Why doesn't my text show up?
BR
Bob Roos
Tue, Dec 7, 2021 3:26 AM
Hello OpenSCAD,
The text shows if I use Echo and it shows if quoted, but not if I reference it as Text[i]
So it doesn't know that is a string?
Thank you;
// Planer Info
// Bob Roos
// December 6, 2021
Size = 10;
Space = 12;
H = 90;
T = 3;
W = 90;
Text = [
["Max Width -- 15in "],
["Max Thickness -- 6in "],
["Min Length -- 6in "],
["Min Thickness -- 3/16in "],
["1 turn = 2mm -- recommended 1/2 turn per pass" ],
["Vary use of sides and middle to spread wear"],
["NO plywood, particle board, endgrain, mesquite"]
for (i = [0:len(Text)-1]){
//    echo(Text[i]);
translate([0,i*Space,0]) linear_extrude(T) text(Text[i],size=Size);
linear_extrude(T) text(size=10,"Text[1]");
Best regards,
Hello OpenSCAD, The text shows if I use Echo and it shows if quoted, but not if I reference it as Text[i] So it doesn't know that is a string? Thank you; // Planer Info // Bob Roos // December 6, 2021 Size = 10; Space = 12; H = 90; T = 3; W = 90; Text = [ ["Max Width -- 15in "], ["Max Thickness -- 6in "], ["Min Length -- 6in "], ["Min Thickness -- 3/16in "], ["1 turn = 2mm -- recommended 1/2 turn per pass" ], ["Vary use of sides and middle to spread wear"], ["NO plywood, particle board, endgrain, mesquite"] ]; for (i = [0:len(Text)-1]){ // echo(Text[i]); translate([0,i*Space,0]) linear_extrude(T) text(Text[i],size=Size); } linear_extrude(T) text(size=10,"Text[1]"); -- Best regards, Bob mailto:roosbob@wybatap.com
BR
Bob Roos
Tue, Dec 7, 2021 3:32 AM
Hi Bob,
Yes, it did not know that was a string until you tell it:
str(Text[i])
Thanks
Monday, December 6, 2021, 10:26:55 PM, you wrote:
Hello OpenSCAD,
Thank you;
// Planer Info
// Bob Roos
// December 6, 2021
Size = 10;
Space = 12;
H = 90;
T = 3;
W = 90;
Text = [
//    echo(Text[i]);
have Fun,
Hi Bob, Yes, it did not know that was a string until you tell it: str(Text[i]) Thanks Monday, December 6, 2021, 10:26:55 PM, you wrote: > Hello OpenSCAD, > The text shows if I use Echo and it shows if quoted, but not if I reference it as Text[i] > So it doesn't know that is a string? > Thank you; > // Planer Info > // Bob Roos > // December 6, 2021 > Size = 10; > Space = 12; > H = 90; > T = 3; > W = 90; > Text = [ > ["Max Width -- 15in "], > ["Max Thickness -- 6in "], > ["Min Length -- 6in "], > ["Min Thickness -- 3/16in "], > ["1 turn = 2mm -- recommended 1/2 turn per pass" ], > ["Vary use of sides and middle to spread wear"], > ["NO plywood, particle board, endgrain, mesquite"] > ]; > for (i = [0:len(Text)-1]){ > // echo(Text[i]); > translate([0,i*Space,0]) linear_extrude(T) text(Text[i],size=Size); > } > linear_extrude(T) text(size=10,"Text[1]"); -- have Fun, Bob mailto:roosbob@wybatap.com
Tue, Dec 7, 2021 5:22 AM
Your Text is a vector, with 7 elements, each element is a vector of length 1, containing the
string.
[                // start outside vector
["string1"],  // a vector containing a string
"string2"      // just a string
]                // end of outside vector
You probably want a vector of strings, like so:
Text = [
"Max Width -- 15in ",
"Max Thickness -- 6in ",
"Min Length -- 6in ",
"Min Thickness -- 3/16in ],
"1 turn = 2mm -- recommended 1/2 turn per pass",
"Vary use of sides and middle to spread wear",
When, with your original Text vector of vectors, str(Text[i]) returns
a vector of length one containing a string, not the '[' & ']' in the output,
that is str() formatting the text to represent a vector.
Sent: Tue, 7 Dec 2021 14:33
Subject: [OpenSCAD] Re: Why doesn't my text show up?
Hi Bob,
str(Text[i])
Thanks
Hello OpenSCAD,
Text[i]
Thank you;
// Planer Info
// Bob Roos
// December 6, 2021
Size = 10;
Space = 12;
H = 90;
T = 3;
W = 90;
Text = [
//    echo(Text[i]);
have Fun,
Your Text is a vector, with 7 elements, each element is a vector of length 1, containing the string. [ // start outside vector ["string1"], // a vector containing a string "string2" // just a string ] // end of outside vector You probably want a vector of strings, like so: Text = [ "Max Width -- 15in ", "Max Thickness -- 6in ", "Min Length -- 6in ", "Min Thickness -- 3/16in ], "1 turn = 2mm -- recommended 1/2 turn per pass", "Vary use of sides and middle to spread wear", "NO plywood, particle board, endgrain, mesquite" ]; When, with your original Text vector of vectors, str(Text[i]) returns a vector of length one containing a string, not the '[' & ']' in the output, that is str() formatting the text to represent a vector. > -----Original Message----- > From: Bob Roos [mailto:roosbob@wybatap.com] > Sent: Tue, 7 Dec 2021 14:33 > To: OpenSCAD general discussion > Subject: [OpenSCAD] Re: Why doesn't my text show up? > > Hi Bob, > > Yes, it did not know that was a string until you tell it: > > str(Text[i]) > > Thanks > > Monday, December 6, 2021, 10:26:55 PM, you wrote: > > Hello OpenSCAD, > > > The text shows if I use Echo and it shows if quoted, but not if I reference it as > Text[i] > > > So it doesn't know that is a string? > > > Thank you; > > > // Planer Info > > // Bob Roos > > // December 6, 2021 > > Size = 10; > > Space = 12; > > H = 90; > > T = 3; > > W = 90; > > Text = [ > > ["Max Width -- 15in "], > > ["Max Thickness -- 6in "], > > ["Min Length -- 6in "], > > ["Min Thickness -- 3/16in "], > > ["1 turn = 2mm -- recommended 1/2 turn per pass" ], > > ["Vary use of sides and middle to spread wear"], > > ["NO plywood, particle board, endgrain, mesquite"] > > ]; > > > for (i = [0:len(Text)-1]){ > > // echo(Text[i]); > > translate([0,i*Space,0]) linear_extrude(T) text(Text[i],size=Size); > > } > > linear_extrude(T) text(size=10,"Text[1]"); > > > > -- > have Fun, > Bob mailto:roosbob@wybatap.com > _______________________________________________ > OpenSCAD mailing list > To unsubscribe send an email to discuss-leave@lists.openscad.org -- This email has been checked for viruses by AVG. https://www.avg.com
Michael Marx
Tue, Dec 7, 2021 5:34 AM
Sorry, badly phrased, make that
When, with your original Text vector of vectors, Text[i] returns
a vector of length one containing a string, then str() formats that
vector into a string, note the '[' & ']' in the output,
that is str() formatting it to represent a vector.
With str("string") it would not have '[' & ']'.
Sent: Tue, 7 Dec 2021 16:23
string.
Text = [
Hi Bob,
str(Text[i])
Thanks
Hello OpenSCAD,
Text[i]
Thank you;
// Planer Info
// Bob Roos
// December 6, 2021
Size = 10;
Space = 12;
H = 90;
T = 3;
W = 90;
Text = [
//    echo(Text[i]);
have Fun,
Sorry, badly phrased, make that > When, with your original Text vector of vectors, Text[i] returns > a vector of length one containing a string, then str() formats that > vector into a string, note the '[' & ']' in the output, > that is str() formatting it to represent a vector. With str("string") it would not have '[' & ']'. > -----Original Message----- > From: MichaelAtOz [mailto:oz.at.michael@gmail.com] > Sent: Tue, 7 Dec 2021 16:23 > To: 'OpenSCAD general discussion' > Subject: [OpenSCAD] Re: Why doesn't my text show up? > > Your Text is a vector, with 7 elements, each element is a vector of length 1, containing > the > string. > > [ // start outside vector > ["string1"], // a vector containing a string > "string2" // just a string > ] // end of outside vector > > You probably want a vector of strings, like so: > > Text = [ > "Max Width -- 15in ", > "Max Thickness -- 6in ", > "Min Length -- 6in ", > "Min Thickness -- 3/16in ], > "1 turn = 2mm -- recommended 1/2 turn per pass", > "Vary use of sides and middle to spread wear", > "NO plywood, particle board, endgrain, mesquite" > ]; > > When, with your original Text vector of vectors, str(Text[i]) returns > a vector of length one containing a string, not the '[' & ']' in the output, > that is str() formatting the text to represent a vector. > > > > -----Original Message----- > > From: Bob Roos [mailto:roosbob@wybatap.com] > > Sent: Tue, 7 Dec 2021 14:33 > > To: OpenSCAD general discussion > > Subject: [OpenSCAD] Re: Why doesn't my text show up? > > > > Hi Bob, > > > > Yes, it did not know that was a string until you tell it: > > > > str(Text[i]) > > > > Thanks > > > > Monday, December 6, 2021, 10:26:55 PM, you wrote: > > > Hello OpenSCAD, > > > > > The text shows if I use Echo and it shows if quoted, but not if I reference it as > > Text[i] > > > > > So it doesn't know that is a string? > > > > > Thank you; > > > > > // Planer Info > > > // Bob Roos > > > // December 6, 2021 > > > Size = 10; > > > Space = 12; > > > H = 90; > > > T = 3; > > > W = 90; > > > Text = [ > > > ["Max Width -- 15in "], > > > ["Max Thickness -- 6in "], > > > ["Min Length -- 6in "], > > > ["Min Thickness -- 3/16in "], > > > ["1 turn = 2mm -- recommended 1/2 turn per pass" ], > > > ["Vary use of sides and middle to spread wear"], > > > ["NO plywood, particle board, endgrain, mesquite"] > > > ]; > > > > > for (i = [0:len(Text)-1]){ > > > // echo(Text[i]); > > > translate([0,i*Space,0]) linear_extrude(T) text(Text[i],size=Size); > > > } > > > linear_extrude(T) text(size=10,"Text[1]"); > > > > > > > > -- > > have Fun, > > Bob mailto:roosbob@wybatap.com > > _______________________________________________ > > OpenSCAD mailing list > > To unsubscribe send an email to discuss-leave@lists.openscad.org > > > -- > This email has been checked for viruses by AVG. > https://www.avg.com > _______________________________________________ > OpenSCAD mailing list > To unsubscribe send an email to discuss-leave@lists.openscad.org
BR
Bob Roos
Tue, Dec 7, 2021 9:53 AM
Hi Michael,
Yes,  Thank you.  I learned the hard way when I could finally see my text on image.
I love OpenSCAD and there is so much to learn!
One problem is that I keep putting semicolons at the end of lines in y other programming language.  ;)
Bob
string.
Text = [
Hi Bob,
str(Text[i])
Thanks
Hello OpenSCAD,
Text[i]
Thank you;
// Planer Info
// Bob Roos
// December 6, 2021
Size = 10;
Space = 12;
H = 90;
T = 3;
W = 90;
Text = [
//    echo(Text[i]);
have Fun,
Virus-free. www.avg.com
have Fun,
Hi Michael, Yes,  Thank you.  I learned the hard way when I could finally see my text on image. I love OpenSCAD and there is so much to learn!    One problem is that I keep putting semicolons at the end of lines in y other programming language.  ;)   Bob Tuesday, December 7, 2021, 12:34:25 AM, you wrote: > Sorry, badly phrased, make that >   >> When, with your original Text vector of vectors, Text[i] returns >> a vector of length one containing a string, then str() formats that >> vector into a string, note the '[' & ']' in the output, >> that is str() formatting it to represent a vector. >   > With str("string") it would not have '[' & ']'. >   >   >   >> -----Original Message----- >> From: MichaelAtOz [mailto:oz.at.michael@gmail.com] >> Sent: Tue, 7 Dec 2021 16:23 >> To: 'OpenSCAD general discussion' >> Subject: [OpenSCAD] Re: Why doesn't my text show up? >> >> Your Text is a vector, with 7 elements, each element is a vector of length 1, containing >> the >> string. >> >> [                // start outside vector >>   ["string1"],   // a vector containing a string >>   "string2"      // just a string >> ]                // end of outside vector >> >> You probably want a vector of strings, like so: >> >> Text = [ >> "Max Width -- 15in ", >> "Max Thickness -- 6in ", >> "Min Length -- 6in ", >> "Min Thickness -- 3/16in ], >> "1 turn = 2mm -- recommended 1/2 turn per pass", >> "Vary use of sides and middle to spread wear", >> "NO plywood, particle board, endgrain, mesquite" >> ]; >> >> When, with your original Text vector of vectors, str(Text[i]) returns >> a vector of length one containing a string, not the '[' & ']' in the output, >> that is str() formatting the text to represent a vector. >> >> >> > -----Original Message----- >> > From: Bob Roos [mailto:roosbob@wybatap.com] >> > Sent: Tue, 7 Dec 2021 14:33 >> > To: OpenSCAD general discussion >> > Subject: [OpenSCAD] Re: Why doesn't my text show up? >> > >> > Hi Bob, >> > >> > Yes, it did not know that was a string until you tell it: >> > >> > str(Text[i]) >> > >> > Thanks >> > >> > Monday, December 6, 2021, 10:26:55 PM, you wrote: >> > > Hello OpenSCAD, >> > >> > >   The text shows if I use Echo and it shows if quoted, but not if I reference it as >> > Text[i] >> > >> > > So it doesn't know that is a string? >> > >> > > Thank you; >> > >> > > // Planer Info >> > > // Bob Roos >> > > // December 6, 2021 >> > > Size = 10; >> > > Space = 12; >> > > H = 90; >> > > T = 3; >> > > W = 90; >> > > Text = [ >> > > ["Max Width -- 15in "], >> > > ["Max Thickness -- 6in "], >> > > ["Min Length -- 6in "], >> > > ["Min Thickness -- 3/16in "], >> > > ["1 turn = 2mm -- recommended 1/2 turn per pass" ], >> > > ["Vary use of sides and middle to spread wear"], >> > > ["NO plywood, particle board, endgrain, mesquite"] >> > > ]; >> > >> > > for (i = [0:len(Text)-1]){ >> > > //    echo(Text[i]); >> > > translate([0,i*Space,0]) linear_extrude(T) text(Text[i],size=Size); >> > > } >> > > linear_extrude(T) text(size=10,"Text[1]"); >> > >> > >> > >> > -- >> > have Fun, >> >  Bob                           mailto:roosbob@wybatap.com >> > _______________________________________________ >> > OpenSCAD mailing list >> > To unsubscribe send an email to discuss-leave@lists.openscad.org >> >> >> -- >> This email has been checked for viruses by AVG. >> https://www.avg.com >> _______________________________________________ >> OpenSCAD mailing list >> To unsubscribe send an email to discuss-leave@lists.openscad.org > Virus-free. www.avg.com --  have Fun,  Bob                           mailto:roosbob@wybatap.com
