About 2/3 of the way through this video, we see a new way to 3D print
bores which require no support material.
I wonder if this approach could be incorporated into any of the
libraries that we commonly use
https://www.youtube.com/watch?v=KBuWcT8XkhA
Yup. I tried that. I found it to be simpler to use this beveled step:
module verticalHoleWithBevelStep( screwInfo, length, layerHeight )
// The default orientation has the screw head at the bottom, flush with
// the xy plane.
threadD = SCREW_HOLE_SCALE_FACTOR * screwInfo[0];
headD = SCREW_HOLE_SCALE_FACTOR * screwInfo[1];
headZ = SCREW_HOLE_SCALE_FACTOR * screwInfo[2];
adjustedLength = SCREW_HOLE_SCALE_FACTOR * length;
union()
cylinder( h=headZ, d=headD );
translate( [ 0, 0, headZ ] )
cylinder( h=3*layerHeight, d1=headD, d2=threadD );
cylinder( h=adjustedLength, d=threadD );
L_cube( [ 10,10,10], center="xy" );
verticalHoleWithBevelStep( Screw_info("M3"), 10 , 0.2 );
I’ve used that technique in the printable 3D printer design that inspired the BOSL and BOSL2 libraries. It’s unclear to me, however, how to genericize that pattern for a library, as it is extremely dependent on the shape of the area to be bridged.
-Revar
On May 20, 2023, at 1:18 PM, jon jon@jonbondy.com wrote:
About 2/3 of the way through this video, we see a new way to 3D print bores which require no support material.
I wonder if this approach could be incorporated into any of the libraries that we commonly use
NopSCADlib can do it. You pass a child which is the 2D profile of the hole
below. It's called hanging hole
-Revar
I wrote about it, with cod and examples
https://www.reddit.com/r/openscad/comments/13nlnvk/images_to_go_with_how_to_3d_print_bores_without/
