JW
Joe Weinpert
Wed, Jan 12, 2022 8:49 PM
I have many, many odd 2D shapes that will be imported over the next few
months.
I have no problem importing or extruding them.
However, I do have the need for the top edge to be rounded around the whole
shape as it is imported or extruded. In other words, a rounded chamfer
around the top.
The attached example 2D shape is about 5" wide overall in real-time and is
to be extruded to 1" high. What can be done to have this extrusion contain
a small, 1/4" radius chamfer around the top?
Any ideas?
Joe Weinpert
months.
around the top.
Any ideas?
Joe Weinpert
Wed, Jan 12, 2022 10:51 PM
The only good way I know to do this is using offset_sweep() from BOSL2
as I already explained in the thread about adding a "dome" to the top.
(I actually wrote offset_sweep specifically to solve this problem of
adding a roundover to an arbitrary shape.) Instead of importing the
SVG you will need to convert it somehow to a point list that you can
then embed into OpenSCAD. The only fully general alternative I'm
aware of (that works on concave inputs) is to make a stair-step shape
by stacking a sequence of smaller and smaller layers.
On Wed, Jan 12, 2022 at 3:52 PM Joe Weinpert joe.weinpert@gmail.com wrote:
I have many, many odd 2D shapes that will be imported over the next few months.
However, I do have the need for the top edge to be rounded around the whole shape as it is imported or extruded. In other words, a rounded chamfer around the top.
The attached example 2D shape is about 5" wide overall in real-time and is to be extruded to 1" high. What can be done to have this extrusion contain a small, 1/4" radius chamfer around the top?
Any ideas?
Joe Weinpert
> Any ideas?
> Joe Weinpert
Wed, Jan 12, 2022 10:59 PM
A stair step solution I've used is at
https://www.thingiverse.com/thing:2461392/comments but there was an
error (typo iirc) in the code, which was easy to correct. No idea if it
will work on the sort of shapes in the svg, and it is slow.
Any ideas?
Joe Weinpert
>> Any ideas?
>> Joe Weinpert
JW
Joe Weinpert
Wed, Jan 12, 2022 11:00 PM
Thanks. The 'step' procedure is something I've been experimenting with.
It is both good and bad.
Where can I find the BOSL2 library?
The 'point list' is what? X/Y coordinates along the shape's edge?
> months.
> > Any ideas?
> > Joe Weinpert
JW
Joe Weinpert
Wed, Jan 12, 2022 11:07 PM
I shall look ... thanks
> months.
> >> Any ideas?
> >> Joe Weinpert
Wed, Jan 12, 2022 11:18 PM
Personally I think the step procedure is pretty ugly. If you are
trying to approximate a curve you need many steps, so it is also slow.
It works well only when the curve in convex, because in that case you
can use hull() to create sloped edges on the layers, and then the
result looks good.
BOSL2 is located here:
https://github.com/revarbat/BOSL2
And the specific function you need is this one:
https://github.com/revarbat/BOSL2/wiki/rounding.scad#functionmodule-offset_sweep
By point list, yes, you need the (x,y) coordinates along the shapes
edge. So your code would look like
include<BOSL2/std.scad>
include<BOSL2/rounding.scad>
shape = [[3,4],[10,10],...etc]; // Shape defined as list of (x,y)
coordinates, without repeating the first point.
offset_sweep(shape, height=1INCH, top=os_circle(r=1/4INCH)); //
Assume model is in metric but you want inches
On Wed, Jan 12, 2022 at 6:00 PM Joe Weinpert joe.weinpert@gmail.com wrote:
Thanks. The 'step' procedure is something I've been experimenting with. It is both good and bad.
Any ideas?
Joe Weinpert
result looks good.
offset_sweep(shape, height=1*INCH, top=os_circle(r=1/4*INCH)); //
>> > Any ideas?
>> > Joe Weinpert
F
fred
Wed, Jan 12, 2022 11:23 PM
I'm not sure this is related, but the original mention referenced importing an SVG, and a following message suggested that would not work.I think that portion can be resolved with Inkscape (free, multi-platform) with the extension Paths to OpenSCAD. My experience is that the extension works with Inkscape 0.92 but I'm not sure if it works with Inkscape 1.x
If you have clean, closed SVG file, you specify thickness and the extension extrudes the shape defined by the SVG converting it to OpenSCAD code quite nicely.
If the SVG is a collection of closed shapes, fill the shape in order to keep empty space separated from filled shapes. If there are non-closed shapes (lines), use the thickness setting in the extension to ensure a result with thickness from the extrude.
Wed, Jan 12, 2022 11:57 PM
few months.
Any ideas?
If you can get the shape as a sequence of X,Y points P1, with a desired
height H, another strategy is to do it something like so:
- Find an offset function that will offset P1 inward 1/4". (I think
BOSL2 has one.) Call this path P2.
- Sweep a 1/4" radius circle around P2, and translate it up by H minus
1/4". This forms your rounded edge.
- Extrude P2 to height H.
- Offset P2 outward 1/4". This is mostly, but not quite, the same
as the original. Call this path P3.
- Extrude P3 to H minus 1/4".
With respect to the "step" scheme... it's not that awful, for small
values, if the destination is 3D printing. Remember that your printer
has finite resolution. It only needs to be 1/4" tall, or about 6mm. At
0.3mm layers, you only need ~21 layers. At 0.1mm layers, ~64 layers.
> few months.
> Any ideas?
* Find an offset function that will offset P1 inward 1/4". (I think
* Sweep a 1/4" radius circle around P2, and translate it up by H minus
* Extrude P2 to height H.
* Offset P2 *outward* 1/4". This is mostly, but not quite, the same
* Extrude P3 to H minus 1/4".
With respect to the "step" scheme... it's not *that* awful, for small
Thu, Jan 13, 2022 1:01 AM
The strategy you propose, of sweeping a circle around the edge, is
less robust than using offset_sweep() and I think also less efficient.
Note that offset_sweep() is basically a function that organizes calls
to offset() to make life easier. The real work and real challenge is
in providing the offset() function. But offset sweep is actually a
better behaved operation than path sweep. It will almost always work.
With path_sweep, if P2 has high sampling rate or sharp turns you're
very likely to get a non-manifold result when sweeping a circle along
P2. I actually wrote a limited path_sweep2d that avoids these
non-manifold issues by reinterpreting a path sweep as a set of offset
operations to exploit the increased robustness of offsetting.
You can call it a personal quirk, but I hate looking at the moire
pattern surfaces that arise when you pack in lots of layers to make a
bad approximation scheme (like stair stepping) give tolerable results.
I think it's hard to tell what those surfaces are actually doing.
(That matters less for a tiny roundover than in other contexts.) I
agree, though, that it can work in practice when you go to print your
model.
On Wed, Jan 12, 2022 at 6:57 PM Jordan Brown
Any ideas?
If you can get the shape as a sequence of X,Y points P1, with a desired height H, another strategy is to do it something like so:
Find an offset function that will offset P1 inward 1/4". (I think BOSL2 has one.) Call this path P2.
Sweep a 1/4" radius circle around P2, and translate it up by H minus 1/4". This forms your rounded edge.
Offset P2 outward 1/4". This is mostly, but not quite, the same as the original. Call this path P3.
With respect to the "step" scheme... it's not that awful, for small values, if the destination is 3D printing. Remember that your printer has finite resolution. It only needs to be 1/4" tall, or about 6mm. At 0.3mm layers, you only need ~21 layers. At 0.1mm layers, ~64 layers.
model.
> Any ideas?
> Offset P2 *outward* 1/4". This is mostly, but not quite, the same as the original. Call this path P3.
> With respect to the "step" scheme... it's not *that* awful, for small values, if the destination is 3D printing. Remember that your printer has finite resolution. It only needs to be 1/4" tall, or about 6mm. At 0.3mm layers, you only need ~21 layers. At 0.1mm layers, ~64 layers.
Thu, Jan 13, 2022 2:16 AM
I think someone with good advance understanding of openscad should make
video tutorials with some test cases.
That will really help a lot of us learn faster.
The videos available seem to be quite old and not very helpful for some
advance modeling purpose
model.
> model.
