V
vulcan_@mac.com
Wed, Sep 17, 2025 8:12 PM
i was working in RotateExtrudeNode.cc today and in VisualStudioCode some of the #include statements have red squiggly lines under them showing there is a problem..
for this include:
#include "core/RotateExtrudeNode.h"
i get
cannot open source file "glib.h" (dependency of "C:\Users\Jeff\.vscode\extensions\ms-vscode.cpptools-1.27.5-win32-x64\bin\core\RotateExtrudeNode.h")C/C++(1696)
but i cannot find where glib.h is coming from. I know that i need to update the include path, and i have found where to do that ..
is glib.h part of the compiler? a specific library?
another mystery is
cannot open source file "libintl.h" (dependency of "C:\Users\Jeff\.vscode\extensions\ms-vscode.cpptools-1.27.5-win32-x64\bin\core\module.h")C/C++(1696)
BUT … i did solve a red squiggly for a boost header by installing boost and adding its folder to the include path list
any tips for finding header files in general .. short of doing a find command from the root folder and working thru the resulting massive list of .h files
for this include:
\#include "core/RotateExtrudeNode.h"
i get
> cannot open source file "glib.h" (dependency of "C:\\Users\\Jeff\\.vscode\\extensions\\ms-vscode.cpptools-1.27.5-win32-x64\\bin\\core\\RotateExtrudeNode.h")C/C++(1696)
another mystery is
cannot open source file "libintl.h" (dependency of "C:\\Users\\Jeff\\.vscode\\extensions\\ms-vscode.cpptools-1.27.5-win32-x64\\bin\\core\\module.h")C/C++(1696)
V
vulcan_@mac.com
Wed, Sep 17, 2025 8:34 PM
i found out that libintl.h is part of gettext and i have two versions visible in PowerShell
winget show gettext
Name Id Source
GnuWin32: GetText GnuWin32.GetText winget
gettext + iconv mlocati.GetText winget
but then .. i don’t know where those are installed either
i found out that libintl.h is part of gettext and i have two versions visible in PowerShell\
winget show gettext
> Name Id Source
RV
Roel Vanhout
Wed, Sep 17, 2025 9:58 PM
Are those development packages? You need source code to compile all of
this. To be honest, compiling large open source projects based on gnu
libraries like gettext, on Windows, is not for the faint of heart, or the
inexperienced for that matter. I put together a toolchain based around
vcpkg last year but there didn't seem to be much interest. Not to put too
fine a point on it, but if you don't recognize glib.h as the 'main' header
for the Glib library, you probably also don't know what Glib is, which
hints at a programming experience level that is unlikely to be sufficient
to take on something as intricate as getting Openscad to compile on Windows
(at least with msvc, in Cygwin it may be easier).
Cheers
On Wed, Sep 17, 2025, 22:35 vulcan_--- via Discuss <
winget show gettext
Name Id Source
Cheers
> winget show gettext
> Name Id Source
Wed, Sep 17, 2025 10:29 PM
On Sep 17, 2025, at 16:12, vulcan_--- via Discuss discuss@lists.openscad.org wrote:
This is a challenge across IDEs, as the IDEs own tooling isn’t necessary aware of, or using, the same build configuration as the project you’re looking at.
I have the same issue with VS Code on macOS, but I haven’t had the energy to go on a hunting expedition for the solution..
> On Sep 17, 2025, at 16:12, vulcan_--- via Discuss <discuss@lists.openscad.org> wrote:
Wed, Sep 17, 2025 10:49 PM
Roel, there has been some development on the Windows front: https://github.com/openscad/openscad/issues/6123
There is still lots to do and it mostly depends on someone knowledgeable about Windows driving it forward, and those people are very hard to find.
On Sep 17, 2025, at 17:58, Roel Vanhout via Discuss discuss@lists.openscad.org wrote:
Are those development packages? You need source code to compile all of this. To be honest, compiling large open source projects based on gnu libraries like gettext, on Windows, is not for the faint of heart, or the inexperienced for that matter. I put together a toolchain based around vcpkg last year but there didn't seem to be much interest. Not to put too fine a point on it, but if you don't recognize glib.h as the 'main' header for the Glib library, you probably also don't know what Glib is, which hints at a programming experience level that is unlikely to be sufficient to take on something as intricate as getting Openscad to compile on Windows (at least with msvc, in Cygwin it may be easier).
Cheers
On Wed, Sep 17, 2025, 22:35 vulcan_--- via Discuss <discuss@lists.openscad.org mailto:discuss@lists.openscad.org> wrote:
winget show gettext
Name Id Source
To unsubscribe send an email to discuss-leave@lists.openscad.org mailto:discuss-leave@lists.openscad.org_______________________________________________
> On Sep 17, 2025, at 17:58, Roel Vanhout via Discuss <discuss@lists.openscad.org> wrote:
> Cheers
> On Wed, Sep 17, 2025, 22:35 vulcan_--- via Discuss <discuss@lists.openscad.org <mailto:discuss@lists.openscad.org>> wrote:
>> winget show gettext
>> Name Id Source
>> To unsubscribe send an email to discuss-leave@lists.openscad.org <mailto:discuss-leave@lists.openscad.org>_______________________________________________
V
vulcan_@mac.com
Wed, Sep 17, 2025 11:15 PM
i do not intend to compile the app myself .. i did try it in early August but did not get far with it.
I am only interested in setting up the header files for the INCLUDE_PATH so that the red squiggly lines under included files that are missing dependencies go away.
I thought i was getting somewhere with that but i am still seeing the squiggly lines even with boost, glib, and eigen header files available in the include path of VisualStudioCode I still have no joy.
V
vulcan_@mac.com
Wed, Sep 17, 2025 11:20 PM
… but if you don't recognize glib.h as the 'main' header for the Glib library, you probably also don't know what Glib is, which hints at a programming experience
indeed .. that was a bad sign. At one time I was coding extensions and utilities for Alias|wavefront, but any graphics programming i did was in the SGI Irix environment .. no Glib .. so i did not recognize it right off.
the bad sign was of failing memory .. ;-)
RV
Roel Vanhout
Thu, Sep 18, 2025 7:34 AM
OK, if you don't want to actually compile the dependencies, that's more
feasible. In VS Code, after installing the C/C++ extension, you select
"C/C++: Edit Configurations (UI)" from the command palette, and then you
enter all paths where you have headers (likely one for each library
Openscad uses, which will be a lot) under "Include paths". Or you can enter
it in the corresponding .json file.
If it's just the squiggles that annoy you though, you can also turn them
off in the command palette, something like 'C/C++ disable error
squiggles'...
VS Code is OK for occasional C++ development on Windows, or a quick code
exploration where startup time of the editor is important, but using Visual
Studio proper is much more convenient (well, to me, I guess this has to do
with the amount of experience one has with one versus the other). There,
after opening the 'project directory' (as you won't have .vcxproj/.sln
files, you just use the openscad source directory), you right-click on the
project in the Solution Explorer, do 'properties', then under 'C/C++' you
add those directories to 'Additonal Include Directories'.
cheers
On Thu, Sep 18, 2025 at 1:15 AM vulcan_--- via Discuss <
squiggles'...
cheers
Thu, Sep 18, 2025 8:59 AM
If it is on your system, this will find it, https://www.voidtools.com/
'everything'
for this include:
i get
another mystery is
"C:\Users\Jeff.vscode\extensions\ms-vscode.cpptools-1.27.5-win32-x64\bin\core\module.h")C/C++(1696)
list of .h files
'everything'
> for this include:
> i get
> another mystery is
> list of .h files
Thu, Sep 18, 2025 11:17 AM
I use Everything ALL the time. If you are using Windows, you really
need to try it.
'everything'
for this include:
i get
another mystery is
list of .h files
need to try it.
> 'everything'
>> for this include:
>> i get
>> another mystery is
>> list of .h files
>> To unsubscribe send an email todiscuss-leave@lists.openscad.org
