HW
Harvey white
Fri, Dec 13, 2024 1:19 AM
I've done front panels by printing (inkjet or color laser) on a
transparency in reverse. Flipping it over lets you read through the
transparency, which provides protection for the printing.
You can also do a fake silk screen for a PC board with the same mechanism.
Harvey
On 12/12/2024 6:30 PM, Terry via Discuss wrote:
On Thu, 12 Dec 2024 13:18:50 -0800, you wrote:
BACKGROUND:
For a Christmas gift I'm making an electronics project in a neat
enclosure. It includes the facility for choosing one of 24 options. That
currently uses a 12 way rotary switch, requiring wires to 12 inputs of a
micro controller unit (MCU). That works. But I want to reduce the size
of the MCU, the wiring, and the case. I've therefore redesigned it so
that the initial choice is instead made by turning the knob of a
potentiometer to one of 24 angles. That works too. But I'm seeking help
on (at least!) labelling the knob positions please.
I could relearn some Inkscape or perhaps use my familiar PaintShop Pro.
And stick the paper or card result around the knob. But I’m considering
OpenSCAD, partly because that will let me play with my Ender 3 Pro 3D
printer. But it would also deliver a finished and labelled knob as the
end result. And the basis for other future projects (my hobby).
Veering off topic:
I'm surprised you aren't using a rotary encoder if you are worried about
the number of wires
https://www.digikey.com/en/products/detail/bourns-inc/PEC11R-4220F-S0024/4499660
- $2.20 something like this gives you clear clockwise/counter clockwise
signals, so as long as the device has power it can just add or subtract to
get to the desired setting.
A common technique is to print the numbers, mirror image, onto
transparency, so when the transparent plastic is cut to size and attached
it protects the ink on the underside.
Thanks David. Not sure I see the practicality of a rotary encoder. What
would be its trigger? Magnetic? Optical (e.g IR) ? Reflective? And the
mechanics of all that? And how would the position be displayed? Plus
extra code (see my reply to Gene re the aTTiny85.)
But I'm very interested in your other suggestion. Could you say a bit
more about it please? Are you talking about printing (mirrored) onto a
transparent sheet with an inkjet printer? Special non-smudge?
Terry
Harvey
>> On Thu, Dec 12, 2024 at 10:55?AM Terry via Discuss <
>> discuss@lists.openscad.org> wrote:
>>> BACKGROUND:
>> Veering off topic:
>> the number of wires
> Terry
DV
david vanhorn
Fri, Dec 13, 2024 3:20 AM
A rotary encoder would give you as many positions as you like, and clicks.
You'd need a display to show what position it's in.
On Thu, Dec 12, 2024 at 6:19 PM Harvey white via Discuss <
Harvey
BACKGROUND:
Veering off topic:
the number of wires
Terry
K1FZY (WA4TPW) SK 9/29/37-4/13/15
> Harvey
> >>> BACKGROUND:
> That
> a
> >> Veering off topic:
> >> the number of wires
> to
> attached
> > Terry
Fri, Dec 13, 2024 10:44 AM
I've used push button BCD switches in various projects. Not sure what
the Amazon quality is like search for 'bcd switches'. this site has an
example of their use https://www.clounce.com/electronics/bcd-switch .
Simple to install, has the 'display ' built in.
mechanism.
Harvey
BACKGROUND:
Veering off topic:
> mechanism.
> Harvey
> >>> BACKGROUND:
> options. That
> inputs of a
> the size
> redesigned it so
> seeking help
> PaintShop Pro.
> considering
> Pro 3D
> knob as the
> >> Veering off topic:
> worried about
> >> the number of wires
> clockwise
> subtract to
> and attached
> encoder. What
> And the
> a bit
> onto a
> > Terry
Terry
Fri, Dec 13, 2024 11:58 AM
Thanks Ray, very useful ideas for future projects.
My pots are all legacy stuff, mostly already used and with short
remaining spindle lengths. The case for the project under discussion is
already prepared, holes included, and space within is small. The MP3
method I described for reliably choosing one of 24 pot positions looks
satisfactory so far. And if I stick on a flat paper dial like the one
shown below, derived from Jordan's code, I may even be able to dispense
with that complication, fun though it is. Viewed on my PC screen at
about 35 mm in diameter it's readable. I'll shortly inkjet print it.
After earlier feedback I'm hesitating about trying option 2 (labels on
the knob), although still looking for an excuse to power up my 3D
printer. ;-)
https://www.dropbox.com/scl/fi/v1twya85yv7426i7usy1s/Dial-Flat-3.jpg?rlkey=f1rljspbmjq3cnl20r0cpmsoj&raw=1
On Fri, 13 Dec 2024 00:41:19 +0000, you wrote:
If you have a surface mounted pot, then mount it on a pcb, and a hole in
the case for the shaft and knob on the outside. You can fit a disc on
the shaft, below the front panel, with the printed numbers showing
through a hole in the panel, you can make the disc large enough to see
the numbers., add detents if you wish. Cover the front panel with a
piece of acrylic sheet.
if you haven't got a surface mounted pot, then print or fabricate a
bracket/whatever, to hold the pot below the front panel.
But you can get for not many pennies, small OLED displays, and software
to run them on arduino/whatever.
On 12/12/2024 21:45, Terry via Discuss wrote:
On Thu, 12 Dec 2024 19:54:58 +0000, you wrote:
You could make a potentiometer click by printing a wheel with 24 detents
and pushing a small ball against it with a spring. You could have that
mounted behind the panel as most pots have long shafts that you cut to
length.
Thanks, that's a clever idea! I may well try it for a future project
that's dependent on a pot's position. But for this particular one I've
used another novel solution. The position reached within a set time
after power up is accepted, and spoken by an MP3 player. It's working
quite well on test. So I'm now hoping to use Jordan's labels (on either
the case or knob perimeter), PLUS a 1 sec playback of that position.##
I'm not sure mounting the detent inside would be possible. Apart
from space restrictions, how would the pot spindle then be easily
secured to the case with its thread and bolt? On top seems the way to
go.
Which would be way OTT; only possible because the project ('Sleep
Fader') has the main function of playing the choice of 24 MP3s.
P.S: My original 12W rotary switch approach had no labels, relying on
counting from position 1 (plus a supplementary toggle switch to get
choices 13 to 24.)
printer. ;-)
>>> length.
>> I'm not sure mounting the detent **inside** would be possible. Apart
>> go.
>> ## Which would be way OTT; only possible because the project ('Sleep
>> Fader') has the main function of **playing** the choice of 24 MP3s.
>> choices 13 to 24.)
Terry
Fri, Dec 13, 2024 12:59 PM
Thanks Harvey, similar suggestion from David which I'm following up.
At a quick look, so many product choices. A few in my screenshot. Some
apparently don't work with certain printer brands. What's your inkjet
printer brand and which sheets do you use?
Terry
Harvey
Terry
>Harvey
HW
Harvey white
Fri, Dec 13, 2024 1:23 PM
I used both HP and Canon (I think), and got tired of replacing 24 dollar
color cartridges after a few months of non-use. I switched over to a
color laser (Canon) and haven't looked back. The transparencies I used
were the generic variety for the most part, or the brand of the printer
I used.
Not too helpful, but note that the ones for color laser and color inkjet
are not the same.
Harvey
Terry
Harvey
I used.
are not the same.
Harvey
> Terry
>> Harvey
