Is it possible to move the "preview screen" off the main window and onto
a second screen ??
If not, perhaps it would make a nice upgrade for OpenSCAD ??
Regards,
Dave
Hi Dave,
You can actually do that by:
OpenScad will reload the preview window too each time you save the file
in the editor view. This works just as well if you use a different
editor and not the built in one !
Cheers,
Csaba
onto
a second screen ??
Regards,
Dave
At least it is possible to pull the editor out of the main window onto a
second screen. This is what I do. Although it's confusing to have the
Menu-Bar for the editor still in the main window and not in the edit window.
And, Yes, I'd agree: It would be much nicer if one could pull the 3d-window
out of the main window. In fact you can pull /any/ window out of the main
window but the 3d-view :-/
onto a second screen ??
Sure. Edit / Preferences / Advanced; check "Enable undocking of Editor
and Console to separate windows". Then drag the editor, console, et
cetera out into their own windows, and put each of the windows wherever
you like.
As others have noted, the preview window is considered the main window,
so you have to move everything else out of it, rather than moving it away.
It would be a nice tweak to make the preview window be undockable, so
that the main window is an empty shell that can contain whichever of the
five sub-windows you want it to contain. Making it possible to hide the
preview window would be symmetric, but I don't know how often it would
be useful.
Tangentially answering your question - I use VS code to write my scad
files, with an OpenSCAD window open on a second monitor. OpenSCAD detects
changes to open files and regenerates the preview each time.
Matthias.
On Mon, 26 Apr 2021 at 22:46, Jordan Brown openscad@jordan.maileater.net
Is it possible to move the "preview screen" off the main window and onto a
second screen ??
and Console to separate windows". Then drag the editor, console, et cetera
out into their own windows, and put each of the windows wherever you like.
As others have noted, the preview window is considered the main window, so
It would be a nice tweak to make the preview window be undockable, so that
the main window is an empty shell that can contain whichever of the five
sub-windows you want it to contain. Making it possible to hide the preview
window would be symmetric, but I don't know how often it would be useful.
When Design/Automatic-reload-and-preview is enabled.
Sent: Tue, 27 Apr 2021 10:33
Subject: [OpenSCAD] Re: Using a second screen ?
Tangentially answering your question - I use VS code to write my scad files, with an OpenSCAD window open on a second monitor. OpenSCAD detects changes to open files and regenerates the preview each time.
Matthias.
On Mon, 26 Apr 2021 at 22:46, Jordan Brown openscad@jordan.maileater.net wrote:
Is it possible to move the "preview screen" off the main window and onto a second screen ??
Sure. Edit / Preferences / Advanced; check "Enable undocking of Editor and Console to separate windows". Then drag the editor, console, et cetera out into their own windows, and put each of the windows wherever you like.
As others have noted, the preview window is considered the main window, so you have to move everything else out of it, rather than moving it away.
It would be a nice tweak to make the preview window be undockable, so that the main window is an empty shell that can contain whichever of the five sub-windows you want it to contain. Making it possible to hide the preview window would be symmetric, but I don't know how often it would be useful.
Thanks for all the info guys
Dave
On 27/04/2021 02:46, MichaelAtOz wrote:
@font-face
{font-family:Tahoma;
panose-1:2 11 6 4 3 5 4 4 2 4;}p.MsoNormal, li.MsoNormal, div.MsoNormal
{margin:0cm;
margin-bottom:.0001pt;
font-size:12.0pt;
font-family:"Times New Roman";}a:link, span.MsoHyperlink
{color:blue;
text-decoration:underline;}a:visited, span.MsoHyperlinkFollowed
{color:blue;
text-decoration:underline;}span.EmailStyle17
{mso-style-type:personal-reply;
font-family:Arial;
color:navy;}div.Section1
{page:Section1;}When Design/Automatic-reload-and-preview is enabled.
Subject: [OpenSCAD] Re: Using a second screen ?Tangentially answering your question - I use VS code to write my scad files, with an OpenSCAD window open on a second monitor. OpenSCAD detects changes to open files and regenerates the preview each time.
Matthias.
On Mon, 26 Apr 2021 at 22:46, Jordan Brown <openscad@jordan.maileater.net> wrote:
To unsubscribe send an email to discuss-leave@lists.openscad.org[](http://www.avg.com/email-signature?utm_medium=email&utm_source=link&utm_campaign=sig-email&utm_content=emailclient) Virus-free. [www.avg.com](http://www.avg.com/email-signature?utm_medium=email&utm_source=link&utm_campaign=sig-email&utm_content=emailclient) [ ](#DAB4FAD8-2DD7-40BB-A1B8-4E2AA1F9FDF2)<pre class="moz-quote-pre" wrap="">_______________________________________________ OpenSCAD mailing list To unsubscribe send an email to <a class="moz-txt-link-abbreviated" href="mailto:discuss-leave@lists.openscad.org">discuss-leave@lists.openscad.org</a>
