On Sunday, May 25, 2025 at 12:27:45 PM EDT, Matthieu Hendriks via Discuss discuss@lists.openscad.org wrote:
Is there a separate mailinglist for asking beginner questions about pythonscad?
Not yet. It would be great if there was one here.
The big thing is, it's Python, so one can do pretty much anything.
The basic template would be something like:
variables = values
at the top
Various calculations/logic based on the variables
make 3D elements using the variables --- note that 3D elements can go int variables and can be combined in various ways, see: https://old.reddit.com/r/OpenPythonSCAD/wiki/index#wiki_3d_operations
then use show() to make the finished 3D model visible at the end.
I believe so, but you'll get a lot more performance if you re-write in Python.
I'm a bit lost. :(
I have tried to explain things in the afore-mentioned wiki, and Guenther has a tutorial at: https://pythonscad.org/tutorial/site/index.html and you may find: https://github.com/WillAdams/gcodepreview of interest if you are planning on using a CNC machine or need to interface with traditional CAD.
If you'll put up a bit of code you are having trouble with we'll gladly do our best to assist.
