NS
Nathan Sokalski
Sat, Sep 2, 2023 5:22 AM
I have a function that generates & returns an array of points, which I use in a module. During preview, this works & displays as expected, but when rendering the module is not displayed. It does not give an error, it simply does not display. If I use a literal array of points rather than generating them everything works fine in both preview & render. I have confirmed that the function returns what I expect using echo. Why does the literal always work but the function only works during preview?
Nathan Sokalski
Nathan Sokalski
njsokalski@hotmail.com<mailto:njsokalski@hotmail.com>
Sat, Sep 2, 2023 5:30 AM
Can you please share how did you generate the list of points.
On Sat, 2 Sept, 2023, 10:52 am Nathan Sokalski, njsokalski@hotmail.com
Nathan Sokalski
On Sat, 2 Sept, 2023, 10:52 am Nathan Sokalski, <njsokalski@hotmail.com>
> Nathan Sokalski
NS
Nathan Sokalski
Sat, Sep 2, 2023 5:41 AM
The exact code of my function is as follows:
function GetBaseFramePerimeter()=
let(xchange=hexsidesizecos(30),ychange=hexsidesizesin(30))
AlignPoints(points=RelativeToAbsolutePoints([[framelinksize.x,hexsidesize],[0,(framelinksize.y-hexsidesize)/2],[-framelinksize.x,0],[0,-framelinksize.y],[framelinksize.x,0],[0,(framelinksize.y-hexsidesize)/2],[211,0],[53cos(60),53sin(60)],[-xchange,ychange],[-xchange,-ychange],[-xchange,ychange],[-xchange,-ychange],[-xchange,ychange]]),alignto=[0,0]);
However, something that I just tried that seems to solve the problem was removing render() from the code. I don't know why this would affect it, but I guess it's a temporary solution.
Nathan Sokalski
Sent: Saturday, September 2, 2023 1:30 AM
Subject: [OpenSCAD] Re: Generated Points Working During Preview But Not During Render
On Sat, 2 Sept, 2023, 10:52 am Nathan Sokalski, <njsokalski@hotmail.commailto:njsokalski@hotmail.com> wrote:
Nathan Sokalski
let(xchange=hexsidesize*cos(30),ychange=hexsidesize*sin(30))
AlignPoints(points=RelativeToAbsolutePoints([[framelinksize.x,hexsidesize],[0,(framelinksize.y-hexsidesize)/2],[-framelinksize.x,0],[0,-framelinksize.y],[framelinksize.x,0],[0,(framelinksize.y-hexsidesize)/2],[211,0],[53*cos(60),53*sin(60)],[-xchange,ychange],[-xchange,-ychange],[-xchange,ychange],[-xchange,-ychange],[-xchange,ychange]]),alignto=[0,0]);
Nathan Sokalski
________________________________
To: OpenSCAD general discussion Mailing-list <discuss@lists.openscad.org>
On Sat, 2 Sept, 2023, 10:52 am Nathan Sokalski, <njsokalski@hotmail.com<mailto:njsokalski@hotmail.com>> wrote:
Nathan Sokalski
To unsubscribe send an email to discuss-leave@lists.openscad.org<mailto:discuss-leave@lists.openscad.org>
NS
Nathan Sokalski
Sat, Sep 2, 2023 5:45 AM
Just in case anybody is wondering, all the variables & functions in this function are from other code that I have written, but they are obviously not the problem since this returns the desired/expected values
Nathan Sokalski
Sent: Saturday, September 2, 2023 1:41 AM
Nathan Sokalski
Nathan Sokalski
Nathan Sokalski
Nathan Sokalski
Nathan Sokalski
Sat, Sep 2, 2023 5:54 AM
It's difficult for me to understand this.
Anyway you have already figured out the issue it seems
On Sat, 2 Sept 2023 at 11:11, Nathan Sokalski njsokalski@hotmail.com
During Render
Nathan Sokalski
On Sat, 2 Sept 2023 at 11:11, Nathan Sokalski <njsokalski@hotmail.com>
> Nathan Sokalski
> *From:* Sanjeev Prabhakar <sprabhakar2006@gmail.com>
> *Sent:* Saturday, September 2, 2023 1:30 AM
> *To:* OpenSCAD general discussion Mailing-list <discuss@lists.openscad.org
> *Subject:* [OpenSCAD] Re: Generated Points Working During Preview But Not
> During Render
> Nathan Sokalski
Sat, Sep 2, 2023 12:38 PM
I don't think he has figured out the problem, actually. If you want help
with your problem you need to post COMPLETE code that others can run.
His problem is that he's created an invalid object that CGAL doesn't like.
That means it can preview but not render. Putting an explicit render()
invoked CGAL and exposed the behavior. If he never wants to render then he
can continue onward, but if he wants more than a preview image, he needs to
figure out why his object is invalid and fix it. Nobody can tell this with
just a code fragment.
On Sat, Sep 2, 2023 at 1:55 AM Sanjeev Prabhakar sprabhakar2006@gmail.com
Not During Render
Nathan Sokalski
On Sat, Sep 2, 2023 at 1:55 AM Sanjeev Prabhakar <sprabhakar2006@gmail.com>
>> Nathan Sokalski
>> Not During Render
>> Nathan Sokalski
Mon, Sep 4, 2023 8:58 PM
like. That means it can preview but not render.
Yeah. One of the most common problem cases is that you've created (or
imported via STL) a polyhedron that is in some subtle way flawed.
Preview works fine. Render of just that polyhedron works fine (because
it doesn't deeply involve CGAL). It's only when you try to combine that
polyhedron with something else - even something as simple as a cube that
doesn't touch it - that the flaws start to cause problems.
