Automated Testing
Fri, Oct 10, 2025 2:45 AM
On Oct 9, 2025, at 22:18, Leonard Martin Struttmann via Discuss discuss@lists.openscad.org wrote:
Ok, thanks, everyone for the ideas.  I am going to start (I'm running on MacOS) by writing a bunch of zsh scripts that generate .OBJ files and will compare them to previously generated "golden" files.
Just keep in mind that exact vertex coordinates and tessellation is hard to guarantee. This is why we compare images.
..but if you run your tests with --enable=predictible-output, things may work better.
> On Oct 9, 2025, at 22:18, Leonard Martin Struttmann via Discuss <discuss@lists.openscad.org> wrote: > > Ok, thanks, everyone for the ideas. I am going to start (I'm running on MacOS) by writing a bunch of zsh scripts that generate .OBJ files and will compare them to previously generated "golden" files. > Just keep in mind that exact vertex coordinates and tessellation is hard to guarantee. This is why we compare images. ..but if you run your tests with --enable=predictible-output, things may work better. -Marius
