Sat, Feb 12, 2022 3:10 PM
Adrian:
You are, of course, correct. I can emit each STL separately using
command line scripts. It will take writing a lot of command line code
and a lot more OpenSCAD code, which would be unnecessary with my
hypothetical code, but I guess that's were I'm heading.
I am already getting a lot of errors with my command line attempts. Are
there any working examples somewhere?
This
https://en.wikibooks.org/wiki/OpenSCAD_User_Manual/Using_OpenSCAD_in_a_command_line_environment
has documentation but no working examples.
For example, if I put this in my command line:
-D mod="Spiral"
I get
WARNING: Ignoring unknown variable 'Spiral'
I am trying to assign the string "Spiral" to the variable/constant
"mod". Do I have to create the "mod" variable in my program first? I
have tried it both ways.
I'm sure that once I get this set up, it will work well, but I'm in the
frustrating phase at the moment.
Thanks!
On 2/12/2022 9:43 AM, Adrian Mariano wrote:
I think you can do something sort of like that with scripting, where
you run OpenSCAD from the command line, pass in parameters with -D to
tell it what to do, and use -o to tell it to save the STL with the
appropriate name.
On Sat, Feb 12, 2022 at 9:23 AM jon jon@jonbondy.com wrote:
Yes, if OpenSCAD had a way to export an STL on command, then I could
emit all of the STLs trivially and then collect them and position them
in PrusaSlicer.
So, if my current code looks (schematically) like
for (x = [1:3])
for (y = [1:3])
translate([x*10, y*10, 0])
cookie(x, y);
new hypothetical code (excuse the poor string syntax) could look like
for (x = [1:3])
for (y = [1:3])
export_stl("cookie" + x + "," + y + ".stl")
cookie(x, y);
I do not believe that OpenSCAD supports this, but I now have a good
personal use case for this kind of feature
On 2/12/2022 8:37 AM, Adrian Mariano wrote:
So my understanding is that if you create a module and pass your
objects as children, then if that module passes (some of its) children
to a submodule, the children are all unioned into one object. This
makes it impossible to pass children around in a powerful, flexible
way. The new experimental lazy union feature may fix this, but I
think it only sometimes skipped the union, so I'm not sure.
Assuming that you can't go that route, then, when you have to do is
work with the bounding boxes to compute object positions. So you
precompute bounding box info and put it in a list. Invoke your
recursive 2d layout fnction. The result is a list of object
positions. Once you have all the positions, you can then position all
the objects on those positions using a simple loop, though it seems
like you'll need a giant cascading if statement to the object with
index i. So once you have a position list you can do something like
for(i=[0:N]) translate(pos[i]) object(i) where object() is a module
that produces all the objects based on the index number. Thiis would
be pretty easy to do if you had a 1d spacing problem but in 2d it
seems like it's going to be tricky. Like if you want to pursue this,
try to solve the 1d problem first.
My slicer has a button that does this. If yours doesn't...might
consider switching slicers.
On Fri, Feb 11, 2022 at 10:25 PM jon jon@jonbondy.com wrote:
Adrian:
Thank you!
Imagine I am creating a series of cookies. Some are of Santa. Some are
of reindeer. Some are Christmas tree ornaments. So there are three
different cookie generators, one for Santas, one for reindeer, and one
for ornaments. Each generator creates a series of sizes, so each
generator might create 5 different objects, for a total of 15.
How would I do this? Create each object in each generator and stuff the
15 into some data structure, and then pass the data structure into the
recursive routine? The part of your suggestion that has me stuck is the
"it does one object at a time". They are not all generated from one
piece of code, but from three, and I don't see how to store them for
processing by the recursion.
On 2/11/2022 9:30 PM, Adrian Mariano wrote:
I don't know if it's "nice", but it OpenSCAD the way to do that is
with recursion. You write a function to generate the positions of all
the objects. It does one object at a time and the state information
(x, y, which objects are left, and the list of positions determined)
is passed to a recursive call. When there are no objects left you
return the list of positions.
On Fri, Feb 11, 2022 at 9:23 PM jon jon@jonbondy.com wrote:
I am generating perhaps 100 2D objects with varying sizes and shapes
(they are not all the same width as depth). I want to place the objects
in a fairly tightly packed array for printing, with perhaps 2 mm between
each object. I know the 2D bounding box of each item. In a "regular"
programming language I would have X and Y variables which I incremented
as I added each object. Is there a nice way to do this in OpenSCAD?
Adrian:
This
-D mod="Spiral"
I get
Thanks!
> appropriate name.
>> in PrusaSlicer.
>> for (x = [1:3])
>> for (y = [1:3])
>> cookie(x, y);
>> for (x = [1:3])
>> for (y = [1:3])
>> cookie(x, y);
>> Jon
>>> think it only *sometimes* skipped the union, so I'm not sure.
>>> On Fri, Feb 11, 2022 at 10:25 PM jon <jon@jonbondy.com> wrote:
>>>> Adrian:
>>>> Thank you!
>>>>>> _______________________________________________
>>>>>> OpenSCAD mailing list
>>>>>> To unsubscribe send an email to discuss-leave@lists.openscad.org
