On Sun, Nov 21, 2021 at 01:20:29PM +0000, Jaacov Molcho via Discuss wrote:
Date: Sun, 21 Nov 2021 13:20:29 +0000
Subject: [OpenSCAD] My program does not rend (F6)
Please help me to find why the attached program cannot finish rend (F5).
It renders instantly as a preview on my computer (F5).
It takes (quite) a while with F6 ("render" in openscad speak).
It took 2h on my computer. It does warn about it being a valid
3D object.
Things to avoid are: subtracting part where a side matches precisely
So don't do:
difference () {
cube (20);
cube (10);
but
difference () {
cube (20);
translate ([-1,-1,-1]) cube (11);
To debug such things, remove parts of your design to see which part
triggers the behaviour you don't like.
Also, you may want to move the parallel toruses outside of
the for(i=[0:30:360]) loop. They only need to be done once.
3D object.
So don't do:
difference () {
cube (20);
cube (10);
but
difference () {
cube (20);
I was able to reduce the render time from 0:02:43.677 to 0:01:32.065 by
adding a hull() to the torr() module:
module torr(x,y,z)
r=1.5;
hull()
rotate_extrude(convexity=10)
translate([x,y,z])
circle(r);
On Sun, Nov 21, 2021 at 9:56 AM Leonard Martin Struttmann <
3D object.
So don't do:
difference () {
cube (20);
cube (10);
but
difference () {
cube (20);
