I'd like to fill in all the area between these two objects. When I use
hull, it fills in the area within the arc as well.
What I am after is something that looks a bit like a dam, if that makes
sense.
http://forum.openscad.org/file/t3018/H.jpg
Here is my code. Does anybody have any ideas hoe I can join those shapes in
that way?
include <dotSCAD-master\src\rotate_p.scad>;
include <dotSCAD-master\src\polysections.scad>;
include <dotSCAD-master\src\path_extrude.scad>;
include <dotSCAD-master\src\bezier_curve.scad>;
no_steps=100;
t_step=1/no_steps;
shape_pts = [
[0, 0],
[2, 0],
[2,0.5],
[0,0.5],
bottom_path = [
[0,0,0],
[0,-20,0],
[20,-20,0],
[20,0,0],
top_path = [
[0,0,0],
[0,-25,0],
[25,-25,0],
[25,0,0],
bottom_path_pts = bezier_curve(t_step,bottom_path);
top_path_pts = bezier_curve(t_step,top_path);
path_extrude(shape_pts, bottom_path_pts, method = "EULER_ANGLE");
translate([-2.5,2,3]) path_extrude(shape_pts, top_path_pts, method =
"EULER_ANGLE");
I would hull the outside paths and then difference with a hull of the
inside paths for that particular shape.
sense.
in
that way?
no_steps=100;
t_step=1/no_steps;
shape_pts = [
[0, 0],
[2, 0],
[2,0.5],
[0,0.5],
bottom_path = [
[0,0,0],
[0,-20,0],
[20,-20,0],
[20,0,0],
top_path = [
[0,0,0],
[0,-25,0],
[25,-25,0],
[25,0,0],
"EULER_ANGLE");
sense.
that way?
It looks like you want something similar to a lofting function
https://en.wikipedia.org/wiki/Lofting
Probably your best guess is to create 2 solids, one based on the outer
curves of top an bottom, another from the inner curves. Then subtract
inner from outer.
You want this?
use <rotate_p.scad>;
use <polysections.scad>;
use <path_extrude.scad>;
use <bezier_curve.scad>;
use <shape_path_extend.scad>;
use <sweep.scad>;
no_steps=100;
t_step=1/no_steps;
bottom_path = [
[0,0,0],
[0,-20,0],
[20,-20,0],
[20,0,0],
top_path = [
[0,0,0],
[0,-25,0],
[25,-25,0],
[25,0,0],
stroke = [[0, 0], [2, 0]];
shape1 = shape_path_extend(stroke, bottom_path_pts);
shape2 = shape_path_extend(stroke, top_path_pts);
sweep([
[for(p = shape1) [p[0], p[1], 0]],
[for(p = shape2) [p[0], p[1], 0] + [-2.5,2,3]]
http://forum.openscad.org/file/t1825/1.jpg
Wow, so many great answers, thanks!
I've tried both nophead and caterpillar's suggestions and got what I wanted
out of both.
It was good to do both, as it means I learn more!
Thanks so much, that has got me going now.
