit (not 16) binary IEEE floating-point format? > As far as I read it requires up to 9 decimal digits to represent its > value as a text so the current dumper implementation involves accuracy > loss against binary STL either. > I see no good reason to hold on 6 meaningful digits output. What matters is not just the digits but the fact that you don't end up with two different points having the same value. Ditto any 'noise' needs to cause points to collide of swap over when exported/imported. A good STL exporter creates a list of every point. If there are two points that would collide because of precision loss then you jiggle them by the smallest possible value up or down (and repeating if need be) so that the points remain unambiguous and correctly numerically ordered (and the error introduced is microscopic in proportion the value). Alan
