Okay, I've managed to design a "pirate chest" w/ a rounded lid in BlockSCAD:
https://www.blockscad3d.com/community/projects/919882
which I've been working out/documenting (sort of) at:
https://community.carbide3d.com/t/has-anyone-used-cc-to-kerf-wood-for-bending/22930
Now I need to actually prepare parts for cutting. STLs won't work since I
want V grooves cut accurately using a V endmill and I can't find a CAM tool
which will do that from an STL (if there is such a tool I'd be glad to know
of it). This is further complicated by the fact that there are V grooves at
a declared angle (15 degrees for the example linked above) and a pair of
grooves which need to be cut at a calculated angle which may not match up
with an extant V endmill.
Apparently if I exported 3 views as DXFs (top/front/side) those could be
imported into Solidworks or something similar using a "wizard" or suitable
technique so as to make a 3D model?
The only work-around I can come up with is to export a pair of files:
Does all this make sense? Is there some better option which I'm missing? Or
should I stop procrastinating and just finish up the coding?
Or
To get you right:
Well, if the groove is a real 3D path with altering z coordinates, I think
you have no chance with OpenSCAD.
Given that rect and groove have constant z heights (i.e. they are parallel
to the XY plane, you might be able to use something like
translate([0,0,-z_groove])
projection(cut = true)
and export that as DXF. This lets the question open, how you would deal with
the groove's angle. E.g. you could export a slightly shifted version and
calc the angle during post processing.
translate([0,0,-z_groove-.1])
I am just guessing because your verbal description has a lot of spaced to do
interpretations. Better show some code or STL ...
Discuss@.openscad
1 - it's a 3-axis machine
2 - no, it's OpenSCAD code exported from BlockSCAD which I'm then editing to
support the Customizer and the 2D export
3 - correct.
I guess I've got it working as well as it can be:
https://community.carbide3d.com/t/has-anyone-used-cc-to-kerf-wood-for-bending/22930/45
it's a single file at least --- I just need to put some text in it to
indicate the V angle which should be used when setting up a V carving.
Thanks!
