OpenScad Mailing-list upgrade - hard-links?
Sun, Mar 7, 2021 6:00 AM
The host of the OpenSCAD Mailing-list (lists.openscad.org) is recommending a
software upgrade.
It is currently using Mailman 2, they are transitioning to Mailman 3.
Mailman 3 is structurally different.
In particular they have noted:
If you have used hard links on your website and other locations to your
current archives, please note that these links will break. Mailman 3 now
stores archives in a database and uses a thread ID for each archived
thread. This can't be helped because this is a result of a design choice
by the Mailman 3 developers. The plus side to this new approach is you can
still easily link to a thread using its thread ID. Even individual
messages can now be linked to.
There will be new URLs to access Affinity and your archives.
The v2 archive will be migrated to v3, but URLs will change.
I am not aware of any hard-links, but I don't know what some if you may have
setup.
So, below I list example URLs which are types of hard-links.
If you have any similar links they will break.
The archive (collected monthly) top level, containing a Year/Month/Index:
http://lists.openscad.org/mailman/private/discuss_lists.openscad.org/
Month/Specific-Post:
http://lists.openscad.org/mailman/private/discuss_lists.openscad.org/2021-February/032917.html
Month/Thread/Index:
http://lists.openscad.org/mailman/private/discuss_lists.openscad.org/2021-February/thread.html
Month/Subject/Index:
http://lists.openscad.org/mailman/private/discuss_lists.openscad.org/2021-February/subject.html
Month/Author/Index:
http://lists.openscad.org/mailman/private/discuss_lists.openscad.org/2021-February/author.html
Month/Date/Index:
http://lists.openscad.org/mailman/private/discuss_lists.openscad.org/2021-February/date.html
Month/Compressed:
http://lists.openscad.org/mailman/private/discuss_lists.openscad.org/2021-February.txt.gz
Note this is not the Forum, it will stay the same, for now.
The host of the OpenSCAD Mailing-list (lists.openscad.org) is recommending a software upgrade. It is currently using Mailman 2, they are transitioning to Mailman 3. Mailman 3 is structurally different. In particular they have noted: > If you have used hard links on your website and other locations to your > current archives, please note that these links will break. Mailman 3 now > stores archives in a database and uses a thread ID for each archived > thread. This can't be helped because this is a result of a design choice > by the Mailman 3 developers. The plus side to this new approach is you can > still easily link to a thread using its thread ID. Even individual > messages can now be linked to. > > There will be new URLs to access Affinity and your archives. The v2 archive will be migrated to v3, but URLs will change. I am not aware of any hard-links, but I don't know what some if you may have setup. So, below I list example URLs which are types of hard-links. If you have any similar links they will break. The archive (collected monthly) top level, containing a Year/Month/Index: http://lists.openscad.org/mailman/private/discuss_lists.openscad.org/ Month/Specific-Post: http://lists.openscad.org/mailman/private/discuss_lists.openscad.org/2021-February/032917.html Month/Thread/Index: http://lists.openscad.org/mailman/private/discuss_lists.openscad.org/2021-February/thread.html Month/Subject/Index: http://lists.openscad.org/mailman/private/discuss_lists.openscad.org/2021-February/subject.html Month/Author/Index: http://lists.openscad.org/mailman/private/discuss_lists.openscad.org/2021-February/author.html Month/Date/Index: http://lists.openscad.org/mailman/private/discuss_lists.openscad.org/2021-February/date.html Month/Compressed: http://lists.openscad.org/mailman/private/discuss_lists.openscad.org/2021-February.txt.gz Note this is not the Forum, it will stay the same, for now. ----- OpenSCAD Admin - email* me if you need anything, or if I've done something stupid... * on the Forum, click on my MichaelAtOz label, there is a link to email me. Unless specifically shown otherwise above, my contribution is in the Public Domain; to the extent possible under law, I have waived all copyright and related or neighbouring rights to this work. Obviously inclusion of works of previous authors is not included in the above. -- Sent from: http://forum.openscad.org/
