Thu, Aug 30, 2018 12:42 PM
All the test that import AMF fail for me on Windows.
Is this supposed to be working or is there an open issue for it?
Thu, Aug 30, 2018 1:21 PM
To my knowledge it’s supposed to work, but it’s not a very widely used feature, so I’m not sure where/when this last worked.
If you have any more context about how it fails, that may be revealing.
Thu, Aug 30, 2018 2:22 PM
It does nothing silently. Under MSYS2 I think it is a build problem because
qmake cant find libzip but I tested it with the Windows snapshot and that
doesn't work either.
I will look into it.
So does nobody use AMF and Windows?
Package libzip was not found in the pkg-config search path.
Perhaps you should add the directory containing `libzip.pc'
to the PKG_CONFIG_PATH environment variable
> -Marius
Thu, Aug 30, 2018 2:31 PM
It's entirely possible that we're ignoring a build error for the snapshot
as well; we don't have an automated test pipeline set up for Windows as we
do on the other platforms.
I'd wager that virtually nobody uses AMF at all - that standard doesn't
seem to be going anywhere : /
because qmake cant find libzip but I tested it with the Windows snapshot
and that doesn't work either.
>> -Marius
Thu, Aug 30, 2018 3:17 PM
Cura removed AMF support in 2016, at the same time that they added 3MF
support.
Various reasons were given for removing AMF support:
- nobody uses it
- the standard contradicts itself
- it is not an open standard (ie, devs need to pay money for a copy of the
standard, no sharing)
support.
* nobody uses it
* the standard contradicts itself
* it is not an open standard (ie, devs need to pay money for a copy of the
> -Marius
>>> -Marius
Thu, Aug 30, 2018 4:31 PM
The test suit seems to use it as a means to an end, rather than just
testing AMF.
$ ctest -R cube
running 'C:/msys64/home/ChrisP/openscad/tests/../Release/openscad.exe
--info' to generate sysinfo.txt
Post test:C:/msys64/mingw64/bin/python.exe
"C:/msys64/home/ChrisP/openscad/tests/test_pretty_print.py"
--builddir=C:/msys64/home/ChrisP/openscad/tests
Test project C:/msys64/home/ChrisP/openscad/tests
Enforcing Default test configuration. Use ctest -C <config> to override
Start 132: dumptest_cube-tests
1/14 Test #132: dumptest_cube-tests ................. Passed 0.29 sec
Start 209: dumptest-examples_text_on_cube
2/14 Test #209: dumptest-examples_text_on_cube ...... Passed 0.28 sec
Start 303: cgalpngtest_cube-tests
3/14 Test #303: cgalpngtest_cube-tests .............. Passed 1.00 sec
Start 339: cgalpngtest_cube-with-hole
4/14 Test #339: cgalpngtest_cube-with-hole ..........***Failed 0.65 sec
Start 466: opencsgtest_cube-tests
5/14 Test #466: opencsgtest_cube-tests .............. Passed 0.64 sec
Start 516: opencsgtest_cube-with-hole
6/14 Test #516: opencsgtest_cube-with-hole ..........***Failed 0.70 sec
Start 643: csgpngtest_cube-tests
7/14 Test #643: csgpngtest_cube-tests ............... Passed 1.04 sec
Start 680: csgpngtest_cube-with-hole
8/14 Test #680: csgpngtest_cube-with-hole ...........***Failed 0.94 sec
Start 807: throwntogethertest_cube-tests
9/14 Test #807: throwntogethertest_cube-tests ....... Passed 0.69 sec
Start 855: throwntogethertest_cube-with-hole
10/14 Test #855: throwntogethertest_cube-with-hole ...***Failed 0.64 sec
Start 918: monotonepngtest_cube10
11/14 Test #918: monotonepngtest_cube10 .............. Passed 0.65 sec
Start 919: stlpngtest_cube10
12/14 Test #919: stlpngtest_cube10 ................... Passed 0.96 sec
Start 920: offpngtest_cube10
13/14 Test #920: offpngtest_cube10 ................... Passed 0.93 sec
Start 921: amfpngtest_cube10
14/14 Test #921: amfpngtest_cube10 ...................***Failed 0.94 sec
64% tests passed, 5 tests failed out of 14
Total Test time (real) = 10.56 sec
The following tests FAILED:
339 - cgalpngtest_cube-with-hole (Failed)
516 - opencsgtest_cube-with-hole (Failed)
680 - csgpngtest_cube-with-hole (Failed)
855 - throwntogethertest_cube-with-hole (Failed)
921 - amfpngtest_cube10 (Failed)
report saved:
support.
- nobody uses it
testing AMF.
$ ctest -R cube
report saved:
> support.
> * nobody uses it
>> -Marius
>>>> -Marius
Thu, Aug 30, 2018 4:50 PM
Without libzip the AMF importer falls back to only being able to read non
zipped AMF files.
cube-with-hole.amf is XML, so it should be able to read it without libzip.
More investigation required.
testing AMF.
$ ctest -R cube
Post test:C:/msys64/mingw64/bin/python.exe "C:/msys64/home/ChrisP/
openscad/tests/test_pretty_print.py" --builddir=C:/msys64/home/
sec
sec
report saved:
support.
- nobody uses it
the standard, no sharing)
snapshot as well; we don't have an automated test pipeline set up for
Windows as we do on the other platforms.
zipped AMF files.
> testing AMF.
> $ ctest -R cube
> sec
> sec
> report saved:
>> support.
>> * nobody uses it
>>> -Marius
>>>>> -Marius
Thu, Aug 30, 2018 11:34 PM
The reason it does not work on Windows is the AMF parser uses fs::path to
represent element hierarchies in the XML file, for example
/amf/object/mesh/volume/triangle. On Windows fs:path uses \ instead of /
so the paths don't match those in the maps of functions. So no functions
are called and and empty polyset is returned.
zipped AMF files.
testing AMF.
$ ctest -R cube
Post test:C:/msys64/mingw64/bin/python.exe "C:/msys64/home/ChrisP/openscad/tests/test_pretty_print.py"
sec
sec
sec
sec
sec
sec
sec
sec
sec
sec
sec
sec
sec
sec
report saved:
support.
- nobody uses it
> zipped AMF files.
>> testing AMF.
>> $ ctest -R cube
>> sec
>> sec
>> sec
>> sec
>> sec
>> sec
>> sec
>> sec
>> sec
>> sec
>> sec
>> sec
>> sec
>> sec
>> report saved:
>>> support.
>>> * nobody uses it
>>>> -Marius
>>>>>> revealing.
>>>>>> -Marius
Fri, Aug 31, 2018 12:12 AM
On 08/31/2018 01:34 AM, nop head wrote:
On Windows fs:path uses \ instead of / so the paths don't match those
in the maps of functions. So no functions are called and and empty
Oh, so instead of path.string() it should be path.generic_string()?
Fri, Aug 31, 2018 6:37 AM
Yes I will change it to a string as it isn't a file system path, so using
fs::path also makes the code a bit confusing.
> ciao,
> Torsten.
