Re Spelling
jim.klessig
Wed, Mar 7, 2018 5:41 PM
Well it is a grey/gray area.
Sent from my U.S. Cellular® Smartphone
null
Well it is a grey/gray area. Sent from my U.S. Cellular® Smartphone null
FV
Frank van der Hulst
Wed, Mar 7, 2018 6:13 PM
Are we talking about colo(u)r now?
Are we talking about colo(u)r now? On Thu, Mar 8, 2018 at 6:41 AM, jim.klessig <jim.klessig@gmail.com> wrote: > Well it is a grey/gray area. > > > > Sent from my U.S. Cellular® Smartphone > > _______________________________________________ > OpenSCAD mailing list > Discuss@lists.openscad.org > http://lists.openscad.org/mailman/listinfo/discuss_lists.openscad.org > >
G
Gadgetmind
Wed, Mar 7, 2018 6:30 PM
That one is fixable in user space and I have done so. I keep musing on
getting my colour () module to also address "grey".
Center, sadly, isn't fixed as easily and it's a shame that (say)
cylinder can cope with many combinations or r, d, r1, r2, d1, d2 but not
centre as well as centre.
Oh, and the other one I'd love to fix is cylinder wanting "h" for height
and linear_extrude wanting "height". I have so many 100mm
linear_extrudes on my 1st pass.
On 07/03/18 18:13, Frank van der Hulst wrote: > Are we talking about colo(u)r now? That one *is* fixable in user space and I have done so. I keep musing on getting my colour () module to also address "grey". Center, sadly, isn't fixed as easily and it's a shame that (say) cylinder can cope with many combinations or r, d, r1, r2, d1, d2 but not centre as well as centre. Oh, and the other one I'd love to fix is cylinder wanting "h" for height and linear_extrude wanting "height". I have so many 100mm linear_extrudes on my 1st pass.
N
NateTG
Wed, Mar 7, 2018 6:56 PM
well as centre.
> Center, sadly, isn't fixed as easily and it's a shame that (say) cylinder > can cope with many combinations or r, d, r1, r2, d1, d2 but not centre as > well as centre. Seems like you could make a wrapper: https://en.wikibooks.org/wiki/OpenSCAD_User_Manual/User-Defined_Functions_and_Modules#Overwriting_built-in_modules -- Sent from: http://forum.openscad.org/
Wed, Mar 7, 2018 10:07 PM
Not in Gadgetmind case:
module cylinder(r, h ,  centre) {
cylinder(r, h, center=centre) ;
would be a improper recursive module.
Em 7 de mar de 2018 15:57, "NateTG" nate-openscadforum@pedantic.org
escreveu:
well as centre.
Not in Gadgetmind case: module cylinder(r, h , centre) { cylinder(r, h, center=centre) ; } would be a improper recursive module. Em 7 de mar de 2018 15:57, "NateTG" <nate-openscadforum@pedantic.org> escreveu: > > > Center, sadly, isn't fixed as easily and it's a shame that (say) cylinder > > can cope with many combinations or r, d, r1, r2, d1, d2 but not centre as > > well as centre. > > Seems like you could make a wrapper: > > https://en.wikibooks.org/wiki/OpenSCAD_User_Manual/User- > Defined_Functions_and_Modules#Overwriting_built-in_modules > > > > -- > Sent from: http://forum.openscad.org/ > > _______________________________________________ > OpenSCAD mailing list > Discuss@lists.openscad.org > http://lists.openscad.org/mailman/listinfo/discuss_lists.openscad.org >
Wed, Mar 7, 2018 10:45 PM
Yes that is the problem when overriding built in modules you can't use the
original. With cylinder you have to construct it yourself and use
polyhedron. Not to mention handling r, r1, r2, d , d1, d2, etc.
escreveu:
cylinder
as
well as centre.
Yes that is the problem when overriding built in modules you can't use the original. With cylinder you have to construct it yourself and use polyhedron. Not to mention handling r, r1, r2, d , d1, d2, etc. On 7 March 2018 at 22:07, Ronaldo Persiano <rcmpersiano@gmail.com> wrote: > Not in Gadgetmind case: > > module cylinder(r, h , centre) { > cylinder(r, h, center=centre) ; > } > > would be a improper recursive module. > > Em 7 de mar de 2018 15:57, "NateTG" <nate-openscadforum@pedantic.org> > escreveu: > >> >> > Center, sadly, isn't fixed as easily and it's a shame that (say) >> cylinder >> > can cope with many combinations or r, d, r1, r2, d1, d2 but not centre >> as >> > well as centre. >> >> Seems like you could make a wrapper: >> >> https://en.wikibooks.org/wiki/OpenSCAD_User_Manual/User-Defi >> ned_Functions_and_Modules#Overwriting_built-in_modules >> >> >> >> -- >> Sent from: http://forum.openscad.org/ >> >> _______________________________________________ >> OpenSCAD mailing list >> Discuss@lists.openscad.org >> http://lists.openscad.org/mailman/listinfo/discuss_lists.openscad.org >> > > _______________________________________________ > OpenSCAD mailing list > Discuss@lists.openscad.org > http://lists.openscad.org/mailman/listinfo/discuss_lists.openscad.org > >
runsun
Thu, Mar 8, 2018 12:33 AM
This will solve that problem :) :)
module cylindre(r, h ,  centre) {
$  Runsun Pan, PhD $ libs: scadx , doctest , faces ( git ), offline doc ( git ), runscad.py ( 2 , git ), editor of choice: CudaText  ( OpenSCAD lexer ); $ Tips ; $ Snippets
This will solve that problem :) :) module *cylindre*(r, h , centre) { cylinder(r, h, center=centre) ; } Ronaldo wrote > module cylinder(r, h , centre) { > cylinder(r, h, center=centre) ; > } > > would be a improper recursive module. ----- $ Runsun Pan, PhD $ libs: scadx , doctest , faces ( git ), offline doc ( git ), runscad.py ( 2 , git ), editor of choice: CudaText ( OpenSCAD lexer );&nbsp;$ Tips ;&nbsp;$ Snippets -- Sent from: http://forum.openscad.org/
Thu, Mar 8, 2018 1:38 AM
original.
Would it be too hard to allow calling the original (or next scope level
down) module? Ala Lisp, Forth etc.
nophead wrote > Yes that is the problem when overriding built in modules you can't use the > original. Would it be too hard to allow calling the original (or next scope level down) module? Ala Lisp, Forth etc. ----- Admin - PM me if you need anything, or if I've done something stupid... Unless specifically shown otherwise above, my contribution is in the Public Domain; to the extent possible under law, I have waived all copyright and related or neighbouring rights to this work. Obviously inclusion of works of previous authors is not included in the above. The TPP is no simple “trade agreement.” Fight it! http://www.ourfairdeal.org/ time is running out! -- Sent from: http://forum.openscad.org/
N
NateTG
Thu, Mar 8, 2018 4:35 AM
MichaelAtOz wrote
original.
Can you do that with nested use<> ?
MichaelAtOz wrote > nophead wrote >> Yes that is the problem when overriding built in modules you can't use >> the >> original. > > Would it be too hard to allow calling the original (or next scope level > down) module? Ala Lisp, Forth etc. > ... Can you do that with nested use<> ? -- Sent from: http://forum.openscad.org/
Thu, Mar 8, 2018 5:21 AM
Why yes you can smart Sir.
use <_originals.scad> // has _cube()
module cube(size=[1,1,1],centre=false)
_cube(size=size,center=centre);
color("red") cube(1, centre=true);
translate([2,0,0]) color("blue") _cube(1);
NateTG wrote > Can you do that with nested use<> ? Why yes you can smart Sir. =========================================== use <_originals.scad> // has _cube() module cube(size=[1,1,1],centre=false) _cube(size=size,center=centre); color("red") cube(1, centre=true); translate([2,0,0]) color("blue") _cube(1); ----- Admin - PM me if you need anything, or if I've done something stupid... Unless specifically shown otherwise above, my contribution is in the Public Domain; to the extent possible under law, I have waived all copyright and related or neighbouring rights to this work. Obviously inclusion of works of previous authors is not included in the above. The TPP is no simple “trade agreement.” Fight it! http://www.ourfairdeal.org/ time is running out! -- Sent from: http://forum.openscad.org/
