Troberg
Sat, Mar 27, 2021 7:00 AM
When you described it as "horrible", I expected something more along the
lines of "a bit awkward", but horrible does not give that solution justice.
This goes beyond horrible, and into pure terror...
nophead wrote
> I gave the equation to Wolfram to solve. It did but answer is horrible:
> https://www.wolframalpha.com/input/?i=solve+sqrt%28w%5E2+-x%5E2%29%2Fx+%3D+%28a-x%29+%2F+%28b+-+sqrt%28w%5E2+-x%5E2%29%29
B
bassklampfe
Sat, Mar 27, 2021 8:04 AM
I took the horror from Wolfram and collected all the common terms and
constants. This is my result
Still looks odd, but it gives me all I want,
The only remaining issues are numeric overflows, when 'w' gets near 'a' ¹).
But I can live with this, because in my use case 'w' is almost always
something about 0.1a … 0.3a.
Thank you all for your support, regards.
¹) I assume, this is because OpenSCAD is doing arithmetic in float. Using
the same formula in lua with double arithmetic let me come much closer to
'a' without numerical overflows
PS: I had to invent
because OpenSCAD coult not evaluate cubic root of negative values ( -8^(1/3)
:= -2)
something about 0.1*a … 0.3*a.
PS: I had to invent
:= -2)
Sat, Mar 27, 2021 10:32 PM
As adrianv already stated, finding and figuring out the algebraic solution is
much more difficult than finding the solution in an iterative fashion.
A short analysis of the problem shows that the points [x,0] and [0, y] need
to have the same distance from the middle point M=[a/2,b/2] and w from each
other. This means we can set up two equations and have two unknowns. However
it is not clear, whether there exists some algebraic solution in a closed
form, which has already been discussed.
Therefore, we better employ some iteration scheme. We choose some interval
[x1 ... x2] that surely contains the solution x and test the middle point
(x1+x2)/2. Depending on the sign of the difference delta of the distances
from M, we recursively continue with the upper respectivley lower half of
the interval, until delta < eps holds. For testing purposes, I added some
max iteration depth test, which shows that the code needs 26 iteration steps
for eps=1E-7
a = 13;
b = 15;
w = 9.16399;
echo(solveit());
function solveit(M=[a/2,b/2],w=w, x1=a, x2=0, eps=1E-7, n = 100) =
let(x = (x1+x2)/2) // equation 1
let(y = sqrt(ww-xx)) // equation 2
let(delta = norm(M-[x,0])- norm(M-[0,y])) // test condition
abs(delta) < eps || n<=0 ? [x, y, n]:
delta>0? solveit(M, w, x1, x, n=n-1):
solveit(M, w, x, x2, n=n-1);
for eps=1E-7
a = 13;
b = 15;
w = 9.16399;
echo(solveit());
let(y = sqrt(w*w-x*x)) // equation 2
jsc
Sun, Mar 28, 2021 9:53 PM
I did a little googling and found this discussion:
https://www.physicsforums.com/threads/rectangle-inscribed-in-another-rectangle-solutions-for-all-cases.508715/
The first attachment is a pretty rigorous write up
(https://www.physicsforums.com/attachments/inscribedrectangles-discussion-txt.36642/).
Case 3 is the one analogous to the given problem.
For his analytical solution, he derives nearly the same quartic as NateTG
came up with (except instead of "2 w a x", it's "2 w^2 a x"), which turns
into the same result as the mess from Wolfram (and now that I look at it
again, the same as adrianv used for the BOSL root finder).
He also details an algorithm for determining the inscribed rectangle angle
by finding the inflection point of a function of the angle.
I thought it was an interesting explanation and covered all of the points
raised in this thread.
Sun, Mar 28, 2021 10:41 PM
I think the Wolfram mess is only because it produces the overall formula in
one step and with some constant folding. Quartics are solved by making
various substitutions of variables to simplify the problem and if you code
it the same way the expressions are a lot simpler. Quadratics can be solved
by completing the square and when you fully expand it you get the
familiar formula that is not too complex but as soon as you go to cubics
the fully expanded formula starts to get out of hand.
A good explanation here: https://www.youtube.com/watch?v=N-KXStupwsc
> The first attachment is a pretty rigorous write up (
> at Nabble.com.
Sun, Mar 28, 2021 11:45 PM
Just to be clear, quartics are actually solved using an iterative method
such as the bisection method posted by Parkinbot or Aberth's method (BOSL2),
or perhaps a Newton iteration. Same with cubics. The quartic and cubic
formula are not generally used and are probably going to lead to stability
problems in general, even if you can implement them in a tidier way as a
series of steps with reductions. And the above mentioned methods have the
advantage of working on any polynomial (Aberth) or even any equation for the
other two, so your labors are better repaid and you have less to debug. The
above methods are also all simpler than the cubic and quartic formulas, or
at least no more complex.
The only time it makes sense to use the cubic or quartic formulas is if for
some reason you want a symbolic answer, like you want to know that it's
really the cube root of 73 + the cube root of 42 or whatever, instead of
having a numerical value.
(And I mean that the symbolic answer is the end point...not that you're then
going to use it to compute a numerical one.)
in
solved
angle
at Nabble.com.
Just to be clear, quartics are *actually* solved using an iterative method
some reason you want a *symbolic* answer, like you want to know that it's
> in
> solved
> jsc@.mit
>> angle
>> at Nabble.com.
>> To unsubscribe send an email to
> discuss-leave@.openscad
Mon, Mar 29, 2021 9:04 AM
Well for this problem the refactored Wolfram code posted by the OP gets the
right answer for x such that when back substituted gives -1.81899e-12, so
pretty close without any iteration.
(BOSL2), or perhaps a Newton iteration. Same with cubics. The quartic and
cubic formula are not generally used and are probably going to lead to
stability problems in general, even if you can implement them in a tidier
way as a series of steps with reductions. And the above mentioned methods
have the advantage of working on any polynomial (Aberth) or even any
equation for the other two, so your labors are better repaid and you have
less to debug. The above methods are also all simpler than the cubic and
quartic formulas, or at least no more complex.
for some reason you want a symbolic answer, like you want to know that
it's really the cube root of 73 + the cube root of 42 or whatever, instead
of having a numerical value.
then going to use it to compute a numerical one.)
in
solved
On Sun, 28 Mar 2021 at 22:53, jsc <[hidden email]
at Nabble.com.
> for some reason you want a *symbolic* answer, like you want to know that
> in
> solved
> NateTG
> turns
> angle
> points
> > at Nabble.com.
> <http:///user/SendEmail.jtp?type=email&email=discuss-leave%40.openscad>
> at Nabble.com.
Mon, Mar 29, 2021 10:24 AM
An unstable algorithm sometimes produces bad answers, not always.
Why are you concerned about avoiding iterations? Also for your approach to
be free of iteration you need to be using a square root algorithm, for
example, that does not involve iteration. The methods I know use for
computing square root are iterative.
method
and
methods
instead
in
code
solved
at Nabble.com.
at Nabble.com.
An unstable algorithm *sometimes* produces bad answers, not always.
> the
> avm4@
>> method
>> and
>> methods
>> instead
>> in
>> code
>> solved
>> NateTG
>> turns
>> it
>> angle
>> points
>> > at Nabble.com.
>> at Nabble.com.
Mon, Mar 29, 2021 11:56 AM
I was talking about iteration at the OpenSCAD level, not the hardware
level. Perhaps it is slower than 9 inline expressions. But, yes, I can see
raising terms to such high powers and then subtracting them might lead to
numerical instability. The cube roots and square roots are probably what
saves it.
to be free of iteration you need to be using a square root algorithm, for
On Mon, 29 Mar 2021 at 00:46, adrianv <[hidden email]
in
at Nabble.com.
at Nabble.com.
saves it.
> the
> method
> and
> tidier
> methods
> have
> and
> instead
> > in
> code
> > solved
> > NateTG
> > turns
> it
> > angle
> > points
> > > at Nabble.com.
> <http:///user/SendEmail.jtp?type=email&email=discuss-leave%40.openscad%3E>
> > at Nabble.com.
> at Nabble.com.
Doug Moen
Mon, Mar 29, 2021 10:29 PM
Division also uses an iterative algorithm. Intel processors have a SQRT operation, which is roughly as expensive as division. OpenSCAD should be using the SQRT machine code operation if it is linked with glibc on linux.
Why are you concerned about avoiding iterations? Also for your approach to be free of iteration you need to be using a square root algorithm, for example, that does not involve iteration. The methods I know use for computing square root are iterative.
in
solved
http:///user/SendEmail.jtp?type=email&email=jsc%40.mit http://user/SendEmail.jtp?type=email&email=jsc%40.mit%3E> wrote:
>> On Mon, 29 Mar 2021 at 00:46, adrianv <[hidden email] <https://www.fastmail.com/user/SendEmail.jtp?type=email&email=avm4%40>> wrote:
>> > in
>> > solved
>> > <http:///user/SendEmail.jtp?type=email&email=jsc%40.mit> <http://user/SendEmail.jtp?type=email&email=jsc%40.mit%3E>> wrote:
>> > NateTG
>> > turns
>> > angle
>> > points
>> > > Sent from the OpenSCAD mailing list archive <http://forum.openscad.org/> <http://forum.openscad.org/%3E>
>> > > at Nabble.com.
>> > <http:///user/SendEmail.jtp?type=email&email=discuss-leave%40.openscad> <http://user/SendEmail.jtp?type=email&email=discuss-leave%40.openscad%3E>
>> > at Nabble.com.
>> > To unsubscribe send an email to [hidden email] <https://www.fastmail.com/user/SendEmail.jtp?type=email&email=discuss-leave%40.openscad>
> Sent from the OpenSCAD mailing list archive <http://forum.openscad.org/> at Nabble.com.
> To unsubscribe send an email to discuss-leave@lists.openscad.org <mailto:discuss-leave%40lists.openscad.org>
