I've turning my Haskell OpenSCAD model types into instances of Semigroup
and Monoid, but wonder if I've chosen the right "empty" value for monoids.
For those not familiar with it, a monoid is a structure that has an
operation (in this case, union) with an identity object, empty. The idea
is that a union of anything with empty should return that same thing.
Is there a convenient such object in OpenSCAD? I just used "box 0 0 0",
which seems to do the right thing, but it feels like there ought to be a
better option for "I need to return an object here, but don't really want
to."
I'm not sure if there is a correct answer. I'm not sure if the openscad
geometric operations are mathematically consistent for edge cases like
passing the empty model as an argument.
Mathematically, a 3D shape is a set of points, and the empty shape is the
empty set. So you would expect union(X, empty) = X, intersection(X, empty)
= empty.
In principle, i'd expect cube(0) and group(){} to both behave as the empty
shape, but in practice, they give different results when passed to
intersection. cube(0) behaves as expected, while
intersection(){cube(1);group(){}} returns cube(1).
So I guess that "box 0 0 0" is a reasonable choice.
to."
