LB
L Boyd
Tue, Aug 30, 2016 12:09 PM
I see multiple question from those new to OpenSCAD about what we call
variables. They are confused because they are different from the variables
used in many programming languages. They don't understand why the can't do
a=a+1.
They are not really constants either, because they can be overridden locally
within inner scopes.
Perhaps we should use an unfamiliar name, so that they have to read the
definition for how to use them.
I don't have any suggestions, but we need to discuss this before changing
the manual.
Larry
View this message in context: http://forum.openscad.org/What-to-call-variables-tp18260.html
a=a+1.
the manual.
Larry
AC
Alan Cox
Tue, Aug 30, 2016 12:31 PM
a=a+1.
the manual.
They are constants but they are scoped. No different to C
const x = 1
static void foo(void)
const x = 4;
blah;
Or perhaps think of them as functions or macros, they are really just an
expansion.
Alan
On Tue, 30 Aug 2016 05:09:39 -0700 (MST)
> a=a+1.
> the manual.
const x = 1
const x = 4;
blah;
expansion.
Alan
LB
L Boyd
Tue, Aug 30, 2016 3:31 PM
L Boyd <
variables
do
a=a+1.
locally
the manual.
const x = 1
const x = 4;
blah;
expansion.
Alan
True, but they are also more
for (a =[3:5])echo(a); // 3 4 5
The question is what word should be used in the manual.
> L Boyd <
> lboyd@
>> variables
>> do
>> a=a+1.
>> locally
>> the manual.
> const x = 1
> const x = 4;
> blah;
> expansion.
> Alan
> Discuss@.openscad
Larry
View this message in context: http://forum.openscad.org/What-to-call-variables-tp18260p18262.html
FV
Frank van der Hulst
Tue, Aug 30, 2016 6:18 PM
Why NOT make them behave like variables in other languages and allow a = a
a=a+1.
locally
the manual.
Larry
+ 1 ?
> a=a+1.
> locally
> the manual.
> Larry
DS
Dan Shriver
Tue, Aug 30, 2016 6:22 PM
"Constants within a scope"?
That would describe them.
a=a+1.
locally
the manual.
Larry
> a=a+1.
> locally
> the manual.
> Larry
MD
Michele Denber
Tue, Aug 30, 2016 6:23 PM
= a + 1 ?
> = a + 1 ?
I second that.
- Michele
Ronaldo
Tue, Aug 30, 2016 7:06 PM
Because there is no assignment in OpenSCAD. When you write:
in OpenSCAD, this is a definition, like in math, not an assignment.
Assignments are the cause of many misleading code and many languages
restrict their effects. Functional programming languages have no variables
neither assignments. We don't need them.
View this message in context: http://forum.openscad.org/What-to-call-variables-tp18260p18266.html
> + 1 ?
> a = 10;
Jerry Davis
Tue, Aug 30, 2016 7:28 PM
excuse me? There are assignments in Functional programming languages.
And yes, we really could use them. Functional programming languages in
simple terms make a
difference between where the variable (in memory) is, and the value that
points
to it.
So, why have true variables only in certain circumstances (like for loops,
arguments in module calls, functions, etc), and not in others.
If a value could be assigned to a "variable" at any time, then the
controversy would just go away.
Jerry
Extra Ham Operator: K7AZJ
Registered Linux User: 275424
> a
> > + 1 ?
> > a = 10;
simple terms make a
points
to it.
Jerry
*The most exciting phrase to hear in science - the one that heralds new
discoveries - is not "Eureka!" but "That's funny...".*- Isaac. Asimov
Tue, Aug 30, 2016 8:14 PM
OpenSCAD is a mathematical notation for describing geometric shapes. It's
not a general purpose programming language.
OpenSCAD's use of the term "variable" is consistent with the meaning of
"variable" in mathematics, and in pure functional programming languages.
The word "variable" in mathematics and formal logic has a distinguished
history going back hundreds of years, and I don't think there's a problem
using that word with its traditional meaning.
The terminology I'd get rid of instead is "assignment statement". I
consider x = 1; to be a "definition" of x. It's a mathematical equation
that defines the meaning of x within its scope. The underlying
mathematical reason that x = x + 1; is invalid is because this is not a
valid equation defining x. There is no number x that is equal to itself
plus 1.
a=a+1.
locally
the manual.
Larry
consider `x = 1;` to be a "definition" of `x`. It's a mathematical equation
that defines the meaning of `x` within its scope. The underlying
mathematical reason that `x = x + 1;` is invalid is because this is not a
valid equation defining `x`. There is no number `x` that is equal to itself
plus 1.
> a=a+1.
> locally
> the manual.
> Larry
DW
Don Wooton
Tue, Aug 30, 2016 8:31 PM
How about having a warning message something like
WARNING Value reassigned: line 6
and a preferences to turn this one warning off. If the warning
is on by default, it may cause the new user to notice that this
procedure is not expected and to look in the manual.
- Don
On Aug 30, doug moen propounded certain bytes, to wit:
Subject: Re: [OpenSCAD] What to call "variables"
plus 1.
a=a+1.
locally
the manual.
Larry
-- End of excerpt from doug moen'
- Don
> plus 1.
> > a=a+1.
> > locally
> > the manual.
> > Larry
