simple syntax error
Mon, Dec 7, 2020 2:07 PM
I can't see the problem.  I'm trying to use a boolean to control which
pair of STL files I import, but neither the ? nor the if conditionals
are accepted.  What am I missing?  I keep getting this:
Saved backup file: C:/Users/jon/Documents/OpenSCAD/backups/Hollow Face
Array for CNC 2-backup-PJfjlBZf.scad
ERROR: Parser error: syntax error, in file Hollow Face Array for CNC
2.scad, line 25
Execution aborted
// faces are about 114 x 76 x 13
isOSCAD = true;
module PFaceA()
    translate([11, 90, 0])
        rotate([90, 0, 180])
            import("d:/stl files/Face-Plate-POS-1-decimatedx2.off",
convexity = 1000);
module PFaceO()
            import("d:/stl files/Face-Plate-POS-1.stl", convexity = 1000);
module NFaceA()
    translate([11, 90, 13])
            import("d:/stl files/Face-Plate-NEG-1-decimatedx2.off",
convexity = 1000);
module NFaceO()
            import("d:/stl files/Face-Plate-NEG-1.stl", convexity = 1000);
module PFace()
    if (isOSCAD) then PFaceO(); else PFaceA();
module NFace()
    isOSCAD ? NFaceO() : NFaceA();
I can't see the problem.  I'm trying to use a boolean to control which pair of STL files I import, but neither the ? nor the if conditionals are accepted.  What am I missing?  I keep getting this: Parsing design (AST generation)... Saved backup file: C:/Users/jon/Documents/OpenSCAD/backups/Hollow Face Array for CNC 2-backup-PJfjlBZf.scad ERROR: Parser error: syntax error, in file Hollow Face Array for CNC 2.scad, line 25 Execution aborted // faces are about 114 x 76 x 13 isOSCAD = true; module PFaceA()     translate([11, 90, 0])         rotate([90, 0, 180])             import("d:/stl files/Face-Plate-POS-1-decimatedx2.off", convexity = 1000); module PFaceO()     translate([11, 90, 0])         rotate([90, 0, 180])             import("d:/stl files/Face-Plate-POS-1.stl", convexity = 1000); module NFaceA()     translate([11, 90, 13])         rotate([90, 0, 180])             import("d:/stl files/Face-Plate-NEG-1-decimatedx2.off", convexity = 1000); module NFaceO()     translate([11, 90, 13])         rotate([90, 0, 180])             import("d:/stl files/Face-Plate-NEG-1.stl", convexity = 1000); module PFace()     if (isOSCAD) then PFaceO(); else PFaceA(); module NFace()     isOSCAD ? NFaceO() : NFaceA();
Mon, Dec 7, 2020 2:14 PM
then
2.scad, line 25
Execution aborted
isOSCAD = true;
module PFaceA()
convexity = 1000);
module PFaceO()
module NFaceA()
convexity = 1000);
module NFaceO()
module PFace()
module NFace()
then On Mon, 7 Dec 2020 at 14:08, jon <jon@jonbondy.com> wrote: > I can't see the problem. I'm trying to use a boolean to control which > pair of STL files I import, but neither the ? nor the if conditionals are > accepted. What am I missing? I keep getting this: > > > Parsing design (AST generation)... > > Saved backup file: C:/Users/jon/Documents/OpenSCAD/backups/Hollow Face > Array for CNC 2-backup-PJfjlBZf.scad > > ERROR: Parser error: syntax error, in file Hollow Face Array for CNC > 2.scad, line 25 > > Execution aborted > > > > > // faces are about 114 x 76 x 13 > isOSCAD = true; > > module PFaceA() > translate([11, 90, 0]) > rotate([90, 0, 180]) > import("d:/stl files/Face-Plate-POS-1-decimatedx2.off", > convexity = 1000); > > module PFaceO() > translate([11, 90, 0]) > rotate([90, 0, 180]) > import("d:/stl files/Face-Plate-POS-1.stl", convexity = 1000); > > module NFaceA() > translate([11, 90, 13]) > rotate([90, 0, 180]) > import("d:/stl files/Face-Plate-NEG-1-decimatedx2.off", > convexity = 1000); > > module NFaceO() > translate([11, 90, 13]) > rotate([90, 0, 180]) > import("d:/stl files/Face-Plate-NEG-1.stl", convexity = 1000); > > module PFace() > if (isOSCAD) then PFaceO(); else PFaceA(); > > module NFace() > isOSCAD ? NFaceO() : NFaceA(); > > _______________________________________________ > OpenSCAD mailing list > Discuss@lists.openscad.org > http://lists.openscad.org/mailman/listinfo/discuss_lists.openscad.org >
Mon, Dec 7, 2020 2:16 PM
Thanks.  I know too many frigging languages.  Sigh
On 12/7/2020 9:14 AM, nop head wrote:
then
 CNC 2.scad, line 25
 Execution aborted
 isOSCAD = true;
 module PFaceA()
             import("d:/stl
 module PFaceO()
 = 1000);
 module NFaceA()
             import("d:/stl
 module NFaceO()
 = 1000);
 module PFace()
 module NFace()
Thanks.  I know too many frigging languages.  Sigh On 12/7/2020 9:14 AM, nop head wrote: > then > > On Mon, 7 Dec 2020 at 14:08, jon <jon@jonbondy.com > <mailto:jon@jonbondy.com>> wrote: > > I can't see the problem.  I'm trying to use a boolean to control > which pair of STL files I import, but neither the ? nor the if > conditionals are accepted.  What am I missing?  I keep getting this: > > > Parsing design (AST generation)... > > Saved backup file: C:/Users/jon/Documents/OpenSCAD/backups/Hollow > Face Array for CNC 2-backup-PJfjlBZf.scad > > ERROR: Parser error: syntax error, in file Hollow Face Array for > CNC 2.scad, line 25 > > Execution aborted > > > > > // faces are about 114 x 76 x 13 > isOSCAD = true; > > module PFaceA() >     translate([11, 90, 0]) >         rotate([90, 0, 180]) >             import("d:/stl > files/Face-Plate-POS-1-decimatedx2.off", convexity = 1000); > > module PFaceO() >     translate([11, 90, 0]) >         rotate([90, 0, 180]) >             import("d:/stl files/Face-Plate-POS-1.stl", convexity > = 1000); > > module NFaceA() >     translate([11, 90, 13]) >         rotate([90, 0, 180]) >             import("d:/stl > files/Face-Plate-NEG-1-decimatedx2.off", convexity = 1000); > > module NFaceO() >     translate([11, 90, 13]) >         rotate([90, 0, 180]) >             import("d:/stl files/Face-Plate-NEG-1.stl", convexity > = 1000); > > module PFace() >     if (isOSCAD) then PFaceO(); else PFaceA(); > > module NFace() >     isOSCAD ? NFaceO() : NFaceA(); > > _______________________________________________ > OpenSCAD mailing list > Discuss@lists.openscad.org <mailto:Discuss@lists.openscad.org> > http://lists.openscad.org/mailman/listinfo/discuss_lists.openscad.org > <http://lists.openscad.org/mailman/listinfo/discuss_lists.openscad.org> > > > _______________________________________________ > OpenSCAD mailing list > Discuss@lists.openscad.org > http://lists.openscad.org/mailman/listinfo/discuss_lists.openscad.org
Mon, Dec 7, 2020 10:45 PM
Also note the conditional '... ? ... : ...' is part of an expression.
Whereas if/else are statements.
Also note the conditional '... ? ... : ...' is part of an expression. Whereas if/else are statements. ----- OpenSCAD Admin - email* me if you need anything, or if I've done something stupid... * on the Forum, click on my MichaelAtOz label, there is a link to email me. Unless specifically shown otherwise above, my contribution is in the Public Domain; to the extent possible under law, I have waived all copyright and related or neighbouring rights to this work. Obviously inclusion of works of previous authors is not included in the above. -- Sent from: http://forum.openscad.org/
