Instead of painting, you can lightly melt the whitish parts with a heat
gun. I grant that this is also probably not an optimal solution.
On Fri, Feb 11, 2022 at 3:29 PM Terry terrypingm@gmail.com wrote:
Yes, tried that on a surplus print and looks awful. The black PLA becomes
whitish. No way I'm going to into painting!
Did you work out why the video didn't work?
I expect you'll have seen the identification of the cause of this unwanted
movement. But I haven't yet been able to stop it.
On Fri, 11 Feb 2022 18:47:59 +0000, you wrote:
If it is merely a case that you want to use it for your cooker knob?
then if a one off, being a pragmatist, I'd round the corners with a bit
of sandpaper ?.
Best wishes,
Ray
On 11/02/2022 17:50, Terry wrote:
Hi Ray,
Thanks. Just tried that. But as soon as I try clicking that I get same
behaviour.
Puzzled why you couldn't see my video? It plays OK here with a double
click, or
Right Click > Launch.
https://www.dropbox.com/s/1zmv1al5ovj7seg/FreeCADtest.mp4?raw=1
Do you have FreeCAD? If so could you try it please, with either the CSG
or SCAD?
Terry
On Fri, 11 Feb 2022 16:35:08 +0000, you wrote:
Hi Terry,
save the file as 'cube.scad', or whatever, as a normal openscad file.
In
freecad open that file. I couldn't see your video, so no idea what
that
was about.
There is an openscad workbench in freecad, which you may or may not
want
to use use.
Best wishes,
Ray
On 11/02/2022 15:19, Terry wrote:
Researching 'add fillets in OpenSCAD' one post reported that FreeCAD
can do so
much more easily. I want to test that, before attempting to use it on
replacement control knob I posted about earlier.
I downloaded and installed FreeCAD. I exported a cube from OpenSCAD
as a CSG and
imported it into FreeCAD. But as a complete FreeCAD beginner I was
lost at the
first hurdle because the model then started zooming in, and nothing I
did would
stop it. I'm discussing in the FreeCAD forum, but so far no solution.
Has anyone here successfully done this please? Does OpenSCAD export
reliably?
FWIW here are the screenshots and video I posted to the FreeCAD forum:
https://www.dropbox.com/s/jfoiqz98nck19az/1-CubeInOpenSCAD.jpg?raw=1
https://www.dropbox.com/s/keizusx5bufuu1x/3.%20Open%20CSG.jpg?raw=1
Video (4 MB)
Terry
