Anyone know how to do stereographic projections? Threonin on
Thingiverse has some OpenSCAD code to map a pixel array (image) onto a
sphere, but that would not produce nice curves. Examples:
http://www.thingiverse.com/thing:294899
http://www.thingiverse.com/thing:295281
http://www.thingiverse.com/thing:418129
Is there a way to create geometry and then methodically warp each point
on each triangle to conform to the sphere?
Yes, if you have access to the points of the geometry. That means you need
to generate the points of the polygons and not producing them by 2D
primitives and 2D operators. Function project() in Threonin's code does
exactly what you want. However, to get a good approximation of the projected
polygon edges you should refine the edges by inserting points in it before
the projection.
View this message in context: http://forum.openscad.org/stereographic-projections-tp20339p20343.html
Not really stereo but:
another approach is to look at problem as solids and booleans.
I.e. assume point light source and a surrounding shell of a sphere which you
want to cut into just as in the example links you sent.
So make the (say maze object - perhaps out of individual bloacks perhaps as
one object),
then extrude it and use scale param down to a very small size at the point
light's location,
then do a boolean difference with the sphere shell.
The result is the same.
View this message in context: http://forum.openscad.org/stereographic-projections-tp20339p20354.html
Neon:
Not sure I get what you're saying.
Start with a planar object of some complex design (say a maze).
When you extrude it, it goes straight up, not towards the light source
or the surface of the sphere.
It seems that this might be easier in an external language than in OpenSCAD.
But perhaps I'm missing your point.
one object),
light's location,
Checked by AVG - www.avg.com
Version: 2016.0.7998 / Virus Database: 4756/13899 - Release Date: 02/06/17
Here is an example using the (seldom used?) scale param to linear_extrude.
$fn=30;
module 2D_shape() {
offset(r=3) {
square(size=[20,30], center=true);
module 3D_projection (dist) {
linear_extrude(height = dist, center = true, convexity = 4, scale=0.1) {
module shell (rad, thick) {
sphere(r=rad, center=true);
sphere(r=rad-thick, center=true);
translate([0,0,rad/2])
cube([rad*2,rad*2,rad],center=true);
module result () {
translate([0,0,24])
shell(20,1);
%3D_projection (30) 2D_shape();
result();
// shell(20,3);
http://forum.openscad.org/file/n20356/sample-_scale_extrude.png
View this message in context: http://forum.openscad.org/stereographic-projections-tp20339p20356.html
I'm not sure I understand it at first glance, but I love it! Thank you!
On 2/6/2017 9:58 PM, Neon22 wrote:
$fn=30;
module 2D_shape() {
offset(r=3) {
cube([rad2,rad2,rad],center=true);
module result () {
translate([0,0,24])
shell(20,1);
result();
// shell(20,3);
