Richy_T
Mon, Dec 26, 2016 6:27 AM
Sometimes, especially if you're 3D printing, you just want to cut off
everything beyond a certain value. You can sort-of do this with a large cube
but it's easy to make errors and if your camera ends up inside the cube, you
get weird things happening so it would be really useful just to have a
plane() primitive that you can just do difference() against or whatever.
Presumably there would have to be some restrictions because I'm guessing you
couldn't export an actual plane to an stl file and other such fun things but
as a virtual object, it would be extremely useful.
View this message in context: http://forum.openscad.org/Request-for-Plane-Primitive-tp19750.html
FV
Frank van der Hulst
Mon, Dec 26, 2016 6:42 AM
I agree. It perhaps could also make mirror() more general.
cube
you
you
but
> cube
> you
> you
> but
Mon, Dec 26, 2016 9:47 AM
You can get rid of the camera problems by using render() or intersection()
instead of difference().
On 26 December 2016 at 06:42, Frank van der Hulst drifter.frank@gmail.com
cube
you
you
but
On 26 December 2016 at 06:42, Frank van der Hulst <drifter.frank@gmail.com>
>> cube
>> you
>> you
>> but
Mon, Dec 26, 2016 12:31 PM
I've never had a problem using difference() and a cube.
large cube
cube, you
whatever.
guessing you
things but
> large cube
> cube, you
> whatever.
> guessing you
> things but
Mon, Dec 26, 2016 12:35 PM
The problem is that when viewed with F5 the camera has to be outside the
big cube you use as a substitute for a plane. This is because OpenCSG does
not draw the cube if any of it is beyond the clipping plane.
cube
you
you
but
>> cube
>> you
>> you
>> but
Richy_T
Mon, Dec 26, 2016 5:07 PM
Hmm, intersection() might be a plan. I'm not familiar with render() but I'll
give it a look.
View this message in context: http://forum.openscad.org/Request-for-Plane-Primitive-tp19750p19764.html
give it a look.
Mon, Dec 26, 2016 5:30 PM
render() uses CGAL to actually compute the geometry and just leaves CGAL to
render the resulting polyhedron.
> I'll
> give it a look.
FV
Frank van der Hulst
Mon, Dec 26, 2016 6:21 PM
One situation where it was a problem for me is dividing an imported STL
(aircraft model) into halves... you need to know the size of the object so
that you can draw a larger cube, but there's no way to find out what the
size of the STL is.
size of the STL is.
Mon, Dec 26, 2016 8:08 PM
That would be trivial with a bounding box information. I don't understand
how OpenSCAD do resize() without computing a bounding box. And if it is
computed, why it is not available by a language function.
2016-12-26 16:21 GMT-02:00 Frank van der Hulst drifter.frank@gmail.com:
size of the STL is.
2016-12-26 16:21 GMT-02:00 Frank van der Hulst <drifter.frank@gmail.com>:
> size of the STL is.
