                    In your arc drawing code, ang2 is very close to zero in one case, and close
to 360 in the other case.   You should somehow explicitly resolve the
ambiguity about how to draw the arc between two points, as there are always
two options.
On Thu, Jan 13, 2022 at 10:37 PM gadgetChris via Discuss <
Cc:
Bcc:
Date: Thu, 13 Jan 2022 22:37:16 -0500
Subject: [OpenSCAD] Re: Tangential arc between two circles
I have this weird behaviour of flipping the angles.
I've not yet been able to pin-point where the issue is?
rt=74.711;  // radius tangent
rt=74.712;  // radius tangent
// https://www.frassek.org/2d-mathe/kreise-verbinden/
// $t = animation step
$fn=40;
cx1=0; // circle 1
cy1=0;
cr1=20;
//cx2=5+sin($t*360)*17; // circle 2
cx2=50;
cy2=50;
cr2=2.5;
// do we have valid values
d12=sqrt( (cx1-cx2)^2+(cy1-cy2)^2 ); // distance between circles
echo("distance between circles=",d12);
testR=(cr1+cr2+d12)/2; //
assert(rt > testR, concat("Tangent radius not big enough! Needs to be
larger than:",str(testR)));
function rm(theta)=[[cos(theta),sin(theta)],[-sin(theta),cos(theta)]];
function ang(x,y)=
x>=0&&y>=0?atan(y/x):x<0&&y>=0?180-abs(atan(y/x)):x<0&&y<0?180+abs(atan(y/x)):360-abs(atan(y/x));
function
cir(r,p=[0,0],s=50)=[for(i=[0:360/s:360-360/s])[p.x+rcos(i),p.y+rsin(i)]];
module p_line(path,size=.5){
for(i=[0:len(path)-1])
let(p0=path[i],p1=i<len(path)-1?path[i+1]:path[0])
 hull(){
 translate(p0)circle(size/2);
 translate(p1)circle(size/2);}}
module p_lineo(path,size=.5){
for(i=[0:len(path)-2])
let(p0=path[i],p1=path[i+1])
 hull(){
function
arc(radius,ang1=0,ang2=355,cp=[0,0],s=20)=[for(i=[ang1:(ang2-ang1)/s:ang2])cp+[radiuscos(i),radiussin(i)]];
function 2cir_tarc(r1,r2,cp1,cp2,r)=
let(
l1=norm(cp2-cp1),
l2=r-r1,
l3=r-r2,
x=(l2^2-l3^2+l1^2)/(2l1),
h=sqrt(l2^2-x^2),
v1=cp2-cp1,u1=v1/norm(v1),
p0=cp1+u1x,
cp3=p0-u1hrm(90),
v2=cp2-cp3,u2=v2/norm(v2),
v3=cp1-cp3,u3=v3/norm(v3),
ang1=ang(u2.x,u2.y),
ang2=ang(u3.x,u3.y)
arc(r,ang1,ang2,cp3);
arc=2cir_tarc(cr1,cr2,[cx1,cy1],[cx2,cy2],rt);
arc2=2cir_tarc(cr2,cr1,[cx2,cy2],[cx1,cy1],rt);
color("cyan") p_lineo(arc,.2);
color("green") p_lineo(arc2,.2);
p_line(cir(cr1,[cx1,cy1]),.2);
p_line(cir(cr2,[cx2,cy2]),.2);
On Sat, Jan 8, 2022 at 6:26 AM MichaelAtOz oz.at.michael@gmail.com
I am using openSCAD 2021.09.12 and it not showing any errors or
warnings
Something to check against a recent snapshot.
From: Sanjeev Prabhakar [mailto:sprabhakar2006@gmail.com]
Sent: Sat, 8 Jan 2022 20:51
Ah, just downloaded the Jan 2021 version
Remove true from line number 9,10,17,18
Then there is no error
On Sat, 8 Jan 2022, 14:58 MichaelAtOz, oz.at.michael@gmail.com wrote:
Hmmm, don't know why.
Sent: Sat, 8 Jan 2022 18:20
Thanks for your comments
I am using openSCAD 2021.09.12 and it not showing any errors or warnings
On Sat, 8 Jan 2022, 12:15 MichaelAtOz, oz.at.michael@gmail.com wrote:
Note that circle() does not take a Boolean, in 4 places. That now
generates warnings.
Also an extra comma
From: gadgetChris via Discuss discuss@lists.openscad.org
Cc: gadgetChris hobbies@klomp.ca
Bcc:
