Re: [OpenSCAD] MeshLab Unexpected end of file in 2015.02.05
K
kintel
Wed, Feb 25, 2015 11:33 PM
Could you try with this updated version?
http://files.openscad.org/snapshots/OpenSCAD-2015.02.25-x86-64.zip
View this message in context: http://forum.openscad.org/MeshLab-Unexpected-end-of-file-in-2015-02-05-tp11666p11775.html
Hi, Could you try with this updated version? http://files.openscad.org/snapshots/OpenSCAD-2015.02.25-x86-64.zip -Marius -- View this message in context: http://forum.openscad.org/MeshLab-Unexpected-end-of-file-in-2015-02-05-tp11666p11775.html Sent from the OpenSCAD mailing list archive at Nabble.com.
Thu, Feb 26, 2015 12:40 AM
It was working OK for me, but JIC I checked .25 anyway with the OP .scad
file, and it still works OK.
shadowwynd will need to confirm in his environment. (assuming he gets
notified as he was/is not registered properly)
View this message in context: http://forum.openscad.org/MeshLab-Unexpected-end-of-file-in-2015-02-05-tp11666p11777.html
It was working OK for me, but JIC I checked .25 anyway with the OP .scad file, and it still works OK. shadowwynd will need to confirm in his environment. (assuming he gets notified as he was/is not registered properly) ----- Unless specifically shown otherwise above, my contribution is in the Public Domain; To the extent possible under law, I have waived all copyright and related or neighbouring rights to this work. This work is published globally via the internet. :) Inclusion of works of previous authors is not included in the above. The TPP is no simple “trade agreement.” Fight it! http://www.ourfairdeal.org/ -- View this message in context: http://forum.openscad.org/MeshLab-Unexpected-end-of-file-in-2015-02-05-tp11666p11777.html Sent from the OpenSCAD mailing list archive at Nabble.com.
S
shadowwynd
Thu, Feb 26, 2015 3:40 AM
I just tested it.  It has worked OK on every file I have tried.
The STL files are even a little smaller, which is good too.
I am on the mailing list again.
Thank you so much for all the work you have put into this program.
View this message in context: http://forum.openscad.org/MeshLab-Unexpected-end-of-file-in-2015-02-05-tp11666p11780.html
I just tested it. It has worked OK on every file I have tried. The STL files are even a little smaller, which is good too. I am on the mailing list again. Thank you so much for all the work you have put into this program. -- View this message in context: http://forum.openscad.org/MeshLab-Unexpected-end-of-file-in-2015-02-05-tp11666p11780.html Sent from the OpenSCAD mailing list archive at Nabble.com.
