Release Candidate: OpenSCAD-2026.11-RC1
Mon, Nov 23, 2026 10:40 PM
Hi all,
We just released OpenSCAD-2026.11-RC1
There has been a lot of activity. Thanks a lot to everyone reporting issues and helping fix them!
Since RC0, 3 weeks ago, we’ve merged ~66 Pull Requests, and we’re graduated several features from experimental.
Full change summary since RC0 follows.
Kind Regards,
Notable Changes & Feature Graduations
  • MCAD unbundled (#6982, #7226):
    The MCAD library is no longer bundled with OpenSCAD; it can be
    downloaded separately from:
    https://github.com/openscad/MCAD/releases/tag/2026.11
    OpenSCAD now prints a helpful warning if a design references MCAD
    when it is not installed.
  • import() for JSON and object() graduated out of experimental (#7097):
    • Objects now format using the JavaScript-like OEP8 syntax:
      { name: val, ... } (#7200)
    • Object equality comparison is now key-order-insensitive (#7176)
  • Predictable mesh output graduated out of experimental (#7229, #7231):
    3D mesh exports (STL, OFF, OBJ, VRML, 3MF, POV-Ray) are now always
    sorted for deterministic, diffable output.
  • New fragments() function (#6890):
    Returns the number of sides a circle with the given radius/diameter
    would have under the current $fn/$fa/$fs settings.
  • Windows Qt5 builds removed (#7236, #7238):
    Windows releases now exclusively use Qt6.
Geometry & Rendering
  • Manifold:
    • minkowski() now ignores unused/isolated points in convex polyhedra
      (#6833, #7263).
    • Automatically flip inside-out closed polyhedra to match CGAL
      backend behavior (#7209).
    • color(undef) now leaves child colors unchanged in F6 renders,
      matching preview behavior and avoiding invisible #00000000
      materials in 3MF export (#5853, #7249).
  • CGAL:
    • Retry vertex quantization on successively finer grids when
      quantization would invert or degenerate triangles, fixing CGAL
      binary operation assertion failures (#6582, #7251).
    • Pass explicit Nef halffacet normals to gluTessNormal() so
      floating-point noise on tricky polygons does not invert normals
      and cull facets (#5158).
  • Performance:
    • Avoid repeated memory reallocations when appending meshes (#7253).
  • OpenGL / Preview:
    • Fix crash with multiple windows open caused by VBO deletion
      running in the wrong OpenGL context (#7011).
    • Always use the GLSL shader in OpenCSGRenderer via a show_edges
      uniform (#7208, #7243).
    • Fix hang when drawing scale markers at a camera distance of 0
      (#7265).
    • Make axis indicator labels slightly larger and more readable
      (#7197).
Language, Parser & Stability
  • Fix ranges with more than 2^32 elements returning too few values
    (#7258).
  • Fix undefined behavior and memory leaks found via fuzzing and UBSan
    (#7257), including out-of-range integer conversions in the lexer,
    tan(), and chr(), and signed left-shift UB in <<.
  • Clean up parser/lexer state when parse() throws, and treat
    filesystem errors during path lookup like missing files (#7151).
  • Improve error location reporting for unsaved files (#7247, #7248).
  • Report an error instead of crashing when the current working
    directory no longer exists (#7268).
File Import / Export & Security
  • SVG Import:
    • Security: Disable XML entity expansion and external entity loading
      (XXE / entity bomb protection) (#7180), and limit <use> element
      expansion (#7192).
    • Fix crashes on <use> elements inside <defs> (#7233) and <polyline>
      elements with no points (#7259).
    • Fix import(..., center = true) centering when viewBox origin is
      not (0, 0) (#5670, #7215).
    • Fix XML string and reader memory leaks on error paths in libsvg
      (#7257).
  • OBJ Import:
    • Do not crash on unparsable or extra-whitespace face indices;
      support w coordinates, vertex colors ("v x y z r g b"), and
      negative (relative) face indices; fix off-by-one line numbers and
      warning messages (#7232).
  • JSON Import:
    • Fail on malformed JSON files that happen to begin with a valid
      JSON value (#7178).
  • DXF Import:
    • Ignore lines with non-finite (NaN/Inf) coordinates, including
      degenerate ellipses (#7257).
  • OFF Import:
    • Fix whitespace (e.g. tab) handling in nOFF headers.
  • 3MF Export:
    • Fix exporting to stdout when stdout is a pipe (and on macOS), and
      return a non-zero exit code when export fails (#6895, #7235).
  • SVG Export:
    • Properly XML-escape fill and stroke color values (#7241).
  • Locale-independent Export:
    • Remove setlocale() calls from STL, DXF, and SVG export and always
      write '.' as the decimal separator (#7186).
  • PNG Export (macOS):
    • Use lodepng instead of CoreGraphics on macOS for faster, smaller,
      and cross-platform-consistent PNG output (#7019).
GUI & Platform Fixes
  • Customizer: Ignore CR in CRLF line endings inside annotations
    (#7239).
  • SVG Export Dialog: Remember fill and stroke settings (#7266).
  • Export Dialog: Fix default file extension not being appended when
    modifying the filename during export (#5620).
  • Save a Copy: Report the copy's filename (rather than the original's)
    if opening for write fails (#7269).
  • About Dialog: List libraries added since the previous release
    (#7210) and pull the copyright year from the build environment
    (#7216).
  • Windows:
    • Fix opening use<> and include<> files with non-ASCII paths (#7207).
    • Keep UNC paths intact in use<>/include<> resolution (#7222), fall
      back safely in path shortening (#7187), and avoid aborting CLI
      export if changing the working directory fails (#7194).
  • Linux:
    • Fix StartupWMClass in the .desktop file (#7204, #7211).
Command-Line Interface & Documentation
  • Rename --animate_sharding to --animate-sharding (#7203).
  • Fix --trace-depth command-line option being ignored (#7189).
  • Warn on malformed, unknown, or out-of-range -O export options
    instead of silently ignoring them (#7240).
  • Update the man page with current CLI options, export formats, and
    color schemes (#7188).
  • Audit and update the 2026.11 release notes (releases/next.md)
    (#7183, #7237, #7261).
Build, Tests & Infrastructure
  • Point Clipper2 to the active PolyClipping/Clipper2 repository
    (#7218).
  • CMake: Add Fontconfig include directory on non-vcpkg builds (#7230)
    and simplify the OpenGL check for Qt6/libglvnd (#7196).
  • Decouple the test suite from MCAD (#7219, #7221, #7224, #7225),
    enable src/geometry unit tests (#7191), and add regression tests
    for linear_extrude(segments=...) (#7190) and SVG tessellation
    (#7220).
  • CI and release workflow updates (release artifact publishing
    workflow, CircleCI Xcode 26.2, CodeQL/schedule updates, cleanup).
Hi all, We just released OpenSCAD-2026.11-RC1 There has been a lot of activity. Thanks a lot to everyone reporting issues and helping fix them! Since RC0, 3 weeks ago, we’ve merged ~66 Pull Requests, and we’re graduated several features from experimental. Full change summary since RC0 follows. Kind Regards, -Marius Notable Changes & Feature Graduations ------------------------------------- * MCAD unbundled (#6982, #7226): The MCAD library is no longer bundled with OpenSCAD; it can be downloaded separately from: https://github.com/openscad/MCAD/releases/tag/2026.11 OpenSCAD now prints a helpful warning if a design references MCAD when it is not installed. * import() for JSON and object() graduated out of experimental (#7097): - Objects now format using the JavaScript-like OEP8 syntax: { name: val, ... } (#7200) - Object equality comparison is now key-order-insensitive (#7176) * Predictable mesh output graduated out of experimental (#7229, #7231): 3D mesh exports (STL, OFF, OBJ, VRML, 3MF, POV-Ray) are now always sorted for deterministic, diffable output. * New fragments() function (#6890): Returns the number of sides a circle with the given radius/diameter would have under the current $fn/$fa/$fs settings. * Windows Qt5 builds removed (#7236, #7238): Windows releases now exclusively use Qt6. Geometry & Rendering -------------------- * Manifold: - minkowski() now ignores unused/isolated points in convex polyhedra (#6833, #7263). - Automatically flip inside-out closed polyhedra to match CGAL backend behavior (#7209). - color(undef) now leaves child colors unchanged in F6 renders, matching preview behavior and avoiding invisible #00000000 materials in 3MF export (#5853, #7249). * CGAL: - Retry vertex quantization on successively finer grids when quantization would invert or degenerate triangles, fixing CGAL binary operation assertion failures (#6582, #7251). - Pass explicit Nef halffacet normals to gluTessNormal() so floating-point noise on tricky polygons does not invert normals and cull facets (#5158). * Performance: - Avoid repeated memory reallocations when appending meshes (#7253). * OpenGL / Preview: - Fix crash with multiple windows open caused by VBO deletion running in the wrong OpenGL context (#7011). - Always use the GLSL shader in OpenCSGRenderer via a show_edges uniform (#7208, #7243). - Fix hang when drawing scale markers at a camera distance of 0 (#7265). - Make axis indicator labels slightly larger and more readable (#7197). Language, Parser & Stability ---------------------------- * Fix ranges with more than 2^32 elements returning too few values (#7258). * Fix undefined behavior and memory leaks found via fuzzing and UBSan (#7257), including out-of-range integer conversions in the lexer, tan(), and chr(), and signed left-shift UB in <<. * Clean up parser/lexer state when parse() throws, and treat filesystem errors during path lookup like missing files (#7151). * Improve error location reporting for unsaved files (#7247, #7248). * Report an error instead of crashing when the current working directory no longer exists (#7268). File Import / Export & Security ------------------------------- * SVG Import: - Security: Disable XML entity expansion and external entity loading (XXE / entity bomb protection) (#7180), and limit <use> element expansion (#7192). - Fix crashes on <use> elements inside <defs> (#7233) and <polyline> elements with no points (#7259). - Fix import(..., center = true) centering when viewBox origin is not (0, 0) (#5670, #7215). - Fix XML string and reader memory leaks on error paths in libsvg (#7257). * OBJ Import: - Do not crash on unparsable or extra-whitespace face indices; support w coordinates, vertex colors ("v x y z r g b"), and negative (relative) face indices; fix off-by-one line numbers and warning messages (#7232). * JSON Import: - Fail on malformed JSON files that happen to begin with a valid JSON value (#7178). * DXF Import: - Ignore lines with non-finite (NaN/Inf) coordinates, including degenerate ellipses (#7257). * OFF Import: - Fix whitespace (e.g. tab) handling in nOFF headers. * 3MF Export: - Fix exporting to stdout when stdout is a pipe (and on macOS), and return a non-zero exit code when export fails (#6895, #7235). * SVG Export: - Properly XML-escape fill and stroke color values (#7241). * Locale-independent Export: - Remove setlocale() calls from STL, DXF, and SVG export and always write '.' as the decimal separator (#7186). * PNG Export (macOS): - Use lodepng instead of CoreGraphics on macOS for faster, smaller, and cross-platform-consistent PNG output (#7019). GUI & Platform Fixes -------------------- * Customizer: Ignore CR in CRLF line endings inside annotations (#7239). * SVG Export Dialog: Remember fill and stroke settings (#7266). * Export Dialog: Fix default file extension not being appended when modifying the filename during export (#5620). * Save a Copy: Report the copy's filename (rather than the original's) if opening for write fails (#7269). * About Dialog: List libraries added since the previous release (#7210) and pull the copyright year from the build environment (#7216). * Windows: - Fix opening use<> and include<> files with non-ASCII paths (#7207). - Keep UNC paths intact in use<>/include<> resolution (#7222), fall back safely in path shortening (#7187), and avoid aborting CLI export if changing the working directory fails (#7194). * Linux: - Fix StartupWMClass in the .desktop file (#7204, #7211). Command-Line Interface & Documentation -------------------------------------- * Rename --animate_sharding to --animate-sharding (#7203). * Fix --trace-depth command-line option being ignored (#7189). * Warn on malformed, unknown, or out-of-range -O export options instead of silently ignoring them (#7240). * Update the man page with current CLI options, export formats, and color schemes (#7188). * Audit and update the 2026.11 release notes (releases/next.md) (#7183, #7237, #7261). Build, Tests & Infrastructure ----------------------------- * Point Clipper2 to the active PolyClipping/Clipper2 repository (#7218). * CMake: Add Fontconfig include directory on non-vcpkg builds (#7230) and simplify the OpenGL check for Qt6/libglvnd (#7196). * Decouple the test suite from MCAD (#7219, #7221, #7224, #7225), enable src/geometry unit tests (#7191), and add regression tests for linear_extrude(segments=...) (#7190) and SVG tessellation (#7220). * CI and release workflow updates (release artifact publishing workflow, CircleCI Xcode 26.2, CodeQL/schedule updates, cleanup).
