Re: [OpenSCAD] Discuss Digest, Vol 9, Issue 1
DE
David Eccles (gringer)
Sun, Aug 2, 2015 4:48 AM
On Fri, 31 Jul 2015 19:27:31 -0700 (MST) Steve wrote:
I have written an Instructable with some more advanced topics.  I think it
will have more value to members of this forum than my introductory one.
I noticed the following text in your instructable:
"One should not expect to do many things one would do with most programming languages. Unfortunately, it was a little too limited, the
recent addition of list comprehensions has been a huge addition to OpenSCAD."
I beg to differ. It just takes a bit of brain twisting to get the hang of functional languages and recursive list structures:
http://www.thingiverse.com/thing:942566/
Check out ellerscad_v4.scad, where I have various [recursive] functions involving dynamic arrays without involving list comprehensions. You
just have to store your variables as the arguments of the function.
  • David
On Fri, 31 Jul 2015 19:27:31 -0700 (MST) Steve wrote: > I have written an Instructable with some more advanced topics. I think it > will have more value to members of this forum than my introductory one. I noticed the following text in your instructable: "One should not expect to do many things one would do with most programming languages. Unfortunately, it was a little too limited, the recent addition of list comprehensions has been a huge addition to OpenSCAD." I beg to differ. It just takes a bit of brain twisting to get the hang of functional languages and recursive list structures: http://www.thingiverse.com/thing:942566/ Check out ellerscad_v4.scad, where I have various [recursive] functions involving dynamic arrays without involving list comprehensions. You just have to store your variables as the arguments of the function. - David
Sun, Aug 2, 2015 7:10 AM
2015.03 didn't just add list comprehensions, it also added 'concat'. With
concat, a function can now return a list whose length is determined at run
time. Before these additions, I agree that OpenSCAD was "a little too
limited".
On 2 August 2015 at 00:48, David Eccles (gringer) <
it
OpenSCAD."
  • David
2015.03 didn't just add list comprehensions, it also added 'concat'. With concat, a function can now return a list whose length is determined at run time. Before these additions, I agree that OpenSCAD was "a little too limited". On 2 August 2015 at 00:48, David Eccles (gringer) < bioinformatics@gringene.org> wrote: > On Fri, 31 Jul 2015 19:27:31 -0700 (MST) Steve wrote: > > I have written an Instructable with some more advanced topics. I think > it > > will have more value to members of this forum than my introductory one. > > I noticed the following text in your instructable: > > "One should not expect to do many things one would do with most > programming languages. Unfortunately, it was a little too limited, the > recent addition of list comprehensions has been a huge addition to > OpenSCAD." > > I beg to differ. It just takes a bit of brain twisting to get the hang of > functional languages and recursive list structures: > > http://www.thingiverse.com/thing:942566/ > > Check out ellerscad_v4.scad, where I have various [recursive] functions > involving dynamic arrays without involving list comprehensions. You > just have to store your variables as the arguments of the function. > > - David > > _______________________________________________ > OpenSCAD mailing list > Discuss@lists.openscad.org > http://lists.openscad.org/mailman/listinfo/discuss_lists.openscad.org > >
S
sgraves
Mon, Aug 3, 2015 2:39 AM
Going through the digest, I came across this message.  If it had been made in
the original topic I would have responded sooner.
gear_trains.scad http://forum.openscad.org/file/n13421/gear_trains.scad
The uploaded file is from a series of files I am working on.  There is a
file for describing gears and another file with gear mounting options.  But
I think you will see in this file that I understand the power of OpenSCAD
and how to write very powerful functions.
But the point I was trying to make was that OpenSCAD is not procedural
language and nor should it be.  I am trying very hard to impress on people
that it doesn't necessarily make sense for it to have run time variables.
Someday someone might come up with a method to shoe horn OpenSCAD into a run
time environment.  I don't think it is a very fruitful endeavor however.
OpenSCAD does what it is supposed to do very well.  In fact, better than any
other language.  The way I see it, the developers are making great choices
about the which areas to work on next.
And list comprehensions is a huge step.  It has given us many things that
make it possible to make almost anything.  I once read somewhere that
OpenSCAD is not good for organic shapes.  Well that is no longer true.  I am
hard pressed to come up with something it can't do now.
The thing I am using a lot is sweeps.  It is replacing the unioned hulls.
In my gears.scad file I was creating gears using the cutting gears concept.
I was able to create spiral gears with unioned hulls.  But there was a big
problem doing them.  With bevel gears I could hull the trapezoidal shapes
and ultimately I was able to speed things up greatly with a scaled
linear_extrude of the trapezoidal shape.  But the spiral gears resist any
simple solution like that.  The sweep solves those problems.  In fact I am
looking at using the sweep to directly generate the spiral gear teeth and
skipping the cutting gear.  I expect it to be orders of magnitude faster
than my present approach.
Steve
View this message in context: http://forum.openscad.org/Re-Discuss-Digest-Vol-9-Issue-1-tp13395p13421.html
Going through the digest, I came across this message. If it had been made in the original topic I would have responded sooner. gear_trains.scad <http://forum.openscad.org/file/n13421/gear_trains.scad> The uploaded file is from a series of files I am working on. There is a file for describing gears and another file with gear mounting options. But I think you will see in this file that I understand the power of OpenSCAD and how to write very powerful functions. But the point I was trying to make was that OpenSCAD is not procedural language and nor should it be. I am trying very hard to impress on people that it doesn't necessarily make sense for it to have run time variables. Someday someone might come up with a method to shoe horn OpenSCAD into a run time environment. I don't think it is a very fruitful endeavor however. OpenSCAD does what it is supposed to do very well. In fact, better than any other language. The way I see it, the developers are making great choices about the which areas to work on next. And list comprehensions is a huge step. It has given us many things that make it possible to make almost anything. I once read somewhere that OpenSCAD is not good for organic shapes. Well that is no longer true. I am hard pressed to come up with something it can't do now. The thing I am using a lot is sweeps. It is replacing the unioned hulls. In my gears.scad file I was creating gears using the cutting gears concept. I was able to create spiral gears with unioned hulls. But there was a big problem doing them. With bevel gears I could hull the trapezoidal shapes and ultimately I was able to speed things up greatly with a scaled linear_extrude of the trapezoidal shape. But the spiral gears resist any simple solution like that. The sweep solves those problems. In fact I am looking at using the sweep to directly generate the spiral gear teeth and skipping the cutting gear. I expect it to be orders of magnitude faster than my present approach. Steve -- View this message in context: http://forum.openscad.org/Re-Discuss-Digest-Vol-9-Issue-1-tp13395p13421.html Sent from the OpenSCAD mailing list archive at Nabble.com.
S
sgraves
Mon, Aug 3, 2015 2:55 AM
I haven't worked on the gear stuff for a few months.  But I think the
animation at the link below is of the example gear train found at the bottom
of the file.
http://www.highergraphics.com/pub/gear_train.avi
Steve
View this message in context: http://forum.openscad.org/Re-Discuss-Digest-Vol-9-Issue-1-tp13395p13422.html
I haven't worked on the gear stuff for a few months. But I think the animation at the link below is of the example gear train found at the bottom of the file. http://www.highergraphics.com/pub/gear_train.avi <http://www.highergraphics.com/pub/gear_train.avi> Steve -- View this message in context: http://forum.openscad.org/Re-Discuss-Digest-Vol-9-Issue-1-tp13395p13422.html Sent from the OpenSCAD mailing list archive at Nabble.com.
S
sgraves
Mon, Aug 3, 2015 2:58 AM
BTW, the maze creation is very clever.  And I get that you understand how to
use OpenSCAD functions.
Steve
it
OpenSCAD."
  • David
Discuss@.openscad
View this message in context: http://forum.openscad.org/Re-Discuss-Digest-Vol-9-Issue-1-tp13395p13423.html
BTW, the maze creation is very clever. And I get that you understand how to use OpenSCAD functions. Steve David Eccles (gringer) wrote > On Fri, 31 Jul 2015 19:27:31 -0700 (MST) Steve wrote: >> I have written an Instructable with some more advanced topics. I think >> it >> will have more value to members of this forum than my introductory one. > > I noticed the following text in your instructable: > > "One should not expect to do many things one would do with most > programming languages. Unfortunately, it was a little too limited, the > recent addition of list comprehensions has been a huge addition to > OpenSCAD." > > I beg to differ. It just takes a bit of brain twisting to get the hang of > functional languages and recursive list structures: > > http://www.thingiverse.com/thing:942566/ > > Check out ellerscad_v4.scad, where I have various [recursive] functions > involving dynamic arrays without involving list comprehensions. You > just have to store your variables as the arguments of the function. > > - David > > _______________________________________________ > OpenSCAD mailing list > Discuss@.openscad > http://lists.openscad.org/mailman/listinfo/discuss_lists.openscad.org -- View this message in context: http://forum.openscad.org/Re-Discuss-Digest-Vol-9-Issue-1-tp13395p13423.html Sent from the OpenSCAD mailing list archive at Nabble.com.
