I was writing a module to replace rotate_extrude() so that I could deal with
the issue that I mentioned in the Does rotate_extrude angle property allow
for values that don't divide 360 evenly?
http://forum.openscad.org/Does-rotate-extrude-angle-property-allow-for-values-that-don-t-divide-360-evenly-td19835.html
thread. However, I got some weird error which I can only describe as a
rounding error, but I am not exactly positive that it is.
Here is the full executable code:
and this is what I'm getting at the interface between the rotate_extrude()
and the extrude_end_segments():
http://forum.openscad.org/file/n19958/rounding_error.png
Note that the extrude_end_segments() is producing an object that is not the
same size as the rotate_extrude(). However, since these are only supposed
to be rotations, should there be that much of a change in size? Looks to be
in the 1-0.1 unit range. Is this indeed a rounding error?
Thanks,
View this message in context: http://forum.openscad.org/Confused-as-how-a-this-could-happen-tp19958.html
with
allow
I don't understand the premise of the problem. Where does this idea of
"values that don't divide 360 evenly" come from? That is just weird.
There is no such limitation, or at least there should not be. The only
thing is that in versions prior to 2016.xx, the angle parameter is
silently ignored and assumed to be 360.
Just use whatever angle you want with rotate_extrude. Granted, I have
not tried OpenSCAD 2016.xx yet, so if there is an issue it should be
identified and fixed. I think a simple example demonstrating the problem
should be provided, for example:
rotate_extrude(angle=57.295779513082320876798154814105)
translate([50,0,0]) circle(10);
Doesn't it work in 2016.xx ?
well, you won't get more than 7 digits (single) or so resolved, but of
course it works.
Where is the problem to download a 2016.xx and test it?
View this message in context: http://forum.openscad.org/Confused-as-how-a-this-could-happen-tp19958p19963.html
The problem is not here. I have been using other software recently...
:-) I just figured the link to 2016.xx was at the bottom of the download
page. As could be expected my little example works, so the whole issue
is a non-problem.
cacb wrote
the whole issue is a non-problem.
Yes and no. A solution based on sweep() can easily be extended to something
more general than just a rotate_extrude. Remember our discussion about
threads http://www.thingiverse.com/thing:1659079 .
Adrian, this is your code using 2016.xx, some odd angle and an arbitrary
resolution.
rotate_extrude(angle = 42.234, $fn = 200) arrow_2d(1, .5, .25);
module arrow_2d(l,w,a) polygon([[0,0],[w,0],[w,l-a],[w*1.3,l-a],[0,l]]);
View this message in context: http://forum.openscad.org/Confused-as-how-a-this-could-happen-tp19958p19965.html
something
The non-problem referred to the value of the angle parameter.
Sure, a general sweep would be extremely useful, I agree. However, when
talking specifically about threads, one can imagine extending
rotate_extrude to take a pitch parameter and allow angles spanning
several whole revolutions. The model below was created using my own
variant of rotate_extrude (on top of carve), rotating 15*360 degrees and
with a suitable pitch. It is smart enough to protest if self
intersections will occur, so in practice it works.
http://www.thingiverse.com/thing:1445033
with
allow
The premise is that $fn must be an integer, so you cannot have a
rotate_extrude produce an extrusion that doesn't result in a whole number of
angled segments.
I never got a clear answer if the angle of the extrusion would have a
complete, 100% scaled, 2d representation of the original on either end of
the extrusion.
View this message in context: http://forum.openscad.org/Confused-as-how-a-this-could-happen-tp19958p19976.html
I've not bothered as yet because afaik, I would have to build it and I'm
just too lazy.
View this message in context: http://forum.openscad.org/Confused-as-how-a-this-could-happen-tp19958p19977.html
is a non-problem.
Good to know about that. Never bothered to go down the page recently. I'll
try it out. :)
View this message in context: http://forum.openscad.org/Confused-as-how-a-this-could-happen-tp19958p19978.html
of angled segments.
Your premise is wrong. You may assign a fraction value to $fn: it will be
adjusted to an integer (with floor, I guess). If an angle is specified in
rotate_extrude, $fn is adjusted in order to ensure that the total angle is
met. See this example from above and bellow to confirm a perfect match:
color("blue")
translate([0,0,-7])
rotate_extrude(r=10, $fn=14.5)
translate([10,0]) square(5,center=true);
rotate_extrude(r=10, angle=360/7, $fn=14)
color("red")
translate([0,0,7])
rotate_extrude(r=10, angle=360/7, $fn=18.5)
View this message in context: http://forum.openscad.org/Confused-as-how-a-this-could-happen-tp19958p19980.html
