redefining a module()
Fri, Jun 12, 2026 1:18 AM
On 6/11/2026 5:36 PM, Revar Desmera wrote:
I HAVE tried suggesting ways to fix the broken use<> in a way that would provide namespaces, though.
 lib = use<lib.scad>;
 foo = lib.func(blah);
Yes, my ideas are along much the same line, though I don't think it
needs magic syntax - use() would just be a function that returned an object.
I never really tried to implement it, but the design in my head still
had a gap for determining which variables/modules/functions in the used
file were included in the object.  It could be "all of them", but that
isn't always the right answer.  And of course since it would squash
module, function, and variable namespaces into one object-member
namespace, that would be a bump in the road for adopting it for existing
libraries.  And it would depend on module references, which are still in
limbo with PR#4478.
On 6/11/2026 5:36 PM, Revar Desmera wrote: > I HAVE tried suggesting ways to fix the broken use<> in a way that would provide namespaces, though. > > lib = use<lib.scad>; > foo = lib.func(blah); Yes, my ideas are along much the same line, though I don't think it needs magic syntax - use() would just be a function that returned an object. I never really tried to implement it, but the design in my head still had a gap for determining which variables/modules/functions in the used file were included in the object.  It could be "all of them", but that isn't always the right answer.  And of course since it would squash module, function, and variable namespaces into one object-member namespace, that would be a bump in the road for adopting it for existing libraries.  And it would depend on module references, which are still in limbo with PR#4478.
Fri, Jun 12, 2026 1:39 AM
On Jun 11, 2026, at 6:18 PM, Jordan Brown openscad@jordan.maileater.net wrote:
lib = use("lib.scad"); seems reasonable to me.  But it really needs module literals to be useful.
Excluding variables in use<> made it unusable (heh) for a library with constants.  Export em all.  If you desperately must provide gatekeeper support, add a keyword to hide elements.  private foobar.
The libraries will cope and be redesigned around the new paradigm.  BOSL3 would probably add a f_ prefix to functions that share names with modules.  If this had been part of the language ten years ago, we'd already be using it.
  • Revar
> On Jun 11, 2026, at 6:18 PM, Jordan Brown <openscad@jordan.maileater.net> wrote: > > On 6/11/2026 5:36 PM, Revar Desmera wrote: >> I HAVE tried suggesting ways to fix the broken use<> in a way that would provide namespaces, though. >> >> lib = use<lib.scad>; >> foo = lib.func(blah); > > Yes, my ideas are along much the same line, though I don't think it needs magic syntax - use() would just be a function that returned an object. lib = use("lib.scad"); seems reasonable to me. But it really needs module literals to be useful. > I never really tried to implement it, but the design in my head still had a gap for determining which variables/modules/functions in the used file were included in the object. It could be "all of them", but that isn't always the right answer. Excluding variables in use<> made it unusable (heh) for a library with constants. Export em all. If you desperately must provide gatekeeper support, add a keyword to hide elements. `private foobar`. > And of course since it would squash module, function, and variable namespaces into one object-member namespace, that would be a bump in the road for adopting it for existing libraries. And it would depend on module references, which are still in limbo with PR#4478. The libraries will cope and be redesigned around the new paradigm. BOSL3 would probably add a `f_` prefix to functions that share names with modules. If this had been part of the language ten years ago, we'd already be using it. - Revar
CC
Cory Cross
Fri, Jun 12, 2026 5:11 AM
On June 11, 2026 6:18:16 PM PDT, Jordan Brown via Discuss discuss@lists.openscad.org wrote:
limbo with PR#4478.
That's why I implemented namespace syntax, so variables, functions, and modules retained their separate namespaces. And allows BOSL2 to be source-compatible whether used as namespace or not. No interest in meeting it though.
On June 11, 2026 6:18:16 PM PDT, Jordan Brown via Discuss <discuss@lists.openscad.org> wrote: >I never really tried to implement it, but the design in my head still >had a gap for determining which variables/modules/functions in the used >file were included in the object.  It could be "all of them", but that >isn't always the right answer.  And of course since it would squash >module, function, and variable namespaces into one object-member >namespace, that would be a bump in the road for adopting it for existing >libraries.  And it would depend on module references, which are still in >limbo with PR#4478. That's why I implemented namespace syntax, so variables, functions, and modules retained their separate namespaces. And allows BOSL2 to be source-compatible whether used as namespace or not. No interest in meeting it though.
