polyhedron(triangles) depricated or dropped?
Mon, Sep 9, 2019 11:30 PM
Wiki still says triangles is deprecated.
2019.05 says:
WARNING: variable triangles not specified as parameter, in file Basics, line
1
TRACE: called by 'polyhedron', in file Basics, line 1.
Does wiki need updating or did triangles get dropped unintentionally?
Note that triangles is used in MCAD/involute_gears.scad (shipped with
2019.05) so I may also be elsewhere.
Wiki still says triangles is deprecated. 2019.05 says: WARNING: variable triangles not specified as parameter, in file Basics, line 1 TRACE: called by 'polyhedron', in file Basics, line 1. Does wiki need updating or did triangles get dropped unintentionally? Note that triangles is used in MCAD/involute_gears.scad (shipped with 2019.05) so I may also be elsewhere. ----- Admin - email* me if you need anything, or if I've done something stupid... * click on my MichaelAtOz label, there is a link to email me. Unless specifically shown otherwise above, my contribution is in the Public Domain; to the extent possible under law, I have waived all copyright and related or neighbouring rights to this work. Obviously inclusion of works of previous authors is not included in the above. The TPP is no simple “trade agreement.” Fight it! http://www.ourfairdeal.org/ time is running out! -- Sent from: http://forum.openscad.org/
Wed, Sep 11, 2019 6:57 PM
It's deprecated, but not yet removed. We should definitely clean up MCAD before removing it though.
2019.05 says:
1
It's deprecated, but not yet removed. We should definitely clean up MCAD before removing it though. -Marius > On Sep 9, 2019, at 19:30, MichaelAtOz <oz.at.michael@gmail.com> wrote: > > Wiki still says triangles is deprecated. > 2019.05 says: > WARNING: variable triangles not specified as parameter, in file Basics, line > 1 > TRACE: called by 'polyhedron', in file Basics, line 1. > > Does wiki need updating or did triangles get dropped unintentionally? > > Note that triangles is used in MCAD/involute_gears.scad (shipped with > 2019.05) so I may also be elsewhere. > > > > ----- > Admin - email* me if you need anything, or if I've done something stupid... > > * click on my MichaelAtOz label, there is a link to email me. > > Unless specifically shown otherwise above, my contribution is in the Public Domain; to the extent possible under law, I have waived all copyright and related or neighbouring rights to this work. Obviously inclusion of works of previous authors is not included in the above. > > The TPP is no simple “trade agreement.” Fight it! http://www.ourfairdeal.org/ time is running out! > -- > Sent from: http://forum.openscad.org/ > > _______________________________________________ > OpenSCAD mailing list > Discuss@lists.openscad.org > http://lists.openscad.org/mailman/listinfo/discuss_lists.openscad.org
