What are the steps needed to make reassignments of variables possible
PF
Peter Falke
Wed, Feb 11, 2015 7:46 PM
The wish for reassigning variables comes again and again.
And apart from the discussion weather or not reassignment is needed or not
I would like to think about what the necessary steps would be to make it
happen.
In my simple understanding of programming, only a simple pre-execution of
the code is needed, that ignores all geometrical calculation and just
generates an intermediate code were every occurrence of a reassigned
variable is overwritten with its explicit value at that time.
schreiben.
Enjoy!
The wish for reassigning variables comes again and again. And apart from the discussion weather or not reassignment is needed or not I would like to think about what the necessary steps would be to make it happen. In my simple understanding of programming, only a simple pre-execution of the code is needed, that ignores all geometrical calculation and just generates an intermediate code were every occurrence of a reassigned variable is overwritten with its explicit value at that time. -- stempeldergeschichte@googlemail.com <karsten@rohrbach.de> P.S. Falls meine E-Mail kürzer ausfällt als Dir angenehm ist: Ich probiere gerade aus kurze Antworten statt gar keine Antworten zu schreiben. Wenn Du gerne mehr lesen möchtest, dann lass es mich bitte wissen. P.S. In case my e-mail is shorter than you enjoy: I am currently trying short replies instead of no replies at all. Please let me know, if you like to read more. Enjoy!
Wed, Feb 11, 2015 8:34 PM
On Feb 11, 2015, at 14:46 PM, Peter Falke stempeldergeschichte@googlemail.com wrote:
Preprocessing might be the logical way to do it.
One way to think about it is that you want to turn this:
a=1;
a=a+1;
a=a+1;
myshape(a);
into:
assign(a=1)
assign(a=a+1)
assign(a=a+1)
sphere(a);
..where the latter is correct OpenSCAD syntax.
While this is perfectly doable, keep in mind that one of the reasons for not changing this behavior is that cmd-line overrides using -D needs to be resolved properly, preferably in a backwards-compatible way.
On Feb 11, 2015, at 14:46 PM, Peter Falke <stempeldergeschichte@googlemail.com> wrote: > > In my simple understanding of programming, only a simple pre-execution of the code is needed, that ignores all geometrical calculation and just generates an intermediate code were every occurrence of a reassigned variable is overwritten with its explicit value at that time. > Preprocessing might be the logical way to do it. One way to think about it is that you want to turn this: a=1; a=a+1; a=a+1; myshape(a); into: assign(a=1) assign(a=a+1) assign(a=a+1) sphere(a); ..where the latter is correct OpenSCAD syntax. While this is perfectly doable, keep in mind that one of the reasons for not changing this behavior is that cmd-line overrides using -D needs to be resolved properly, preferably in a backwards-compatible way. -Marius
PF
Peter Falke
Wed, Feb 11, 2015 9:30 PM
One solution for -D cmd-line would be to assign the first occurrence of the
variable to the -D parameter.
One has to think about the reassignment by libraries as well.
2015-02-11 21:34 GMT+01:00 Marius Kintel marius@kintel.net:
a=1;
a=a+1;
a=a+1;
myshape(a);
into:
assign(a=1)
assign(a=a+1)
assign(a=a+1)
sphere(a);
schreiben.
Enjoy!
One solution for -D cmd-line would be to assign the first occurrence of the variable to the -D parameter. One has to think about the reassignment by libraries as well. 2015-02-11 21:34 GMT+01:00 Marius Kintel <marius@kintel.net>: > > On Feb 11, 2015, at 14:46 PM, Peter Falke < > stempeldergeschichte@googlemail.com> wrote: > > > > In my simple understanding of programming, only a simple pre-execution > of the code is needed, that ignores all geometrical calculation and just > generates an intermediate code were every occurrence of a reassigned > variable is overwritten with its explicit value at that time. > > > Preprocessing might be the logical way to do it. > One way to think about it is that you want to turn this: > > a=1; > a=a+1; > a=a+1; > myshape(a); > > into: > > assign(a=1) > assign(a=a+1) > assign(a=a+1) > sphere(a); > > ..where the latter is correct OpenSCAD syntax. > > While this is perfectly doable, keep in mind that one of the reasons for > not changing this behavior is that cmd-line overrides using -D needs to be > resolved properly, preferably in a backwards-compatible way. > > -Marius > > > _______________________________________________ > OpenSCAD mailing list > Discuss@lists.openscad.org > http://lists.openscad.org/mailman/listinfo/discuss_lists.openscad.org > -- stempeldergeschichte@googlemail.com <karsten@rohrbach.de> P.S. Falls meine E-Mail kürzer ausfällt als Dir angenehm ist: Ich probiere gerade aus kurze Antworten statt gar keine Antworten zu schreiben. Wenn Du gerne mehr lesen möchtest, dann lass es mich bitte wissen. P.S. In case my e-mail is shorter than you enjoy: I am currently trying short replies instead of no replies at all. Please let me know, if you like to read more. Enjoy!
JL
Joseph Lenox
Wed, Feb 11, 2015 10:34 PM
Perhaps it is too soon to consider some form of automatic namespacing?
Like if a is included from b.scad, you can refer to it directly as b:a?
Includes from includes could either be part of the last include's namespace
or the file they came from. So if c defines a and b includes c and the user
has included b, either still b:a or b:c:a. I am less enamored of the second
as it implies a lot more coupling to libraries.
Obviously a namespace block would be useful as well.
This, I think is a useful balance between library name collisions and
compatibility with existing  libs.
Overrides with -D are still pretty dirty (but entirely in keeping with the
syntax restrictions to its loose cousin, the c preprocessor)
On Feb 11, 2015 3:30 PM, "Peter Falke" stempeldergeschichte@googlemail.com
a=1;
a=a+1;
a=a+1;
myshape(a);
into:
assign(a=1)
assign(a=a+1)
assign(a=a+1)
sphere(a);
schreiben.
Enjoy!
Perhaps it is too soon to consider some form of automatic namespacing? Like if a is included from b.scad, you can refer to it directly as b:a? Includes from includes could either be part of the last include's namespace or the file they came from. So if c defines a and b includes c and the user has included b, either still b:a or b:c:a. I am less enamored of the second as it implies a lot more coupling to libraries. Obviously a namespace block would be useful as well. This, I think is a useful balance between library name collisions and compatibility with existing libs. Overrides with -D are still pretty dirty (but entirely in keeping with the syntax restrictions to its loose cousin, the c preprocessor) On Feb 11, 2015 3:30 PM, "Peter Falke" <stempeldergeschichte@googlemail.com> wrote: > One solution for -D cmd-line would be to assign the first occurrence of > the variable to the -D parameter. > > One has to think about the reassignment by libraries as well. > > 2015-02-11 21:34 GMT+01:00 Marius Kintel <marius@kintel.net>: > >> >> On Feb 11, 2015, at 14:46 PM, Peter Falke < >> stempeldergeschichte@googlemail.com> wrote: >> > >> > In my simple understanding of programming, only a simple pre-execution >> of the code is needed, that ignores all geometrical calculation and just >> generates an intermediate code were every occurrence of a reassigned >> variable is overwritten with its explicit value at that time. >> > >> Preprocessing might be the logical way to do it. >> One way to think about it is that you want to turn this: >> >> a=1; >> a=a+1; >> a=a+1; >> myshape(a); >> >> into: >> >> assign(a=1) >> assign(a=a+1) >> assign(a=a+1) >> sphere(a); >> >> ..where the latter is correct OpenSCAD syntax. >> >> While this is perfectly doable, keep in mind that one of the reasons for >> not changing this behavior is that cmd-line overrides using -D needs to be >> resolved properly, preferably in a backwards-compatible way. >> >> -Marius >> >> >> _______________________________________________ >> OpenSCAD mailing list >> Discuss@lists.openscad.org >> http://lists.openscad.org/mailman/listinfo/discuss_lists.openscad.org >> > > > > -- > stempeldergeschichte@googlemail.com <karsten@rohrbach.de> > > P.S. Falls meine E-Mail kürzer ausfällt als Dir angenehm ist: > Ich probiere gerade aus kurze Antworten statt gar keine Antworten zu > schreiben. > Wenn Du gerne mehr lesen möchtest, dann lass es mich bitte wissen. > > P.S. In case my e-mail is shorter than you enjoy: > I am currently trying short replies instead of no replies at all. > Please let me know, if you like to read more. > > Enjoy! > > _______________________________________________ > OpenSCAD mailing list > Discuss@lists.openscad.org > http://lists.openscad.org/mailman/listinfo/discuss_lists.openscad.org > >
JL
Joseph Lenox
Wed, Feb 11, 2015 10:36 PM
You are starting to get into the territory of "shouldn't someone just use
solid python instead", imho.
a=1;
a=a+1;
a=a+1;
myshape(a);
into:
assign(a=1)
assign(a=a+1)
assign(a=a+1)
sphere(a);
schreiben.
Enjoy!
You are starting to get into the territory of "shouldn't someone just use solid python instead", imho. On Feb 11, 2015 3:30 PM, "Peter Falke" <stempeldergeschichte@googlemail.com> wrote: > One solution for -D cmd-line would be to assign the first occurrence of > the variable to the -D parameter. > > One has to think about the reassignment by libraries as well. > > 2015-02-11 21:34 GMT+01:00 Marius Kintel <marius@kintel.net>: > >> >> On Feb 11, 2015, at 14:46 PM, Peter Falke < >> stempeldergeschichte@googlemail.com> wrote: >> > >> > In my simple understanding of programming, only a simple pre-execution >> of the code is needed, that ignores all geometrical calculation and just >> generates an intermediate code were every occurrence of a reassigned >> variable is overwritten with its explicit value at that time. >> > >> Preprocessing might be the logical way to do it. >> One way to think about it is that you want to turn this: >> >> a=1; >> a=a+1; >> a=a+1; >> myshape(a); >> >> into: >> >> assign(a=1) >> assign(a=a+1) >> assign(a=a+1) >> sphere(a); >> >> ..where the latter is correct OpenSCAD syntax. >> >> While this is perfectly doable, keep in mind that one of the reasons for >> not changing this behavior is that cmd-line overrides using -D needs to be >> resolved properly, preferably in a backwards-compatible way. >> >> -Marius >> >> >> _______________________________________________ >> OpenSCAD mailing list >> Discuss@lists.openscad.org >> http://lists.openscad.org/mailman/listinfo/discuss_lists.openscad.org >> > > > > -- > stempeldergeschichte@googlemail.com <karsten@rohrbach.de> > > P.S. Falls meine E-Mail kürzer ausfällt als Dir angenehm ist: > Ich probiere gerade aus kurze Antworten statt gar keine Antworten zu > schreiben. > Wenn Du gerne mehr lesen möchtest, dann lass es mich bitte wissen. > > P.S. In case my e-mail is shorter than you enjoy: > I am currently trying short replies instead of no replies at all. > Please let me know, if you like to read more. > > Enjoy! > > _______________________________________________ > OpenSCAD mailing list > Discuss@lists.openscad.org > http://lists.openscad.org/mailman/listinfo/discuss_lists.openscad.org > >
Wed, Feb 11, 2015 11:10 PM
Once it looks like you can do x=x+1, then you will want
if (expr)
x=x+1;
else
x=x+2;
cube(x);
View this message in context: http://forum.openscad.org/What-are-the-steps-needed-to-make-reassignments-of-variables-possible-tp11611p11618.html
Once it looks like you can do x=x+1, then you will want if (expr) x=x+1; else x=x+2; cube(x); ----- Unless specifically shown otherwise above, my contribution is in the Public Domain; To the extent possible under law, I have waived all copyright and related or neighbouring rights to this work. This work is published globally via the internet. :) Inclusion of works of previous authors is not included in the above. The TPP is no simple “trade agreement.” Fight it! http://www.ourfairdeal.org/ -- View this message in context: http://forum.openscad.org/What-are-the-steps-needed-to-make-reassignments-of-variables-possible-tp11611p11618.html Sent from the OpenSCAD mailing list archive at Nabble.com.
GW
G. Wade Johnson
Thu, Feb 12, 2015 12:02 AM
On Wed, 11 Feb 2015 16:34:45 -0600
b:a?
libraries.
But it really makes generating multiple prints from one file easy with
the command line version.
I have many designs with multiple STL files generated from one design
via a "plate" constant/variable. I reset on the command line to
generate the one I want. (From a Makefile, if you want to realize just
how much of a programmer I am.<shrug/>)
Not allowing the -D option would really make for a messier workflow, or
a bunch of small files that do the equivalent.
Just my 2 cents.
G. Wade
pre-execution
time.
a=1;
a=a+1;
a=a+1;
myshape(a);
into:
assign(a=1)
assign(a=a+1)
assign(a=a+1)
sphere(a);
schreiben.
Enjoy!
Why do your people ask if someone's ready right before you are going to
do something massively unwise?      -- Delenn - "The War without End"
On Wed, 11 Feb 2015 16:34:45 -0600 Joseph Lenox <lenox.joseph@gmail.com> wrote: > Perhaps it is too soon to consider some form of automatic namespacing? > > Like if a is included from b.scad, you can refer to it directly as > b:a? > > Includes from includes could either be part of the last include's > namespace or the file they came from. So if c defines a and b > includes c and the user has included b, either still b:a or b:c:a. I > am less enamored of the second as it implies a lot more coupling to > libraries. > > Obviously a namespace block would be useful as well. > > This, I think is a useful balance between library name collisions and > compatibility with existing libs. > > Overrides with -D are still pretty dirty (but entirely in keeping > with the syntax restrictions to its loose cousin, the c preprocessor) But it really makes generating multiple prints from one file easy with the command line version. I have many designs with multiple STL files generated from one design via a "plate" constant/variable. I reset on the command line to generate the one I want. (From a Makefile, if you want to realize just how much of a programmer I am.<shrug/>) Not allowing the -D option would really make for a messier workflow, or a bunch of small files that do the equivalent. Just my 2 cents. G. Wade > On Feb 11, 2015 3:30 PM, "Peter Falke" > <stempeldergeschichte@googlemail.com> wrote: > > > One solution for -D cmd-line would be to assign the first > > occurrence of the variable to the -D parameter. > > > > One has to think about the reassignment by libraries as well. > > > > 2015-02-11 21:34 GMT+01:00 Marius Kintel <marius@kintel.net>: > > > >> > >> On Feb 11, 2015, at 14:46 PM, Peter Falke < > >> stempeldergeschichte@googlemail.com> wrote: > >> > > >> > In my simple understanding of programming, only a simple > >> > pre-execution > >> of the code is needed, that ignores all geometrical calculation > >> and just generates an intermediate code were every occurrence of a > >> reassigned variable is overwritten with its explicit value at that > >> time. > >> > > >> Preprocessing might be the logical way to do it. > >> One way to think about it is that you want to turn this: > >> > >> a=1; > >> a=a+1; > >> a=a+1; > >> myshape(a); > >> > >> into: > >> > >> assign(a=1) > >> assign(a=a+1) > >> assign(a=a+1) > >> sphere(a); > >> > >> ..where the latter is correct OpenSCAD syntax. > >> > >> While this is perfectly doable, keep in mind that one of the > >> reasons for not changing this behavior is that cmd-line overrides > >> using -D needs to be resolved properly, preferably in a > >> backwards-compatible way. > >> > >> -Marius > >> > >> > >> _______________________________________________ > >> OpenSCAD mailing list > >> Discuss@lists.openscad.org > >> http://lists.openscad.org/mailman/listinfo/discuss_lists.openscad.org > >> > > > > > > > > -- > > stempeldergeschichte@googlemail.com <karsten@rohrbach.de> > > > > P.S. Falls meine E-Mail kürzer ausfällt als Dir angenehm ist: > > Ich probiere gerade aus kurze Antworten statt gar keine Antworten zu > > schreiben. > > Wenn Du gerne mehr lesen möchtest, dann lass es mich bitte wissen. > > > > P.S. In case my e-mail is shorter than you enjoy: > > I am currently trying short replies instead of no replies at all. > > Please let me know, if you like to read more. > > > > Enjoy! > > > > _______________________________________________ > > OpenSCAD mailing list > > Discuss@lists.openscad.org > > http://lists.openscad.org/mailman/listinfo/discuss_lists.openscad.org > > > > -- Why do your people ask if someone's ready right before you are going to do something massively unwise? -- Delenn - "The War without End"
YA
Yona Appletree
Perhaps I'm missing something, but I don't really get the need for
variable re-assignment, and it seems that it would break the functional
nature of the OpenSCAD language.
Variable mutation basically means that OpenSCAD would no longer be a
tree-description language and would become an imperative language that
has functions to build a geometry tree (see Josheph's comment about
geometric python).
When these requests come up, I would suggest referring people to
documentation about functional languages and focus the effort on making
OpenSCAD a better functional language, as opposed to making a chimera
that might make some folks happy in the short-term.
MichaelAtOz mailto:oz.at.michael@gmail.com
February 11, 2015 at 15:10
if (expr)
x=x+1;
else
x=x+2;
cube(x);
Joseph Lenox mailto:lenox.joseph@gmail.com
February 11, 2015 at 14:36
Peter Falke mailto:stempeldergeschichte@googlemail.com
February 11, 2015 at 13:30
stempeldergeschichte@googlemail.com mailto:karsten@rohrbach.de
schreiben.
Enjoy!
Marius Kintel mailto:marius@kintel.net
February 11, 2015 at 12:34
a=1;
a=a+1;
a=a+1;
myshape(a);
into:
assign(a=1)
assign(a=a+1)
assign(a=a+1)
sphere(a);
February 11, 2015 at 11:46
make it happen.
schreiben.
Enjoy!
Perhaps I'm missing something, but I don't really get the need for variable re-assignment, and it seems that it would break the functional nature of the OpenSCAD language. Variable mutation basically means that OpenSCAD would no longer be a tree-description language and would become an imperative language that has functions to build a geometry tree (see Josheph's comment about geometric python). When these requests come up, I would suggest referring people to documentation about functional languages and focus the effort on making OpenSCAD a better functional language, as opposed to making a chimera that might make some folks happy in the short-term. > MichaelAtOz <mailto:oz.at.michael@gmail.com> > February 11, 2015 at 15:10 > Once it looks like you can do x=x+1, then you will want > > if (expr) > x=x+1; > else > x=x+2; > cube(x); > > > > ----- > Unless specifically shown otherwise above, my contribution is in the > Public Domain; To the extent possible under law, I have waived all > copyright and related or neighbouring rights to this work. This work > is published globally via the internet. :) Inclusion of works of > previous authors is not included in the above. > > The TPP is no simple “trade agreement.” Fight it! > http://www.ourfairdeal.org/ > -- > View this message in context: > http://forum.openscad.org/What-are-the-steps-needed-to-make-reassignments-of-variables-possible-tp11611p11618.html > Sent from the OpenSCAD mailing list archive at Nabble.com. > > _______________________________________________ > OpenSCAD mailing list > Discuss@lists.openscad.org > http://lists.openscad.org/mailman/listinfo/discuss_lists.openscad.org > Joseph Lenox <mailto:lenox.joseph@gmail.com> > February 11, 2015 at 14:36 > > You are starting to get into the territory of "shouldn't someone just > use solid python instead", imho. > > _______________________________________________ > OpenSCAD mailing list > Discuss@lists.openscad.org > http://lists.openscad.org/mailman/listinfo/discuss_lists.openscad.org > Peter Falke <mailto:stempeldergeschichte@googlemail.com> > February 11, 2015 at 13:30 > One solution for -D cmd-line would be to assign the first occurrence > of the variable to the -D parameter. > > One has to think about the reassignment by libraries as well. > > > > > -- > stempeldergeschichte@googlemail.com <mailto:karsten@rohrbach.de> > > P.S. Falls meine E-Mail kürzer ausfällt als Dir angenehm ist: > Ich probiere gerade aus kurze Antworten statt gar keine Antworten zu > schreiben. > Wenn Du gerne mehr lesen möchtest, dann lass es mich bitte wissen. > > P.S. In case my e-mail is shorter than you enjoy: > I am currently trying short replies instead of no replies at all. > Please let me know, if you like to read more. > > Enjoy! > _______________________________________________ > OpenSCAD mailing list > Discuss@lists.openscad.org > http://lists.openscad.org/mailman/listinfo/discuss_lists.openscad.org > Marius Kintel <mailto:marius@kintel.net> > February 11, 2015 at 12:34 > Preprocessing might be the logical way to do it. > One way to think about it is that you want to turn this: > > a=1; > a=a+1; > a=a+1; > myshape(a); > > into: > > assign(a=1) > assign(a=a+1) > assign(a=a+1) > sphere(a); > > ..where the latter is correct OpenSCAD syntax. > > While this is perfectly doable, keep in mind that one of the reasons > for not changing this behavior is that cmd-line overrides using -D > needs to be resolved properly, preferably in a backwards-compatible way. > > -Marius > > > _______________________________________________ > OpenSCAD mailing list > Discuss@lists.openscad.org > http://lists.openscad.org/mailman/listinfo/discuss_lists.openscad.org > Peter Falke <mailto:stempeldergeschichte@googlemail.com> > February 11, 2015 at 11:46 > The wish for reassigning variables comes again and again. > And apart from the discussion weather or not reassignment is needed or > not I would like to think about what the necessary steps would be to > make it happen. > > In my simple understanding of programming, only a simple pre-execution > of the code is needed, that ignores all geometrical calculation and > just generates an intermediate code were every occurrence of a > reassigned variable is overwritten with its explicit value at that time. > > > > > -- > stempeldergeschichte@googlemail.com <mailto:karsten@rohrbach.de> > > P.S. Falls meine E-Mail kürzer ausfällt als Dir angenehm ist: > Ich probiere gerade aus kurze Antworten statt gar keine Antworten zu > schreiben. > Wenn Du gerne mehr lesen möchtest, dann lass es mich bitte wissen. > > P.S. In case my e-mail is shorter than you enjoy: > I am currently trying short replies instead of no replies at all. > Please let me know, if you like to read more. > > Enjoy! > _______________________________________________ > OpenSCAD mailing list > Discuss@lists.openscad.org > http://lists.openscad.org/mailman/listinfo/discuss_lists.openscad.org
Michele
Thu, Feb 12, 2015 1:04 AM
Even Lisp, the canonical functional language has SETQ.
View this message in context: http://forum.openscad.org/What-are-the-steps-needed-to-make-reassignments-of-variables-possible-tp11611p11621.html
Even Lisp, the canonical functional language has SETQ. -- View this message in context: http://forum.openscad.org/What-are-the-steps-needed-to-make-reassignments-of-variables-possible-tp11611p11621.html Sent from the OpenSCAD mailing list archive at Nabble.com.
Thu, Feb 12, 2015 1:58 AM
Well general purpose programming languages need to be able to remember and
manipulate state for a lot of applications but a description of a 3D object
is not one of them.
Well general purpose programming languages need to be able to remember and manipulate state for a lot of applications but a description of a 3D object is not one of them. On 12 February 2015 at 01:04, Michele <denber@mindspring.com> wrote: > Even Lisp, the canonical functional language has SETQ. > > > > -- > View this message in context: > http://forum.openscad.org/What-are-the-steps-needed-to-make-reassignments-of-variables-possible-tp11611p11621.html > Sent from the OpenSCAD mailing list archive at Nabble.com. > > _______________________________________________ > OpenSCAD mailing list > Discuss@lists.openscad.org > http://lists.openscad.org/mailman/listinfo/discuss_lists.openscad.org >
