How do I bend?
TL
Thomas Leonard Gertz
Wed, Mar 21, 2018 2:09 PM
Make a shape like a pipebend.
Kerteminde, Danmark
Make a shape like a pipebend. ----- Thomas Leonard Gertz Kerteminde, Danmark -- Sent from: http://forum.openscad.org/
Wed, Mar 21, 2018 2:35 PM
There were many discussions about this here. A starting list may be: http://forum.openscad.org/Curved-Cylinders-td18425.html http://forum.openscad.org/Curved-bent-conical-tubing-td20686.html http://forum.openscad.org/bend-a-pipe-tube-td12503.html
N
NateTG
Wed, Mar 21, 2018 3:59 PM
If you're feeling silly and have OpenSCAD 2015 or more recent, you can do
something like this:
function flatten(list) =  [for (a=list) for (b=a) b];module pipebend (
curve_radius=10,  bend_angle=30,  pipe_od=2,  pipe_id=1.8,  $fn=36  ) {
$fbend=$fn;  $fpipe=$fn;  or=pipe_od/2;  ir=pipe_id/2;
c_step=360/$fpipe;  b_steps=ceil(bend_angle/360*$fbend);
b_step=bend_angle/b_steps;  opoints=        flatten([for
(theta=[0:b_step:bend_angle])            [for (phi=[c_step:c_step:360])
[                  cos(theta) * (curve_radius+orcos(phi)),
sin(theta) * (curve_radius+or
cos(phi)),
orsin(phi)                ]            ]        ])  ;
ofaces=flatten([concat(      [[for (i=[$fpipe-1:-1:0]) i]],
flatten([for (j=[0:b_steps])            [for (i=[$fpipe-1:-1:0])
[j
$fpipe+i,j*$fpipe+(i+1)%$fpipe,(j+1)$fpipe+(i+1)%$fpipe,(j+1)$fpipe+i]
]        ]),      [[for (i=[$fpipe:-1:0]) ($fpipe*(b_steps+1))-i]]  )]);
ipoints=        flatten([for (theta=[-b_step:b_step:bend_angle+b_step])
[for (phi=[c_step:c_step:360])                [                  cos(theta)
  • (curve_radius+ircos(phi)),                  sin(theta) *
    (curve_radius+ir
    cos(phi)),
    irsin(phi)                ]            ]        ])  ;
    ifaces=flatten([concat(      [[for (i=[$fpipe-1:-1:0]) i]],
    flatten([for (j=[0:b_steps+2])            [for (i=[$fpipe-1:-1:0])
    [j
    ]        ]),      [[for (i=[$fpipe:-1:0]) ($fpipe*(b_steps+3))-i]]  )]);
    difference() {      polyhedron(        points=opoints,        faces=ofaces
    );      polyhedron(        points=ipoints,        faces=ifaces      );
    }}pipebend($fn=36,bend_angle=45,curve_radius=5,pipe_od=5,pipe_id=4);
If you're feeling silly and have OpenSCAD 2015 or more recent, you can do something like this: function flatten(list) = [for (a=list) for (b=a) b];module pipebend ( curve_radius=10, bend_angle=30, pipe_od=2, pipe_id=1.8, $fn=36 ) { $fbend=$fn; $fpipe=$fn; or=pipe_od/2; ir=pipe_id/2; c_step=360/$fpipe; b_steps=ceil(bend_angle/360*$fbend); b_step=bend_angle/b_steps; opoints= flatten([for (theta=[0:b_step:bend_angle]) [for (phi=[c_step:c_step:360]) [ cos(theta) * (curve_radius+or*cos(phi)), sin(theta) * (curve_radius+or*cos(phi)), or*sin(phi) ] ] ]) ; ofaces=flatten([concat( [[for (i=[$fpipe-1:-1:0]) i]], flatten([for (j=[0:b_steps]) [for (i=[$fpipe-1:-1:0]) [j*$fpipe+i,j*$fpipe+(i+1)%$fpipe,(j+1)*$fpipe+(i+1)%$fpipe,(j+1)*$fpipe+i] ] ]), [[for (i=[$fpipe:-1:0]) ($fpipe*(b_steps+1))-i]] )]); ipoints= flatten([for (theta=[-b_step:b_step:bend_angle+b_step]) [for (phi=[c_step:c_step:360]) [ cos(theta) * (curve_radius+ir*cos(phi)), sin(theta) * (curve_radius+ir*cos(phi)), ir*sin(phi) ] ] ]) ; ifaces=flatten([concat( [[for (i=[$fpipe-1:-1:0]) i]], flatten([for (j=[0:b_steps+2]) [for (i=[$fpipe-1:-1:0]) [j*$fpipe+i,j*$fpipe+(i+1)%$fpipe,(j+1)*$fpipe+(i+1)%$fpipe,(j+1)*$fpipe+i] ] ]), [[for (i=[$fpipe:-1:0]) ($fpipe*(b_steps+3))-i]] )]); difference() { polyhedron( points=opoints, faces=ofaces ); polyhedron( points=ipoints, faces=ifaces ); }}pipebend($fn=36,bend_angle=45,curve_radius=5,pipe_od=5,pipe_id=4); -- Sent from: http://forum.openscad.org/
Thu, Mar 22, 2018 11:25 AM
From OpenSCAD 2016.XX, there is a more home grown version:
pipebend($fn=36, bend_angle=60, curve_radius=5, pipe_od=5, pipe_id=4);
module pipebend (curve_radius=10,bend_angle=30,pipe_od=2,pipe_id=1.8,$fn=36)
rotate_extrude(angle=bend_angle)
translate([curve_radius, 0])
circle(d=pipe_od);
circle(d=pipe_id);
>From OpenSCAD 2016.XX, there is a more home grown version: pipebend($fn=36, bend_angle=60, curve_radius=5, pipe_od=5, pipe_id=4); module pipebend (curve_radius=10,bend_angle=30,pipe_od=2,pipe_id=1.8,$fn=36) rotate_extrude(angle=bend_angle) translate([curve_radius, 0]) difference() { circle(d=pipe_od); circle(d=pipe_id); } -- Sent from: http://forum.openscad.org/
CC
Chris Camacho
Thu, Mar 22, 2018 11:53 AM
pity there isn't a "native" (built in) path extrude I find it so useful
in blender...
circle(d=pipe_od);
circle(d=pipe_id);
pity there isn't a "native" (built in) path extrude I find it so useful in blender... On 22/03/18 11:25, Parkinbot wrote: > From OpenSCAD 2016.XX, there is a more home grown version: > > pipebend($fn=36, bend_angle=60, curve_radius=5, pipe_od=5, pipe_id=4); > > module pipebend (curve_radius=10,bend_angle=30,pipe_od=2,pipe_id=1.8,$fn=36) > rotate_extrude(angle=bend_angle) > translate([curve_radius, 0]) > difference() > { > circle(d=pipe_od); > circle(d=pipe_id); > } > > > > -- > Sent from: http://forum.openscad.org/ > > _______________________________________________ > OpenSCAD mailing list > Discuss@lists.openscad.org > http://lists.openscad.org/mailman/listinfo/discuss_lists.openscad.org
Thu, Mar 22, 2018 12:42 PM
well there are some sweep libs out there that allow for this kind stuff.
How does blender treat selfintersections?
in blender...
well there are some sweep libs out there that allow for this kind stuff. How does blender treat selfintersections? codifies wrote > pity there isn't a "native" (built in) path extrude I find it so useful > in blender... -- Sent from: http://forum.openscad.org/
CC
Chris Camacho
Thu, Mar 22, 2018 5:38 PM
ignores them, if you're just rendering a soup of tri's - start to
attempt boolean ops on something self intersecting it aint gonna end
well...
in blender...
ignores them, if you're just rendering a soup of tri's - start to attempt boolean ops on something self intersecting it aint gonna end well... On 22/03/18 12:42, Parkinbot wrote: > well there are some sweep libs out there that allow for this kind stuff. > How does blender treat selfintersections? > > > codifies wrote >> pity there isn't a "native" (built in) path extrude I find it so useful >> in blender... > > > > > -- > Sent from: http://forum.openscad.org/ > > _______________________________________________ > OpenSCAD mailing list > Discuss@lists.openscad.org > http://lists.openscad.org/mailman/listinfo/discuss_lists.openscad.org
