Generate OpenSCAD models from AngelScript
CA
Wed, Dec 30, 2015 8:59 PM
I hope I am not breaking any rules by posting this, if you believe I am
just say so and I will go away :-)
In another thread I recently mentioned that I am experimenting with
AngelScript for creating CSG models, using OpenSCAD as the "back end"
via its .csg file format.
(I said I would write about it on my blog when there was anything new,
but due to technical problems I cannot access it at the moment, so
instead this message)
I have done quite a bit the last couple of days and I believe have some
decent results. As an example, this rotate sweep was done without the
upcoming rotate_extrude in OpenSCAD:
http://arnholm.org/software/as_csg/test_sweep_rotate.png
This is the AngelScript CSG code to produce the above:
#include "lib_sweep.as"    // provides general sweep features
#include "lib_degrees.as"  // provides deg/rad conversions
shape@ main_shape()
// specify a rotation sweep of a circle profile
double s_rad  = 100;          // sweep radius
double s_ang  = to_rad(120);  // sweep angle=120deg
uint  s_nseg = 60;            // sweep #segments
double c_rad  = 30;            // circle radius
shape2d@ xsec = circle(c_rad); // sweep profile
// use path_rotate for the sweep
return sweep(path_rotate(xsec,s_rad,s_ang,s_nseg));
void main()
shape@ obj = main_shape();
obj.write_csg(GetOutputFullPath('.csg'));
The sweep function is implemented in AngelScript, and it is general
enough to allow different kind of sweeping, for example a completely
custom one:
http://arnholm.org/software/as_csg/test_sweep_custom.png
shape@ main_shape()
// specify a custom sweep of a circle profile
double s_h    = 100.0;        // sweep height
path_custom path(circle(c_rad),s_h,s_nseg);
return sweep(path);
void main()
Notice "path_custom" instead of "path_rotate" as in the first example.
The sweep function itself is exactly the same in the 2 cases:
solid@ sweep(path_sweep@ path)
uint nseg = path.nseg(); // # of segments
double dp = 1.0/nseg;    // delta parameter
double  p = 0.0;        // start parameter
solid@ end1 = path.slice(p);
solid@[] segments;
for(uint iseg=0; iseg<nseg; iseg++) {
solid@ end2 = path.slice(p+=dp);
segments.push_back(hull3d(end1,end2));
@end1 = @end2;
return union3d(segments);
The point is that the sweep function uses an interface to a path which
can be implemented for various scenarios, of which rotate is only one.
interface path_sweep
uint  nseg();          // number of segments in path
solid@ slice(double p); // thin slice at parameter p [0,1]
In any case, I have put together a Windows installation for anyone who
wants to give it a try. Just download and install. There is no GUI other
than OpenSCAD, "as_csg" is a console program that converts .as files
into OpenSCAD .csg files. A "samples" folder is included, plus a
compiled HTML help file. The samples contain everything to reproduce the
images linked to above.
Here is the download
http://arnholm.org/software/as_csg/AngelScript_CSG_setup_D1.0-00.exe
I guess if you need support, we should not spam this list. Instead you
can send question to me at arnholm@arnholm.org
Kind regards
Hi, I hope I am not breaking any rules by posting this, if you believe I am just say so and I will go away :-) In another thread I recently mentioned that I am experimenting with AngelScript for creating CSG models, using OpenSCAD as the "back end" via its .csg file format. (I said I would write about it on my blog when there was anything new, but due to technical problems I cannot access it at the moment, so instead this message) I have done quite a bit the last couple of days and I believe have some decent results. As an example, this rotate sweep was done without the upcoming rotate_extrude in OpenSCAD: http://arnholm.org/software/as_csg/test_sweep_rotate.png This is the AngelScript CSG code to produce the above: #include "lib_sweep.as" // provides general sweep features #include "lib_degrees.as" // provides deg/rad conversions shape@ main_shape() { // specify a rotation sweep of a circle profile double s_rad = 100; // sweep radius double s_ang = to_rad(120); // sweep angle=120deg uint s_nseg = 60; // sweep #segments double c_rad = 30; // circle radius shape2d@ xsec = circle(c_rad); // sweep profile // use path_rotate for the sweep return sweep(path_rotate(xsec,s_rad,s_ang,s_nseg)); } void main() { shape@ obj = main_shape(); obj.write_csg(GetOutputFullPath('.csg')); } The sweep function is implemented in AngelScript, and it is general enough to allow different kind of sweeping, for example a completely custom one: http://arnholm.org/software/as_csg/test_sweep_custom.png shape@ main_shape() { // specify a custom sweep of a circle profile uint s_nseg = 60; // sweep #segments double s_h = 100.0; // sweep height double c_rad = 30; // circle radius shape2d@ xsec = circle(c_rad); // sweep profile path_custom path(circle(c_rad),s_h,s_nseg); return sweep(path); } void main() { shape@ obj = main_shape(); obj.write_csg(GetOutputFullPath('.csg')); } Notice "path_custom" instead of "path_rotate" as in the first example. The sweep function itself is exactly the same in the 2 cases: solid@ sweep(path_sweep@ path) { uint nseg = path.nseg(); // # of segments double dp = 1.0/nseg; // delta parameter double p = 0.0; // start parameter solid@ end1 = path.slice(p); solid@[] segments; for(uint iseg=0; iseg<nseg; iseg++) { solid@ end2 = path.slice(p+=dp); segments.push_back(hull3d(end1,end2)); @end1 = @end2; } return union3d(segments); } The point is that the sweep function uses an interface to a path which can be implemented for various scenarios, of which rotate is only one. interface path_sweep { uint nseg(); // number of segments in path solid@ slice(double p); // thin slice at parameter p [0,1] } In any case, I have put together a Windows installation for anyone who wants to give it a try. Just download and install. There is no GUI other than OpenSCAD, "as_csg" is a console program that converts .as files into OpenSCAD .csg files. A "samples" folder is included, plus a compiled HTML help file. The samples contain everything to reproduce the images linked to above. Here is the download http://arnholm.org/software/as_csg/AngelScript_CSG_setup_D1.0-00.exe I guess if you need support, we should not spam this list. Instead you can send question to me at arnholm@arnholm.org Kind regards Carsten Arnholm
jpmendes
Wed, Dec 30, 2015 10:38 PM
During file download Avast detected a virus in the and blocked the access to
the page.
jpmendes
View this message in context: http://forum.openscad.org/Generate-OpenSCAD-models-from-AngelScript-tp15379p15380.html
Hi, During file download Avast detected a virus in the and blocked the access to the page. jpmendes -- View this message in context: http://forum.openscad.org/Generate-OpenSCAD-models-from-AngelScript-tp15379p15380.html Sent from the OpenSCAD mailing list archive at Nabble.com.
CA
Wed, Dec 30, 2015 10:46 PM
the page.
Hi, check/replace your antivirus. It is a false alarm.
Kind regards
On 30. des. 2015 23:38, jpmendes wrote: > Hi, > During file download Avast detected a virus in the and blocked the access to > the page. Hi, check/replace your antivirus. It is a false alarm. Kind regards Carsten Arnholm
EN
Ed Nisley
Thu, Dec 31, 2015 12:02 AM
Although that's quite likely, you /are/ distributing a closed source
Windows executable that triggers a Virustotal hit for
HEUR/QVM06.1.Malware.Gen:
https://www.virustotal.com/en/file/1ec1b0f19e7789075651d78778dd78b7fdd74bb314afe4e56add98f17bd194f6/analysis/1451519369/
If I were running Windows, I'd treat that file with the same casual
nonchalance as I would any other lump of glowing-hot radioactive metal.
It might be a false alarm or you might be at the leading edge of Yet
Another Windows botnet; there's no way to tell from outside.
Ed
softsolder.com
On 12/30/2015 05:46 PM, Carsten Arnholm wrote: > Hi, check/replace your antivirus. It is a false alarm. Although that's quite likely, you /are/ distributing a closed source Windows executable that triggers a Virustotal hit for HEUR/QVM06.1.Malware.Gen: https://www.virustotal.com/en/file/1ec1b0f19e7789075651d78778dd78b7fdd74bb314afe4e56add98f17bd194f6/analysis/1451519369/ If I were running Windows, I'd treat that file with the same casual nonchalance as I would any other lump of glowing-hot radioactive metal. It might be a false alarm or you might be at the leading edge of Yet Another Windows botnet; there's no way to tell from outside. -- Ed softsolder.com
CA
Thu, Dec 31, 2015 12:16 AM
Do as you please. The file is clean.
Now I suggest these reports are sent straight to me with some more
actual facts rather than simple accusations. I have checked and there is
nothing.
Kind regards
On 31. des. 2015 01:02, Ed Nisley wrote: > If I were running Windows, I'd treat that file with the same casual > nonchalance as I would any other lump of glowing-hot radioactive metal. Do as you please. The file is clean. Now I suggest these reports are sent straight to me with some more actual facts rather than simple accusations. I have checked and there is nothing. Kind regards Carsten Arnholm
Thu, Dec 31, 2015 12:30 AM
I checked the link to the .exe with virustotal.com. It is clean! The report
shows 0/66.
View this message in context: http://forum.openscad.org/Generate-OpenSCAD-models-from-AngelScript-tp15379p15384.html
I checked the link to the .exe with virustotal.com. It is clean! The report shows 0/66. -- View this message in context: http://forum.openscad.org/Generate-OpenSCAD-models-from-AngelScript-tp15379p15384.html Sent from the OpenSCAD mailing list archive at Nabble.com.
CA
Thu, Dec 31, 2015 12:31 AM
I can explain why it was a false alarm, I let the setup program
(optionally) update the user PATH so it would be easier to run. I have
removed that feature, so people will have to do it manually. There
really isn't anything nefarious, and there never was.
That's all.
On 31. des. 2015 01:02, Ed Nisley wrote: > It might be a false alarm or you might be at the leading edge of Yet > Another Windows botnet; there's no way to tell from outside. I can explain why it was a false alarm, I let the setup program (optionally) update the user PATH so it would be easier to run. I have removed that feature, so people will have to do it manually. There really isn't anything nefarious, and there never was. That's all. Carsten Arnholm
jpmendes
Thu, Dec 31, 2015 12:54 AM
I didn't accused you of anything, I simply reported a fact.
After that I navigate your blog just to try to download the file however but
I couldn't find it.
jpmendes
View this message in context: http://forum.openscad.org/Generate-OpenSCAD-models-from-AngelScript-tp15379p15386.html
Hi, I didn't accused you of anything, I simply reported a fact. After that I navigate your blog just to try to download the file however but I couldn't find it. jpmendes -- View this message in context: http://forum.openscad.org/Generate-OpenSCAD-models-from-AngelScript-tp15379p15386.html Sent from the OpenSCAD mailing list archive at Nabble.com.
CA
Thu, Dec 31, 2015 1:10 AM
I couldn't find it.
No problem, see the other comments.
As reported, I cannot access my blog right now, that is why the link
isn't there. The blog will be updated when the access issue is solved.
See the first message for link to Windows executable.
Here is a Linux binary with the exact same features (yes, virus scan ok)
http://arnholm.org/software/as_csg/angelscript_csg_d1.0-11_kubuntu_1510.tar.gz
Built on Linux Kubuntu 15.10 64bit
It loads a shared object so to run you may have to say
LD_LIBRARY_PATH=.
Kind regards
On 31. des. 2015 01:54, jpmendes wrote: > Hi, > I didn't accused you of anything, I simply reported a fact. > After that I navigate your blog just to try to download the file however but > I couldn't find it. No problem, see the other comments. As reported, I cannot access my blog right now, that is why the link isn't there. The blog will be updated when the access issue is solved. See the first message for link to Windows executable. Here is a Linux binary with the exact same features (yes, virus scan ok) http://arnholm.org/software/as_csg/angelscript_csg_d1.0-11_kubuntu_1510.tar.gz Built on Linux Kubuntu 15.10 64bit It loads a shared object so to run you may have to say LD_LIBRARY_PATH=. Kind regards Carsten Arnholm
CA
Sat, Jan 2, 2016 12:04 AM
Happy new year to all!
I have been adding features to AngelScript CSG today. As others have
mentioned here, spline curves can be very useful. I have hade the same
idea for some time and have now added 2d and 3d spline curves.
A small example creating an OpenSCAD polygon from a 2d spline curve:
http://arnholm.org/software/as_csg/spline_sample.png
Another example is 3d splines. Below is an example of 3 splines turned
into a lofted surface, turned into an OpenSCAD polyhedron by offsetting
the original surface to create a solid with top an bottom:
http://arnholm.org/software/as_csg/polyhedron_sample.png
You can obviously make it as thick or thing as you like, and you can use
as many/long curves as you want to. They should however not intersect
and should be listed in a logical order.
The complete AngelScript CSG code used for generating the polyhedron:
http://arnholm.org/software/as_csg/polyhedron_sample.as
The result can be displayed in OpenSCAD using this .csg file
http://arnholm.org/software/as_csg/polyhedron_sample.csg
These new features will obviously not run in the version released a few
days ago, as this is brand new.
Have fun.
Happy new year to all! I have been adding features to AngelScript CSG today. As others have mentioned here, spline curves can be very useful. I have hade the same idea for some time and have now added 2d and 3d spline curves. A small example creating an OpenSCAD polygon from a 2d spline curve: http://arnholm.org/software/as_csg/spline_sample.png Another example is 3d splines. Below is an example of 3 splines turned into a lofted surface, turned into an OpenSCAD polyhedron by offsetting the original surface to create a solid with top an bottom: http://arnholm.org/software/as_csg/polyhedron_sample.png You can obviously make it as thick or thing as you like, and you can use as many/long curves as you want to. They should however not intersect and should be listed in a logical order. The complete AngelScript CSG code used for generating the polyhedron: http://arnholm.org/software/as_csg/polyhedron_sample.as The result can be displayed in OpenSCAD using this .csg file http://arnholm.org/software/as_csg/polyhedron_sample.csg These new features will obviously not run in the version released a few days ago, as this is brand new. Have fun. Carsten Arnholm
