I need to create a 3D shape that starts out as a hollow rectangle and ends
up as a hollow cylinder. Are there any SCAD scripts for this?
TIA,
Frank
G.Frank Paynter, PhD
OSU ESL Research Scientist (ret)
EM Workbench LLC
614 638-6749 (cell)
Take the hull of a very thin cylinder and a square to form the outer shape.
Subtract a smaller but slightly longer version to make it hollow.
TIA,
Frank
EM Workbench LLC
614 638-6749 (cell)
If you want an option that is more curved, without the triangular faces on
the side you can look at
https://github.com/revarbat/BOSL2/wiki/skin.scad#functionmodule-skin
Examples 11 and 12.
shape. Subtract a smaller but slightly longer version to make it hollow.
ends up as a hollow cylinder. Are there any SCAD scripts for this?
TIA,
Frank
EM Workbench LLC
614 638-6749 (cell)
Well, you might be able to write one based on this AngelCAD script. See
the STL included there for the result.
https://gist.github.com/arnholm/b798d062ab914eb19dffce751ed86427
Carsten Arholm
Yup. 3 minutes work:
dcyl = 40;
dsqu = 40;
wt = 2;
hh = 40;
module cylsqu (ds, dcy, hh)
dh = .5;
hull () {
cylinder (d=ds, h=dh, $fn=4);
translate ([0,0,hh-dh]) cylinder (d=dcy, h=dh, $fn=60);
module hcylsqu (ds, dcy, hh)
difference () {
cylsqu (dsqu+2wt, dcyl+2wt, hh);
translate ([0,0,-0.01]) cylsqu (dsqu, dcyl, hh+.02);
hcylsqu (dsqu, dcyl, hh);
Adapting from "square" as implemented to "rectangle" is left as an
excercise for the reader.
Wow! I'm in love with hull()!! Thanks Roger!!
dcyl = 40;
dsqu = 40;
wt = 2;
hh = 40;
dh = .5;
hull () {
difference () {
TIA,
Frank
EM Workbench LLC
614 638-6749 (cell)
EM Workbench LLC
614 638-6749 (cell)
