Hello,
I have a problem with the STL file.
Please take a look at this:
http://stackoverflow.com/questions/42869159/openscad-faces-are-duplicated-in-stl
View this message in context: http://forum.openscad.org/polyhedron-is-not-filled-internally-tp20947.html
The faces of the polygons that meet in the middle have the wrong winding
order. If you press F12 you will see they are purple. Perhaps that is
causing the issue.
On 18 March 2017 at 10:16, Endre ebak32@gmail.com wrote:
Hello,
<http://stackoverflow.com/questions/42869159/openscad-
faces-are-duplicated-in-stl>
The last face should be [8, 3, 1, 0] in both cases.
causing the issue.
Hello,
<http://stackoverflow.com/questions/42869159/openscad-faces-
Thanks for the quick reply! I'll check.
I have even tried to look for such issues with "Thrown Together" but I did
not notice it.
Perhaps I'll see it if I preview the model without mirroring.
Can it cause a problem that the middle face is the mirror plane? So it is
mirrored to itself with inverse normal.
Here I have attached an image, I don't see the purple faces from outside. I
can see purple only if I zoom inside the model.
http://forum.openscad.org/file/n20950/cobra.png
View this message in context: http://forum.openscad.org/polyhedron-is-not-filled-internally-tp20947p20950.html
Yes you need to remove one of the polyhedrons to see the problem.
I think the union fails when its inputs are not manifold. I don't see any
duplicate faces when I fix the polyhedrons.
not notice it.
Thank you very much! It has really solved the problem.
View this message in context: http://forum.openscad.org/polyhedron-is-not-filled-internally-tp20947p20952.html
