I can linear_extrude this font fine but as soon as I put it against a
flat surface or substract it from one I am in trouble.
The font is "Pioneerbrush" and I have attached it
-Daniel
This is where it fails
CGAL_Nef_Polyhedron.
-Daniel
Most likely the font has a self-intersection somewhere in one or more of
its characters, quite possibly very small.
Isolate which particular character causes the problem, then blow it way
up and examine it carefully.
It might also work to linear_extrude it and view it with View/Thrown
Together. (Do not render it with F6.) Look for purple faces.
Unfortunately, finding a self-intersection doesn't solve the problem -
it just shows that the font is misdesigned.
Try offsetting by a minute amount before extruding. That sometimes fixes 2D
self intersections because Clipper gets called to do the offset and it can
fix polygons.
On Sat, 26 Mar 2022 at 02:03, Jordan Brown openscad@jordan.maileater.net
Unfortunately, finding a self-intersection doesn't solve the problem - it
Thanks nop head! That worked a treat
-Daniel
-Daniel
