Alternate triangulation bug
Ronaldo
Sun, Jan 7, 2018 4:26 PM
As Parkinbot remarked recently in another thread, the alternate triangulation
OpenSCAD builds for non-triangular faces has some bugs. I could isolate a
small example where this comes clear. The code is a simple polyhedron (fully
inside an intercepting cube) with many triangular faces and 2 quadrangular
faces. The list faces0 contains just the triangular faces; faces1 includes
the 2 quadrangular faces and faces2 is the same as faces1 with the
quadrangular faces explicitly subdivided in triangles. The polyhedron
defined with faces2 renders fine. With faces0, it renders with a warning
(non-manifold) because of the 2 missing faces. With faces1, we get an access
violation from CGAL. I checked it with version 2017.08.31 (git c6f3f0d) in a
Windows 7 environment.
verts = [[107.118, 20.796, 3.69206], [101.912, 18.7279, -9.29348], [89.8439,
13.9336, -3.69206], [95.0496, 16.0017, 9.29348], [91.3134, 60.0577,
3.69206], [86.6335, 56.9797, -9.29348], [75.7842, 49.844, -3.69206],
[80.4641, 52.9221, 9.29348], [61.5224, 90.1203, 3.69206], [57.5616, 86.1595,
-9.29348], [48.3794, 76.9773, -3.69206], [52.3402, 80.9381, 9.29348]];
faces0 = [[0, 5, 1], [0, 4, 5], [1, 6, 2], [1, 5, 6], [2, 7, 3], [2, 6, 7],
[3, 4, 0], [3, 7, 4], [4, 9, 5], [4, 8, 9], [5, 10, 6], [5, 9, 10], [6, 11,
7], [6, 10, 11], [7, 8, 4], [7, 11, 8]];
faces1 = concat(faces0, [ [0, 1, 2, 3], [11, 10, 9, 8]] );
faces2 =  concat( faces0, [ [0, 1, 2], [0, 2, 3], [8, 11, 10], [8, 10, 9]]
intersection(){
translate([0,0,-100]) cube(200);
polyhedron( verts, faces1);
//  polyhedron( verts, faces0);
//  polyhedron( verts, faces2);
As Parkinbot remarked recently in another thread, the alternate triangulation OpenSCAD builds for non-triangular faces has some bugs. I could isolate a small example where this comes clear. The code is a simple polyhedron (fully inside an intercepting cube) with many triangular faces and 2 quadrangular faces. The list faces0 contains just the triangular faces; faces1 includes the 2 quadrangular faces and faces2 is the same as faces1 with the quadrangular faces explicitly subdivided in triangles. The polyhedron defined with faces2 renders fine. With faces0, it renders with a warning (non-manifold) because of the 2 missing faces. With faces1, we get an access violation from CGAL. I checked it with version 2017.08.31 (git c6f3f0d) in a Windows 7 environment. verts = [[107.118, 20.796, 3.69206], [101.912, 18.7279, -9.29348], [89.8439, 13.9336, -3.69206], [95.0496, 16.0017, 9.29348], [91.3134, 60.0577, 3.69206], [86.6335, 56.9797, -9.29348], [75.7842, 49.844, -3.69206], [80.4641, 52.9221, 9.29348], [61.5224, 90.1203, 3.69206], [57.5616, 86.1595, -9.29348], [48.3794, 76.9773, -3.69206], [52.3402, 80.9381, 9.29348]]; ; faces0 = [[0, 5, 1], [0, 4, 5], [1, 6, 2], [1, 5, 6], [2, 7, 3], [2, 6, 7], [3, 4, 0], [3, 7, 4], [4, 9, 5], [4, 8, 9], [5, 10, 6], [5, 9, 10], [6, 11, 7], [6, 10, 11], [7, 8, 4], [7, 11, 8]]; faces1 = concat(faces0, [ [0, 1, 2, 3], [11, 10, 9, 8]] ); faces2 = concat( faces0, [ [0, 1, 2], [0, 2, 3], [8, 11, 10], [8, 10, 9]] ); intersection(){ translate([0,0,-100]) cube(200); polyhedron( verts, faces1); // polyhedron( verts, faces0); // polyhedron( verts, faces2); } -- Sent from: http://forum.openscad.org/
Sun, Jan 7, 2018 4:34 PM
I believe this is covered by #2246, which I fixed yesterday: https://github.com/openscad/openscad/issues/2246
FYI: The bug was that we didn’t always catch when CGAL failed at accepting a polygon. I think our own triangulation has always worked.
> On Jan 7, 2018, at 11:26 AM, Ronaldo <rcmpersiano@gmail.com> wrote: > > As Parkinbot remarked recently in another thread, the alternate triangulation > OpenSCAD builds for non-triangular faces has some bugs. I believe this is covered by #2246, which I fixed yesterday: https://github.com/openscad/openscad/issues/2246 FYI: The bug was that we didn’t always catch when CGAL failed at accepting a polygon. I think our own triangulation has always worked. -Marius
Sun, Jan 7, 2018 4:38 PM
I believe this is covered by #2246, which I fixed yesterday:> https://github.com/openscad/openscad/issues/2246
And Windows snapshot builds are updated to include that fix.
On 07.01.2018 17:34, Marius Kintel wrote: > >> On Jan 7, 2018, at 11:26 AM, Ronaldo <rcmpersiano@gmail.com> wrote: >> >> As Parkinbot remarked recently in another thread, the alternate triangulation >> OpenSCAD builds for non-triangular faces has some bugs. > > I believe this is covered by #2246, which I fixed yesterday:> https://github.com/openscad/openscad/issues/2246 > And Windows snapshot builds are updated to include that fix. ciao, Torsten.
Sun, Jan 7, 2018 4:59 PM
I was not aware of #2246. I have checked my codes with the new version and
it seems to work as expected. Thank you.
2018-01-07 14:38 GMT-02:00 Torsten Paul Torsten.Paul@gmx.de:
triangulation
I was not aware of #2246. I have checked my codes with the new version and it seems to work as expected. Thank you. 2018-01-07 14:38 GMT-02:00 Torsten Paul <Torsten.Paul@gmx.de>: > On 07.01.2018 17:34, Marius Kintel wrote: > > > >> On Jan 7, 2018, at 11:26 AM, Ronaldo <rcmpersiano@gmail.com> wrote: > >> > >> As Parkinbot remarked recently in another thread, the alternate > triangulation > >> OpenSCAD builds for non-triangular faces has some bugs. > > > > I believe this is covered by #2246, which I fixed yesterday:> > https://github.com/openscad/openscad/issues/2246 > > > And Windows snapshot builds are updated to include that fix. > > ciao, > Torsten. > > _______________________________________________ > OpenSCAD mailing list > Discuss@lists.openscad.org > http://lists.openscad.org/mailman/listinfo/discuss_lists.openscad.org >
G
Gadgetmind
Sun, Feb 25, 2018 9:42 AM
Does this triangulation handle faces that have concave edges? If so, it's
something that's hard to implement within OpenSCAD "user land" and it would
be good to be able to force polyhedron to do this task. Perhaps a
triangulation option that defaults to false?
This would speed up rendering and make skin () from list-comprehensions far
more useful. I've added my own convex-only triangulation to skin () to
prevent cgal errors and speed things up, but as the logic is in the "back
end" why not enable users to choose to enable it?
Thanks.
Does this triangulation handle faces that have concave edges? If so, it's something that's hard to implement within OpenSCAD "user land" and it would be good to be able to force polyhedron to do this task. Perhaps a triangulation option that defaults to false? This would speed up rendering and make skin () from list-comprehensions far more useful. I've added my own convex-only triangulation to skin () to prevent cgal errors and speed things up, but as the logic is in the "back end" why not enable users to choose to enable it? Thanks. -- Sent from: http://forum.openscad.org/
Sun, Feb 25, 2018 2:10 PM
2018-02-25 6:42 GMT-03:00 Gadgetmind lists@foxhill.co.uk:
Perhaps a
​Yes, it handles non-convex facets and even non-planar ones:
p = [ [10,20,0],[0,0,-10], [10,-10,0], [20,0,0], [30,0,20], [20,20,0]];
polyhedron(points=p,faces=[[1,2,3,4,5,0]]);​
​Note that the triangulation of the facet changes​ with the facet indexing
(circular) order. You have no control on it although it may change
radically the geometry of non-planar facets.
AFAIK, this triangulation is fired automatically when CGAL complaints some
facet is non-planar. I don't think a triangulation option is needed because
the process is very fast. Anyway, to help beginners it should defaults to
true.
2018-02-25 6:42 GMT-03:00 Gadgetmind <lists@foxhill.co.uk>: > Does this triangulation handle faces that have concave edges? > ​... > Perhaps a > triangulation option that defaults to false? > ​Yes, it handles non-convex facets and even non-planar ones: p = [ [10,20,0],[0,0,-10], [10,-10,0], [20,0,0], [30,0,20], [20,20,0]]; polyhedron(points=p,faces=[[1,2,3,4,5,0]]);​ ​Note that the triangulation of the facet changes​ with the facet indexing (circular) order. You have no control on it although it may change radically the geometry of non-planar facets. AFAIK, this triangulation is fired automatically when CGAL complaints some facet is non-planar. I don't think a triangulation option is needed because the process is very fast. Anyway, to help beginners it should defaults to true.
G
Gadgetmind
Sun, Feb 25, 2018 4:43 PM
I used to see the error and the retry a good 15-20 minutes into a
render. Won't cgal restart from scratch?
On 25/02/18 14:10, Ronaldo Persiano wrote: > > AFAIK, this triangulation is fired automatically when CGAL complaints > some facet is non-planar. I don't think a triangulation option is > needed because the process is very fast. I used to see the error and the retry a good 15-20 minutes into a render. Won't cgal restart from scratch?
