OpenSCAD working folder
Ronaldo
Tue, Jul 26, 2016 6:58 PM
At least in Windows environment, OpenSCAD system creates a folder in user
Documents area, naming it OpenSCAD with a backup folder in it. That seems to
be an great place to store all our personal OpenSCAD projects. However, when
we create a new file and try to save it, the system drive us to the
installation folder of OpenSCAD. I don't believe this is a good choice
mainly in a multi-user environment. Is there any hidden good reason for
that? Or did I miss some configuration option?
View this message in context: http://forum.openscad.org/OpenSCAD-working-folder-tp17987.html
At least in Windows environment, OpenSCAD system creates a folder in user Documents area, naming it OpenSCAD with a backup folder in it. That seems to be an great place to store all our personal OpenSCAD projects. However, when we create a new file and try to save it, the system drive us to the installation folder of OpenSCAD. I don't believe this is a good choice mainly in a multi-user environment. Is there any hidden good reason for that? Or did I miss some configuration option? -- View this message in context: http://forum.openscad.org/OpenSCAD-working-folder-tp17987.html Sent from the OpenSCAD mailing list archive at Nabble.com.
Thu, Aug 4, 2016 2:19 AM
I'm presuming due to the multi platform nature OpenSCAD does not choose a
location?
If you installed via the installer.exe edit the shortcut in the start menu,
set your default directory/folder in 'Start in'.
I generally install via the zip file and create a shortcut in the start menu
as above.
View this message in context: http://forum.openscad.org/OpenSCAD-working-folder-tp17987p18029.html
I'm presuming due to the multi platform nature OpenSCAD does not choose a location? If you installed via the installer.exe edit the shortcut in the start menu, set your default directory/folder in 'Start in'. I generally install via the zip file and create a shortcut in the start menu as above. ----- Admin - PM me if you need anything, or if I've done something stupid... Unless specifically shown otherwise above, my contribution is in the Public Domain; to the extent possible under law, I have waived all copyright and related or neighbouring rights to this work. Obviously inclusion of works of previous authors is not included in the above. The TPP is no simple “trade agreement.” Fight it! http://www.ourfairdeal.org/ time is running out! -- View this message in context: http://forum.openscad.org/OpenSCAD-working-folder-tp17987p18029.html Sent from the OpenSCAD mailing list archive at Nabble.com.
Thu, Aug 4, 2016 9:12 PM
Nice and perfect, Michael. Thank you.
2016-08-03 23:19 GMT-03:00 MichaelAtOz oz.at.michael@gmail.com:
location?
menu
as above.
Nice and perfect, Michael. Thank you. 2016-08-03 23:19 GMT-03:00 MichaelAtOz <oz.at.michael@gmail.com>: > I'm presuming due to the multi platform nature OpenSCAD does not choose a > location? > > If you installed via the installer.exe edit the shortcut in the start menu, > set your default directory/folder in 'Start in'. > > I generally install via the zip file and create a shortcut in the start > menu > as above. > > > > > ----- > Admin - PM me if you need anything, or if I've done something stupid... > > Unless specifically shown otherwise above, my contribution is in the > Public Domain; to the extent possible under law, I have waived all > copyright and related or neighbouring rights to this work. Obviously > inclusion of works of previous authors is not included in the above. > > The TPP is no simple “trade agreement.” Fight it! > http://www.ourfairdeal.org/ time is running out! > -- > View this message in context: http://forum.openscad.org/ > OpenSCAD-working-folder-tp17987p18029.html > Sent from the OpenSCAD mailing list archive at Nabble.com. > > _______________________________________________ > OpenSCAD mailing list > Discuss@lists.openscad.org > http://lists.openscad.org/mailman/listinfo/discuss_lists.openscad.org >
