There has been a lot of discussion going on about F6 rendering time. I never
had to fight with a design with many non-intersecting clones, so I didn't do
any testing on it. Now I did - with astonishing results.
Have a look at this simple code, which F5-displays immediately but
F6-renders several minutes on my machine. It clearly shows that there is not
even a simple boundingbox test done before CGAL invoke.
for (i = [1:30])
for (j = [1:30])
translate([i20, j20, 0])
cylinder(r = 5, h = 10);
And I'd say from its O(n²) behavior, that also CGAL doesn't seem to make any
effort to use boundingbox tests itself. Maybe this because of the way, how
it is invoked ...
Wouldn't it speed up things a lot if
It could also make sense, to introduce a directive (or a switch) for
indicating multiple elements with non intersecting bounding boxes to
OpenSCAD. (conditional analysis)
Also have a look here:
http://www8.cs.umu.se/education/examina/Rapporter/NilsBaeckman.pdf
View this message in context: http://forum.openscad.org/No-bounding-box-test-for-union-before-entering-CGAL-tp17538.html
I forgot to add, there is of course a way to F6-render this specific problem
even for 40000 cylinders within 5 seconds (F5 takes about a minute)
linear_extrude(height = 10)
for (i = [1:200])
for (j = [1:200])
circle(r = 5);
this demonstrates even more how OpenSCAD could win using some boundary box
testing.
View this message in context: http://forum.openscad.org/No-bounding-box-test-for-union-before-entering-CGAL-tp17538p17601.html
