Is there any difference, either practical or theoretical, between the
following two module definitions?
module hole() {
translate([0,0,-1]) cylinder(fwthickness+1,d=screwsz);
translate([0,0,fwthickness]) cylinder(100,d=screwhd);
module hole() {
ATM no.
At some time in the misty future, the implicit union will be removed,
possibly in some fashion that preserves backward compatibility.
With that, a non unioned group() [the first of your cases] will exist as two
child objects, v's the union()'d case will be one object.
Thus allowing the first case, each object can be accessed via children()
individually.
It may also have performance implications, but that is less clear ATM.
View this message in context: http://forum.openscad.org/module-implies-union-tp21790p21793.html
