I have a library that I made and have used for a couple of years and has
worked great. I have a several parameters in it that I used to generate
several different variations of objects to stl files from command line. I
added a couple of new parameters it works great in the OpenSCAD GUI but when
I added those parameters to the command line I get the error message.
Current top level object is empty
This is an example of what I am running from command line. p3 is this new
parameter, if I leave it off the stl file is generated correctly. lib2.scad
uses lib1.scad
openscad.com -o obj1.stl lib2.scad -D p1=3 -D p2=5 -D p3=circle
WARNING: Ignoring unknown variable 'circle', in file lib2.scad, line 460.
WARNING: Ignoring unknown variable 'circle', in file lib1.scad, line 1727.
Current top level object is empty.
The curious thing is that lib2.scad only has 456 lines and lib1.scad only
has 1723 lines.
If I change p3=circle to p4=circle then the stl file is generated just fine
except that lib2 then just uses the default value for p3. Any ideas what
could be the issue here?
I am running Windows 10 Pro and OpenSCAD version 2019.05
has 1723 lines.
fine
Ignore the line numbers, '-D var=val' adds them to the end of the files, in
memory, possibly with an extra CR or LF.
Should it be '-D p3="circle" ' or is 'circle' a variable defined in code?
Thanks, that was close, it got onto the right track though. This is what
worked for me.
'-D p3="circle"'
has 1723 lines.
fine
something stupid...
For Windows just the quote should work as it includes them in the
parameter, but Linux doesn't.
worked for me.
'-D p3="circle"'
only
has 1723 lines.
fine
what
in
something stupid...
