Discrpency, wiki v's exmaples
Sun, Jul 5, 2015 4:03 AM
The wiki example here
https://en.wikibooks.org/wiki/OpenSCAD_User_Manual/First_Steps/Opening_an_existing_example_model
does not match example004.scad, missing the translate & cylinder.
As the wiki has a graphic with the cylinder, perhaps the extra two lines
should be added to the distributed example004.scad (and its new name if it
made it to the new examples structure)?
View this message in context: http://forum.openscad.org/Discrpency-wiki-v-s-exmaples-tp13040.html
The wiki example here <https://en.wikibooks.org/wiki/OpenSCAD_User_Manual/First_Steps/Opening_an_existing_example_model> does not match example004.scad, missing the translate & cylinder. As the wiki has a graphic with the cylinder, perhaps the extra two lines should be added to the distributed example004.scad (and its new name if it made it to the new examples structure)? ----- Unless specifically shown otherwise above, my contribution is in the Public Domain; To the extent possible under law, I have waived all copyright and related or neighbouring rights to this work. This work is published globally via the internet. :) Inclusion of works of previous authors is not included in the above. The TPP is no simple “trade agreement.” Fight it! http://www.ourfairdeal.org/ -- View this message in context: http://forum.openscad.org/Discrpency-wiki-v-s-exmaples-tp13040.html Sent from the OpenSCAD mailing list archive at Nabble.com.
Sun, Jul 5, 2015 6:06 PM
I've simply removed the reference to the example004 filename. I think it
still makes sense that way...
On 07/05/2015 06:03 AM, MichaelAtOz wrote: > The wiki example here > <https://en.wikibooks.org/wiki/OpenSCAD_User_Manual/First_Steps/Opening_an_existing_example_model> > does not match example004.scad, missing the translate & cylinder. > > As the wiki has a graphic with the cylinder, perhaps the extra two lines > should be added to the distributed example004.scad (and its new name if it > made it to the new examples structure)? > I've simply removed the reference to the example004 filename. I think it still makes sense that way... ciao, Torsten.
